Need help in interfacing DP83848 Phy controller with ESP32
Posted: Tue Oct 30, 2018 11:53 am
HI, I am trying to interface ESP32 with Phy controller DP83848, i am using the Olimex reference Hardware Link
there is one change in hardware, instead of using BD5230G to control OSC, i am controlling it from GPIO pin of ESP32,
on Power up it is LOW for particular period.
The problem is i dont get any values from PHY, i have made following change in code,
but the PHY check always fails,
res1 and res2 are always 0xFFFF
i would like to know what may be problem, i have checked pin to pin connection between PHY and ESP32 and it seems OK.
is there anyway of troubleshooting, would like to know,
regards
sushant
#define LAN8720_PHY_ID1 0x2000 // 0x20005C90 for DP
#define LAN8720_PHY_ID2 0x5C90Code: Select all
// Call esp_eth_smi_wait_value() with a timeout so it prints an error periodically
res1 = esp_eth_smi_wait_value(MII_PHY_IDENTIFIER_1_REG, LAN8720_PHY_ID1, UINT16_MAX, 1000);
res2 = esp_eth_smi_wait_value(MII_PHY_IDENTIFIER_2_REG, LAN8720_PHY_ID2, LAN8720_PHY_ID2_MASK, 1000);i would like to know what may be problem, i have checked pin to pin connection between PHY and ESP32 and it seems OK.
regards
sushant
