Can't bind socket to address, errno 112 Address already in use
DannyBackx
Postby DannyBackx » Sun Dec 09, 2018 2:53 pm
One of the things my app does is to serve image files to other nodes. After a network reconnect, the server code often crashes on the return statement just after bind.
Messages I typically see then are :
E (193533) ImageTaskLoop: ImageTaskLoop: Can't bind socket to address, errno 112 Address already in use, ServerSocket 63
uru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled.
Core 1 register dump:
PC : 0x400d5d80 PS : 0x00060e30 A0 : 0x00000000 A1 : 0x3ffcaf10
Can anyone help ?
Thanks,
Danny
 * Background task to serve the image transfer
 * As this can't be a class method, the variables are global.
void ImageTaskLoop(void *ptr) {
  const char *itl_tag = "ImageTaskLoop";
  if (weather && weather->isWeatherNode()) {
    const int listen_queue = 5;                   // Number of connections allowed
    // Start server
    struct sockaddr_in ServerAddr;
    ServerAddr.sin_addr.s_addr = htonl(INADDR_ANY);
    ServerAddr.sin_family = AF_INET;
    ServerAddr.sin_port = htons(portImage);
    ServerSocket = socket(AF_INET, SOCK_STREAM, 0);
    if (ServerSocket < 0) {
      ESP_LOGE(itl_tag, "Can't create socket");
      return;
    ESP_LOGI(itl_tag, "Socket created, %d", ServerSocket);
    if (bind(ServerSocket, (struct sockaddr *)&ServerAddr, sizeof(ServerAddr)) != 0) {
      ESP_LOGE(itl_tag, "ImageTaskLoop: Can't bind socket to address, errno %d %s, ServerSocket %d", errno, strerror(errno), ServerSocket);
      close(ServerSocket);
      ServerSocket = -1;
      return;				// Crash here
    if (listen(ServerSocket, listen_queue) != 0) {
      ESP_LOGE(itl_tag, "Listen failed, errno %d %s", errno, strerror(errno));
      ServerSocket = -1;
      return;
    fcntl(ServerSocket, F_SETFL, O_NONBLOCK);
  ESP_LOGD("ImageTaskLoop", "Start");
  while (1) {
      // Task 1 : serve an icon image, only in the weather node
      struct sockaddr_in RemoteAddr;
      socklen_t RAlen = sizeof (RemoteAddr);
      int ClientSocket = accept(ServerSocket, (struct sockaddr *)&RemoteAddr, &RAlen);
      // deleted
  ESP_LOGE("Peers static", "ImageTaskLoop exiting (after while) !");
void Peers::ImageServerStopTask() {
  ESP_LOGI(peer_tag, "ImageServerStopTask()");
  if (ServerSocket >= 0) {
    ESP_LOGI(peer_tag, "Closing ServerSocket %d", ServerSocket);
  ServerSocket = -1;
  if (imageTask)
    vTaskDelete(imageTask);
  imageTask = 0;
  ESP_LOGI(peer_tag, "ImageServerStopTask end");
DannyBackx
Re: Can't bind socket to address, errno 112 Address already in use
Postby DannyBackx » Sat Dec 22, 2018 12:43 pm
I added
  int flag = 1;
  setsockopt(mcsock, SOL_SOCKET, SO_REUSEADDR, &flag, sizeof(flag));
before the bind calls.
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bytespider, PerplexityBot, PetalBot and 0 guests
