I'm using BLE on ESP32.
The ESP32 board is my server.
I have a problem: the number of services is limited to 7, and also the number of characteristics is limited to 7.
If I try to use more services or characteristics the client (the smartphone or another ESP32 board) can't see them.
Is it possible to use more services and characteristics?
I have tried to see if there are some #define in the .h files that limit this number, but I don't have found anything.
Thank you
BLE: limited number of services and characteristics
Re: BLE: limited number of services and characteristics
There is parameter handles number
https://github.com/nkolban/ESP32_BLE_Ar ... Server.cpp
Thank you very much!
If other people are interested in this: the parameter numHandles of the function createService allows you to specify the number of characteristics.
Just out of curiosity: is it possible to change also the number of services?
There is no services number limit. Only limit is handles number which is 0xFFFF.
I have the same issue with the number of services for the esp32.
The following code stops after starting the seventh service.
Is the number of possible BLE-services on an ESP32 limited or can I change something in the code to expand the number?
Code: Untitled.c Select all
Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleServer.cpp
Ported to Arduino ESP32 by Evandro Copercini
updates by chegewara
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE1_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define SERVICE2_UUID "5fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define SERVICE3_UUID "6fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define SERVICE4_UUID "7fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define SERVICE5_UUID "8fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define SERVICE6_UUID "9fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define SERVICE7_UUID "4fafc301-1fb5-459e-8fcc-c5c9c331914b"
#define SERVICE8_UUID "4fafc401-1fb5-459e-8fcc-c5c9c331914b"
#define SERVICE9_UUID "4fafc501-1fb5-459e-8fcc-c5c9c331914b"
#define SERVICE10_UUID "4fafc601-1fb5-459e-8fcc-c5c9c331914b"
Serial.println("Starting BLE work!");
BLEDevice::init("Long name works now");
BLEServer *pServer = BLEDevice::createServer();
Serial.println("Service1");
BLEService *pService1 = pServer->createService(SERVICE1_UUID);
BLECharacteristic *pCharacteristic1 = pService1->createCharacteristic(SERVICE1_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic1->setValue("Hello World says Neil");
pService1->start();
Serial.println("Service2");
BLEService *pService2 = pServer->createService(SERVICE2_UUID);
BLECharacteristic *pCharacteristic2 = pService2->createCharacteristic(SERVICE2_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic2->setValue("Hello World says Neil");
pService2->start();
Serial.println("Service3");
BLEService *pService3 = pServer->createService(SERVICE3_UUID);
BLECharacteristic *pCharacteristic3 = pService3->createCharacteristic(SERVICE3_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic3->setValue("Hello World says Neil");
pService3->start();
Serial.println("Service4");
BLEService *pService4 = pServer->createService(SERVICE4_UUID);
BLECharacteristic *pCharacteristic4 = pService4->createCharacteristic(SERVICE4_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic4->setValue("Hello World says Neil");
pService4->start();
Serial.println("Service5");
BLEService *pService5 = pServer->createService(SERVICE5_UUID);
BLECharacteristic *pCharacteristic5 = pService5->createCharacteristic(SERVICE5_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic5->setValue("Hello World says Neil");
pService5->start();
Serial.println("Service6");
BLEService *pService6 = pServer->createService(SERVICE6_UUID);
BLECharacteristic *pCharacteristic6 = pService6->createCharacteristic(SERVICE6_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic6->setValue("Hello World says Neil");
pService6->start();
Serial.println("Service7");
BLEService *pService7 = pServer->createService(SERVICE7_UUID);
BLECharacteristic *pCharacteristic7 = pService7->createCharacteristic(SERVICE7_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic7->setValue("Hello World says Neil");
pService7->start();
Serial.println("Service8");
BLEService *pService8 = pServer->createService(SERVICE8_UUID);
BLECharacteristic *pCharacteristic8 = pService8->createCharacteristic(SERVICE8_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic8->setValue("Hello World says Neil");
pService8->start();
Serial.println("Service9");
BLEService *pService9 = pServer->createService(SERVICE9_UUID);
BLECharacteristic *pCharacteristic9 = pService9->createCharacteristic(SERVICE9_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic9->setValue("Hello World says Neil");
pService9->start();
Serial.println("Service10");
BLEService *pService10 = pServer->createService(SERVICE10_UUID);
BLECharacteristic *pCharacteristic10 = pService10->createCharacteristic(SERVICE10_UUID, BLECharacteristic::PROPERTY_READ);
pCharacteristic10->setValue("Hello World says Neil");
pService10->start();
BLEDevice::startAdvertising();
Serial.println("Characteristic defined! Now you can read it in your phone!");
delay(2000);
I tried this code with esp-idf in PIO and i found this, which is very strange:
You can try to use this function and decrease numHandles:
https://github.com/nkolban/esp32-snippe ... rver.h#L67
Each characteristic needs 2 handles and descriptor 1 handle.
BT_GATT: GATTS_ReserveHandles: no free handle blocks
dhiraj_gehlot
I am facing exactly same issue.
I am using Arduino IDE to code ESP-32 module. Currently I am using BLE functionality to communicate with our mobile app.
There seems to be limitation on number of BLE services which can be created. Even If I create more than 7 services, only 6 are visible.
I find some link which states solution in ESP-IDF but I couldn't find this variable GATT_MAX_SR_PROFILES or bt_target.h file:
https://github.com/espressif/esp-idf/issues/1644
https://github.com/espressif/esp-idf/issues/5495
Can someone help me?
Users browsing this forum: MicroController and 0 guests
