Error on secondary bluetooth connection
gunar.kroeger
Postby gunar.kroeger » Tue Nov 13, 2018 5:05 pm
When connecting a secondary bluetooth device to the esp32 I get an error message:
(768946) SPP: ESP_SPP_DATA_IND_EVT len=3 handle=3
D (768946) SPP: primary channel data:
I (768946) SPP: start processing 01
D (768946) SPP: RX(3):01|
I (768956) SPP: finnished processing 01
I (768956) SPP: ESP_SPP_WRITE_EVT 0
E (779396) BT_OSI: alarm_set failed to start timer, err 0x103
I (780036) SPP: ESP_SPP_SRV_OPEN_EVT handle=641
D (780036) SPP: secondary channel open: 641
I (783586) SPP: ESP_SPP_DATA_IND_EVT len=3 handle=3
Is this a bug or am I supposed to do something special when connecting more than one device at once?
Everything apart from this message seems to work
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
squonk11
Re: Error on secondary bluetooth connection
Postby squonk11 » Fri Feb 22, 2019 6:11 pm
I am getting the error message "BT_OSI: alarm_set failed to start timer, err 0x103" also when using only one client. Did you find a solution for this problem?
"Whoever believes to be someone has stopped becoming someone"
Sokrates
gunar.kroeger
Postby gunar.kroeger » Wed Mar 13, 2019 1:05 pm
No I didn't
gunar.kroeger
Postby gunar.kroeger » Tue Nov 05, 2019 5:49 pm
Anyone?
Users browsing this forum: Google [Bot] and 2 guests
