How to keep LEDs turn on without fading or PWM
snahmad75
Postby snahmad75 » Wed Nov 07, 2018 5:22 pm
Here is my code
#define LEDC_HS_TIMER          LEDC_TIMER_0
#define LEDC_HS_MODE           LEDC_HIGH_SPEED_MODE
#define LEDC_HS_CH0_GPIO       (32)
#define LEDC_HS_CH0_CHANNEL    0
#define LEDC_HS_CH1_GPIO       (33)
#define LEDC_HS_CH1_CHANNEL    1
#define LEDC_LS_TIMER          LEDC_TIMER_1
#define LEDC_LS_MODE           LEDC_LOW_SPEED_MODE
#define LEDC_LS_CH2_GPIO       (26)
#define LEDC_LS_CH2_CHANNEL    2
#define LEDC_LS_CH3_GPIO       (0)
#define LEDC_LS_CH3_CHANNEL    3
#define LEDC_TEST_CH_NUM       (4)
ledc_timer_config_t ledc_timer;
ledc_channel_config_t ledc_channel[LEDC_TEST_CH_NUM];
\brief
\details
void initLeds()
     * Prepare and set configuration of timers
     * that will be used by LED Controller
	ledc_timer.duty_resolution = LEDC_TIMER_13_BIT;
    ledc_timer.freq_hz = 5000;
    ledc_timer.speed_mode = LEDC_HS_MODE;
    ledc_timer.timer_num = LEDC_HS_TIMER;
    // Set configuration of timer0 for high speed channels
    ledc_timer_config(&ledc_timer);
    // Prepare and set configuration of timer1 for low speed channels
    ledc_timer.speed_mode = LEDC_LS_MODE;
    ledc_timer.timer_num = LEDC_LS_TIMER;
	ledc_channel[0].channel    = (ledc_channel_t)LEDC_HS_CH0_CHANNEL;
    ledc_channel[0].duty       = 4000;
    ledc_channel[0].gpio_num   = LEDC_HS_CH0_GPIO;
    ledc_channel[0].speed_mode = LEDC_HS_MODE;
    ledc_channel[0].timer_sel  = LEDC_HS_TIMER;
	ledc_channel[0].intr_type  = LEDC_INTR_DISABLE;
	ledc_channel[1].channel    = (ledc_channel_t)LEDC_HS_CH1_CHANNEL;
    ledc_channel[1].duty       = 4000;
    ledc_channel[1].gpio_num   = LEDC_HS_CH1_GPIO;
    ledc_channel[1].speed_mode = LEDC_HS_MODE;
    ledc_channel[1].timer_sel  = LEDC_HS_TIMER;
	ledc_channel[1].intr_type  = LEDC_INTR_DISABLE;
    ledc_channel[2].channel    = (ledc_channel_t)LEDC_LS_CH2_CHANNEL;
    ledc_channel[2].duty       = 4000;
    ledc_channel[2].gpio_num   = LEDC_LS_CH2_GPIO;
    ledc_channel[2].speed_mode = LEDC_HS_MODE;
    ledc_channel[2].timer_sel  = LEDC_HS_TIMER;
	ledc_channel[2].intr_type  = LEDC_INTR_DISABLE;
	ledc_channel[3].channel    = (ledc_channel_t)LEDC_LS_CH3_CHANNEL;
    ledc_channel[3].duty       = 4000;
    ledc_channel[3].gpio_num   = LEDC_LS_CH3_GPIO;
    ledc_channel[3].speed_mode = LEDC_LS_MODE;
    ledc_channel[3].timer_sel  = LEDC_LS_TIMER;
	ledc_channel[3].intr_type  = LEDC_INTR_DISABLE;
    // Set LED Controller with previously prepared configuration
    for (int ch = 0; ch < LEDC_TEST_CH_NUM; ch++) {
	    ledc_channel_config(&ledc_channel[ch]);
    // Initialize fade service.
    ledc_fade_func_install(0);
Thanks,
Naem
snahmad75
Re: How to keep LEDs turn on without fading or PWM
Postby snahmad75 » Wed Nov 07, 2018 7:39 pm
Can some one reply please.
I need to keep my leds on all the time.
ESP_Sprite
Postby ESP_Sprite » Thu Nov 08, 2018 2:58 am
...if you need to keep your leds on all the time, why use the LED PWM unit? Just set the GPIO high and you're there.
WiFive
Postby WiFive » Thu Nov 08, 2018 3:36 am
:idea:
snahmad75
Postby snahmad75 » Thu Nov 08, 2018 9:37 am
ESP_Sprite wrote:...if you need to keep your leds on all the time, why use the LED PWM unit? Just set the GPIO high and you're there.
Kindly give example of setting Led GPIO to high
snahmad75
Postby snahmad75 » Thu Nov 08, 2018 11:25 am
Thanks, I will try this set it high using GPIO number of led.
Ritesh
Contact:
Postby Ritesh » Fri Nov 09, 2018 7:45 am
You just need to set direction of thst GPIO and then set value to High to keep LED as solid ON.
No more configuration is required for that.
Regards,
Ritesh Prajapati
snahmad75
Postby snahmad75 » Fri Nov 09, 2018 2:55 pm
Thanks everyone. all working.
Ritesh
Contact:
Postby Ritesh » Fri Nov 09, 2018 3:08 pm
Great. Thanks for update regarding same.
Regards,
Ritesh Prajapati
Users browsing this forum: No registered users and 203 guests
