WROVER PCB or IPex antenna
Posted: Mon Sep 10, 2018 1:08 pm
by curarepilot
I have a WROVER board that comes with the PCB antenna connected. (from the schematic I assume R15 is connected and R14 is NOT connected).
If I want to use an external antenna connected to the ipex connector, do I need to remove R15 and move it to the R14 position? (I assume having both connected at the same time does not work).
Re: WROVER PCB or IPex antenna
Posted: Tue Sep 11, 2018 2:25 am
by Sprite
If I read the schematics in https://www.espressif.com/sites/default ... eet_en.pdf correctly, that's indeed what you need to do.
