Using a ESP32 WROVER as a slave with esp-idf v3.0 I'm doing SPI transactions using VSPI and DMA channel 1. Frequently I observe the following behavior:
- SPI interrupt TRANS_DONE triggers
- slv_rd_bit.slv_rdata_bit is set to 0
- the rx buffer doesn't contain the expected data
- host->hw->dma_rx_status seems to indicate that the DMA FIFO is not empty
On a nominal case, slv_rd_bit.slv_rdata_bit has a non zero value and the transaction structure I get from spi_slave_get_trans_result is correct but in this case the size of the transaction is set to 0 and the data can't be used.
Im' using the spi_slave_transmit API to bundle the spi_slave_queue_trans and spi_slave_get_trans_result calls.
Is there a reason this could happen? The master is setup with a 16MHz clock, and the mode is 0.
Thanks.
Invalid slave VSPI transaction on ESP32-WROVER
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: PetalBot, Qwantbot and 3 guests
- All times are UTC
- Top
- Delete cookies
About Us
Information
