AMR record and playback loop error
mgsscorr1
Postby mgsscorr1 » Mon Nov 26, 2018 9:35 pm
I am attempting to put together the record and playback examples for AMR.
after i got both working together, i Wanted to run record and playback multiple times.
My issue is that i have added a counter for the file naming, but when i go to play the any recording other than the first recording i am getting the following error where the amr decoder keeps getting a BAD HEADER
Screen Shot 2018-11-26 at 3.23.51 PM.png (348.09 KiB) Viewed 4822 times
I went to attempt to check where that line of code is called but there is no "amr_decoder.c" file. When i go to read any recording on my laptop, it seems that the recording hasn't had any issues, just when playing back on the lyraTD. First run thru of rec/playback runs properly but anything else after that first recording doesn't playback because of that header issue
The following is how im calling the record file
Screen Shot 2018-11-26 at 4.29.41 PM.png (110.8 KiB) Viewed 4822 times
The following is how im calling the playback file
Screen Shot 2018-11-26 at 4.28.17 PM.png (182.51 KiB) Viewed 4822 times
If anyone has any ideas of why im receiving this error please let me know.
Thanks,
Steve
jason.mao
Re: AMR record and playback loop error
Postby jason.mao » Tue Nov 27, 2018 7:19 am
Hi Steve
Could you attach your recording AMR file to here?
Thanks.
