Deep sleep wake up from GPIO impossible using Arduino IDE?
lesept
Postby lesept » Sun Nov 18, 2018 9:05 pm
Hi
I'm trying to use the deep sleep of the ESP32 and wake up using an interrupt from a MPU6050 accelerometer.
But when I compile the code, I get an error :
Arduino : 1.8.2 (Windows 10), Carte : "LOLIN D32, Default, 80MHz, 921600, None"
C:\Users\Chuwi\Documents\Arduino\_ESP32\DS_TouchWakeUp_et_Timer\DS_TouchWakeUp_et_Timer.ino: In function 'void setup()':
DS_TouchWakeUp_et_Timer:156: error: 'esp_deep_sleep_enable_ext0_wakeup' was not declared in this scope
Serial.println(esp_deep_sleep_enable_ext0_wakeup(GPIO_NUM_13, 1)); //1 = High, 0 = Low
exit status 1
Why is it not declared? Is it ipmossible to wake up from interrupt when programming with Arduino IDE?
WiFive
Re: Deep sleep wake up from GPIO impossible using Arduino IDE?
Postby WiFive » Sun Nov 18, 2018 11:18 pm
#include "esp_sleep.h"
And
esp_sleep_enable_ext0_wakeup
lesept
Postby lesept » Mon Nov 19, 2018 6:48 am
Thank you. Now I have no more compilation error, but the sensor does not wake the ESP32. Can you tell me what is wrong with my code or provide an example on how to achieve this?
I want to put the ESP32 in deep sleep and have my accelerometer MPU6050 wake it when it detects a movement.
#define Threshold 40 /* Greater the value, more the sensitivity */
#define uS_TO_S_FACTOR 1000000  /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP  10       /* Time ESP32 will go to sleep (in seconds) */
// Bus 2 : l'accéléro
#define SDA2 5
#define SCL2 4
RTC_DATA_ATTR int bootCount = 0;
touch_pad_t touchPin;
#define BUTTON_PIN_BITMASK 0xFF00000000 // all pins
#include <Wire.h>
#include <MPU6050.h>
MPU6050 accelgyro;
  Method to print the reason by which ESP32
  has been awaken from sleep
void print_wakeup_reason() {
  esp_sleep_wakeup_cause_t wakeup_reason;
  wakeup_reason = esp_sleep_get_wakeup_cause();
  switch (wakeup_reason)
    case 1  : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
    case 2  : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
    case 3  : Serial.println("Wakeup caused by timer"); break;
    case 4  : Serial.println("Wakeup caused by touchpad"); break;
    case 5  : Serial.println("Wakeup caused by ULP program"); break;
    default : Serial.println("Wakeup was not caused by deep sleep"); break;
  Method to print the touchpad by which ESP32
void print_wakeup_touchpad() {
  touch_pad_t pin;
  touchPin = esp_sleep_get_touchpad_wakeup_status();
  /*  Touch Sensor Pin Layout
    T0 = GPIO4
    T1 = GPIO0
    T2 = GPIO2
    T3 = GPIO15
    T4 = GPIO13
    T5 = GPIO12
    T6 = GPIO14
    T7 = GPIO27
    T8 = GPIO33
    T9 = GPIO32  */
  switch (touchPin)
    case 0  : Serial.print("Touch detected on GPIO 4 : value "); Serial.println(touchRead(T0)); break;
    case 1  : Serial.print("Touch detected on GPIO 0 : value "); Serial.println(touchRead(T1)); break;
    case 2  : Serial.print("Touch detected on GPIO 2 : value "); Serial.println(touchRead(T2)); break;
    case 3  : Serial.print("Touch detected on GPIO 15 : value "); Serial.println(touchRead(T3)); break;
    case 4  : Serial.print("Touch detected on GPIO 13 : value "); Serial.println(touchRead(T4)); break;
    case 5  : Serial.print("Touch detected on GPIO 12 : value "); Serial.println(touchRead(T5)); break;
    case 6  : Serial.print("Touch detected on GPIO 14 : value "); Serial.println(touchRead(T6)); break;
    case 7  : Serial.print("Touch detected on GPIO 27 : value "); Serial.println(touchRead(T7)); break;
    case 8  : Serial.print("Touch detected on GPIO 33 : value "); Serial.println(touchRead(T8)); break;
    case 9  : Serial.print("Touch detected on GPIO 32 : value "); Serial.println(touchRead(T9)); break;
    default : Serial.println("Wakeup not by touchpad"); break;
void callback0() {}
void callback1() {}
void callback2() {}
void callback3() {}
void callback4() {}
void callback5() {}
void callback6() {}
void callback7() {}
void callback8() {}
void callback9() {}
bool InitAccelero () {
  Wire.begin(SDA2, SCL2);
  accelgyro.initialize();
  //  accelgyro.setIntDMPEnabled(false);
  // verify connection
  bool Success  = accelgyro.testConnection();
  if (Success) {
    Serial.println("MPU6050 connection successful");
    // supply your own gyro offsets here, scaled for min sensitivity
    accelgyro.setXGyroOffset(29);
    accelgyro.setYGyroOffset(-30);
    accelgyro.setZGyroOffset(-45);
    accelgyro.setXAccelOffset(-3499);
    accelgyro.setYAccelOffset(-5049);
    accelgyro.setZAccelOffset(887);
  else Serial.println("MPU6050 connection failed");
  return Success;
  accelgyro.setIntMotionEnabled(true); // INT_ENABLE register enable interrupt source  motion detection
  accelgyro.setMotionDetectionThreshold(10); // 1mg/LSB
  accelgyro.setMotionDetectionDuration(2); // number of consecutive samples above threshold to trigger int
  bool AcceleroSuccess = InitAccelero ();
  delay(1000); //Take some time to open up the Serial Monitor
  //Increment boot number and print it every reboot
  ++bootCount;
  Serial.println("Boot number: " + String(bootCount));
  delay(200);
  //Print the wakeup reason for ESP32 and touchpad too
  print_wakeup_reason();
  print_wakeup_touchpad();
  //  touchAttachInterrupt(T0, callback0, Threshold);
  touchAttachInterrupt(T1, callback1, Threshold);
  touchAttachInterrupt(T2, callback2, Threshold);
  touchAttachInterrupt(T3, callback3, Threshold);
  //  touchAttachInterrupt(T4, callback4, Threshold);
  touchAttachInterrupt(T5, callback5, Threshold);
  touchAttachInterrupt(T6, callback6, Threshold);
  touchAttachInterrupt(T7, callback7, Threshold);
  touchAttachInterrupt(T8, callback8, Threshold);
  touchAttachInterrupt(T9, callback9, Threshold);
  //Configure Touchpad as wakeup source
//  esp_sleep_enable_touchpad_wakeup();
  //Configure Timer as wakeup source
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  // Configure RTCIO as wakeup source
  esp_sleep_enable_ext0_wakeup(GPIO_NUM_13, 1); //1 = High, 0 = Low
  //Go to sleep now
  Serial.println("Going to sleep now");
  delay(200);
  esp_deep_sleep_start();
The touchpin part was from previous tests, but touch and external wakeup are exclusive.
Thanks for your help.
robster_mn
Postby robster_mn » Fri Nov 15, 2019 1:47 am
Any progress with this, I am to trying to wake up using a 6050 ?
Thanks for any help?
Users browsing this forum: Bing [Bot], PerplexityBot and 1 guest
