Transparent Wi-Fi module with RMII input
Re: Transparent Wi-Fi module with RMII input
Postby rudi ;-) » Tue Feb 28, 2017 8:41 pm
WiFive wrote:
rudi ;-) wrote:
btw, there a small parameter idx mistake in the given pvParameter
but have figured it out
What is the correction?
I'm glad
To get a question from you WiFive
Finally you know what not 8-)
:D
here is the answer idx swap:
f_out = f_xtal * (sdm2 + 4) / (2 * (o_div + 2))
param0: enable
param1: (uint8_t) sdm2
param2: (uint8_t) o_div
param3: ?
param4: ?
examples:
rtc_plla_ena(1, 1, 1, 0, 0); // 33,3 MHz
rtc_plla_ena(1, 2, 1, 0, 0); // 40,3 MHz
rtc_plla_ena(1, 3, 1, 0, 0); // 47,2 MHz
rtc_plla_ena(1, 3, 0, 0, 0); // 70,2 MHz
rtc_plla_ena(1, 4, 2, 0, 0); // 40,3 MHz
rtc_plla_ena(1, 5, 1, 0, 0); // 60 MHz
bingo ;-)
rtc_plla_ena(1, 1, 0, 0, 0); // 50 MHz
rtc_plla_ena(1, 10, 0, 0, 0); // 140 MHz
rtc_plla_ena(1, 12, 0, 0, 0); // 156 MHz
rtc_plla_ena(1, 16, 0, 0, 0); // 156 MHz
rtc_plla_ena(1, 0, 1, 0, 0); // 26,7 MHz
rtc_plla_ena(1, 0, 2, 0, 0); // 20 MHz ( glass clear)
rtc_plla_ena(1, 0, 14, 0, 0); // 5 MHz Jitter
rtc_plla_ena(1, 1, 14, 0, 0); // 6.25 MHz Jitter
rtc_plla_ena(1, 6, 2, 0, 0); // 50 MHz
rtc_plla_ena(1, 0, 9000, 0, 0); // 8 MHz
rtc_plla_ena(1, 0, 900, 0, 0); // 8 MHz
rtc_plla_ena(1, 0, 254, 0, 0); // 2.57 MHz
rtc_plla_ena(1, 0, 255, 0, 0); // 2.5MHz
ESP_igrr
Postby ESP_igrr » Wed Mar 01, 2017 1:37 am
The fact that sdm2 is the 3rd argument and not 5th might mean that we aren't using the same version of libraries... And the function signature you have is then rtc_plla_ena(bool enable, uint32_t sdm2, uint32_t o_div).
Postby rudi ;-) » Wed Mar 01, 2017 2:24 am
hi ivan
thanks! good to know there are more versions ;-)
i use the first and last 'public' from esp32-wifi-lib
https://github.com/espressif/esp32-wifi ... brtc_clk.a
think there was only one version online
btw:
if i call the function with 3 parameters
then i got an error, "to few arguments"
added the lib, to use, rename it .a without .zip
thanks again!
edit:
Please always check on history
It may already have a newer version
on
Http://www.github.com/espressif
are located.
this uploaded was the first public version
and can be out dated if you surf later time here
in this thread.
librtc_clk.a.zip
(10.23 KiB) Downloaded 455 times
Postby rudi ;-) » Fri Mar 03, 2017 12:10 am
@ivan
thanks for the hint!
now i figured it out, ESP32 ETH PHY RMII with own 50MHz Clk for Refer and X_in
done!
i will forward code ect to robin and angus after clearing all
it takes few days for testing - and then upload
Postby rudi ;-) » Fri Mar 03, 2017 4:16 pm
ESP_igrr wrote:
Sorry, no idea whether that works with EMAC (there may be more settings needed to make EMAC actually use this clock), but at least it gets 50MHz out of IO16. Hope this helps.
Edit: rtc_plla_ena function signature may change, this function may be removed, you may get eaten by raptors if you use it, etc, etc.
hi ivan
short, think we can use it for EMAC - but we must change few things. at weekend i try to complete.
i read between the lines, that the rtc_plla_ena function may be removed?
How - will this function no longer exist?
Can you reveal something that does this function?
(E.g.
It would be interesting which register it uses to get this setting.
A few things I have already found in the emac_main
But are not all listed, e.g. Still missing the entry
Just for the use of gpio16 as clk src.
So far we have
If (emac_config.mac_mode == ETH_MODE_RMII) {
         emac_set_clk_rmii ();
         emac_set_clk_mii ();
I will supplement it with ( or other name )
ETH_MODE_RMII_INT_50MHZ_CLK
in as well
Esp_eth.h
Typedef enum {
     ETH_MODE_RMII = 0,
     ETH_MODE_RMII_INT_50MHZ_CLK, /* new */
     ETH_MDOE_MII,
} Eth_mode_t;
for config the emac_main
        if ( emac_config.mac_mode == ETH_MODE_RMII_INT_50MHZ_CLK) {
         emac_set_clk_rmii_intern();
And also adjust the emac_dev with
Void emac_set_clk_rmii_intern (void)
     // clear ex clock source
     REG_CLR_BIT (EMAC_EX_CLK_CTRL_REG, EMAC_EX_EXT_OSC_EN);
     REG_SET_BIT (EMAC_EX_CLK_CTRL_REG, EMAC_EX_INT_OSC_EN);
And a few other things like init clk for gpio16 ect.
i will try and make a PR then
just in time i have only the problem for right setup ( register settings ) with LAN8710A
it looks we have a small difference to LAN8720A -
Postby rudi ;-) » Sun Mar 05, 2017 1:29 pm
ESP_igrr wrote:The fact that sdm2 is the 3rd argument and not 5th might mean that we aren't using the same version of libraries... And the function signature you have is then rtc_plla_ena(bool enable, uint32_t sdm2, uint32_t o_div).
hi ivan
fyi, now the esp-idf repo provide the lib that you mentioned with 5 parameters.
txs
AAAwen
Postby AAAwen » Sat Sep 16, 2017 6:39 am
ESP_Sprite wrote:Fyi, we have both Ethernet (RMII) as well as WiFi on the ESP32. We do not have support for packet forwarding yet (which is what you seem to need) but we do have that in the roadmap; it should appear in esp-idf eventually.
Hi,ESP_Sprite:
I have the same question about the transparent bridge (between eth and wifi). I have a wrover-kit board, but I can't find the sample or document about it. Is any advice? Thanks very much!
我也同样想尝试用ESP32做一个以太网与wifi的桥接器进行透明传输。但是没有找到相关的资料。是否有人能够赐教,不胜感激!
eplancho
Postby eplancho » Tue Nov 27, 2018 7:12 pm
Any example available for this application?
Need to provide Wifi capabilities to an existing Ethernet board.
Thanks,
ESP_morris
Postby ESP_morris » Wed Nov 28, 2018 2:18 am
eplancho
Postby eplancho » Wed Nov 28, 2018 2:27 pm
Users browsing this forum: ESP_Sprite and 24 guests
