ESP32 debugging with Segger Jlink
Hello All,
I am using Segger Jlink for debugging in ESP32. But not able to succeed as I got "exec format error" on launching debugger
Environment
Ubuntu 14.04 32 bit Eclipse
Steps followed
1. Installed Segger Jlink plugin for eclipse
2. Provided the ESP32 config files to Jlink
3. Set the path of application to elf file
I suspect Jlink misses the knowledge on elf/bin format of ESP32.
Correct me if I am wrong and any suggestions on where I am going wrong is welcome.
let me know how to solve this.
thanks!
Environment
Steps followed
thanks!
Re: ESP32 debugging with Segger Jlink
It is possible to use JLink debugger (hardware part of it) for ESP32. Please follow this guide: https://docs.espressif.com/projects/esp ... index.html. Note that JLink software is not compatible with ESP32, so you will need to follow the steps described in that guide to set up OpenOCD.
--> we have downloaded OpenOCD from the
Github(https://github.com/gnu-mcu-eclipse/openocd/releases)--success
--> In Configuring ESP32 Target step
--> Configure and connect JTAG interface------success
--> Run OpenOCD with command( bin/openocd -s scripts/ -f
scripts/interface/jlink.cfg -f scripts/board/esp-wroom-32.cfg)--Failed
In above step we are getting an error like
"embedded:startup.tcl:21: Error: Unknown target type esp32, try one of
arm7tdmi, arm9tdmi, arm920t, arm720t, arm966e, arm946e, arm926ejs,
fa526, feroceon, dragonite, xscale, cortex_m, cortex_a, cortex_r4,
arm11, ls1_sap, mips_m4k, avr, dsp563xx, dsp5680xx, testee,
avr32_ap7k, hla_target, nds32_v2, nds32_v3, nds32_v3m, or1k,
quark_x10xx, quark_d20xx, stm8, riscv, or aarch64
in procedure 'script'
at file "embedded:startup.tcl", line 60
at file "scripts/board/esp-wroom-32.cfg", line 58
in procedure 'target' called at file "scripts//target/esp32.cfg", line 90
in procedure 'ocd_bouncer'
at file "embedded:startup.tcl", line 21".
Need your suggestion to solve this error.
thanks,
ningappa
thanks,
ningappa
The vanilla OpenOCD you downloaded does not support the ESP32. Please download the ESP32 version from https://github.com/espressif/openocd-esp32 instead.
To build OpenOCD, use the following sequence of commands:
./bootstrap (when building from the git repository)
./configure
make
Above following step we are getting an "configure: error: jimtcl not found, run git submodule init and git submodule update."
i have attached the config.log file for your reference.
thanks
./configure
make
thanks
- config.log
- (46.6 KiB) Downloaded 1028 times
I know this is somewhat of a cryptic error message and it may not immediately be clear what to do, but have you tried running git submodule init and git submodule update?Configure: error: jimtcl not found, run git submodule init and git submodule update.
Yes,we have tried but again we got same error.I know this is somewhat of a cryptic error message and it may not immediately be clear what to do, but have you tried running git submodule init and git submodule update?
If you have trouble building openocd, please try downloading the binaries from the releases page: https://github.com/espressif/openocd-esp32/releases.
we are getting same error "exec format error" as we were got in the beginning of this conversation.Hello All,
Environment
Steps followed
thanks
Could you please first verify if you are able to debug from the command line, before using Eclipse? Please follow these instructions: https://docs.espressif.com/projects/esp ... index.html
Users browsing this forum: No registered users and 196 guests
