BLE广播连接之后找不到服务
ChiShaoJun
BLE广播连接之后找不到服务
Postby ChiShaoJun » Tue Dec 11, 2018 4:38 am
例程为:gatt_server_service_table
手机为:honor 7x
现象:见截图
关键日志为:
Code: Untitled.txt Select all
root@ubuntu:~/esp/gatt_server_service_table# make monitor
Toolchain path: /home/kyle/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a
Compiler version: 5.2.0
Python requirements from /home/kyle/esp/esp-idf/requirements.txt are satisfied.
MONITOR
--- idf_monitor on /dev/ttyUSB0 115200 ---
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6160
ho 0 tail 12 room 4
load:0x40078000,len:10168
ho 0 tail 12 room 4
load:0x40080400,len:6552
entry 0x40080764
I (32) boot: ESP-IDF v3.3-dev-270-g6f8e2b018 2nd stage bootloader
I (32) boot: compile time 11:37:06
I (32) boot: Enabling RNG early entropy source...
I (38) boot: SPI Speed : 40MHz
I (42) boot: SPI Mode : DIO
I (46) boot: SPI Flash Size : 4MB
I (50) boot: Partition Table:
I (54) boot: ## Label Usage Type ST Offset Length
I (61) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (69) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (76) boot: 2 factory factory app 00 00 00010000 00100000
I (84) boot: End of partition table
I (88) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x230b4 (143540) map
I (147) esp_image: segment 1: paddr=0x000330dc vaddr=0x3ff80000 size=0x00000 ( 0) load
I (147) esp_image: segment 2: paddr=0x000330e4 vaddr=0x3ff80000 size=0x00000 ( 0) load
I (154) esp_image: segment 3: paddr=0x000330ec vaddr=0x3ffbdb60 size=0x02db0 ( 11696) load
I (167) esp_image: segment 4: paddr=0x00035ea4 vaddr=0x3ffc0910 size=0x00000 ( 0) load
I (172) esp_image: segment 5: paddr=0x00035eac vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at /home/kyle/esp/esp-idf/components/freertos/xtensa_vectors.S:1685
I (181) esp_image: segment 6: paddr=0x000362b4 vaddr=0x40080400 size=0x09d5c ( 40284) load
I (206) esp_image: segment 7: paddr=0x00040018 vaddr=0x400d0018 size=0x7cbf4 (510964) map
0x400d0018: _flash_cache_start at ??:?
I (385) esp_image: segment 8: paddr=0x000bcc14 vaddr=0x4008a15c size=0x07b38 ( 31544) load
0x4008a15c: coex_arbit_clean_overtime_until at ??:?
I (399) esp_image: segment 9: paddr=0x000c4754 vaddr=0x400c0000 size=0x00000 ( 0) load
I (399) esp_image: segment 10: paddr=0x000c475c vaddr=0x50000000 size=0x00000 ( 0) load
I (406) esp_image: segment 11: paddr=0x000c4764 vaddr=0x50000000 size=0x00000 ( 0) load
I (425) boot: Loaded app from partition at offset 0x10000
I (425) boot: Disabling RNG early entropy source...
I (426) cpu_start: Pro cpu up.
I (430) cpu_start: Starting app cpu, entry point is 0x400811d8
0x400811d8: call_start_cpu1 at /home/kyle/esp/esp-idf/components/esp32/cpu_start.c:246
I (0) cpu_start: App cpu up.
I (440) heap_init: Initializing. RAM available for dynamic allocation:
I (447) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (453) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (459) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (465) heap_init: At 3FFBDB5C len 00000004 (0 KiB): DRAM
I (472) heap_init: At 3FFC9A58 len 000165A8 (89 KiB): DRAM
I (478) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (484) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (491) heap_init: At 40091C94 len 0000E36C (56 KiB): IRAM
I (497) cpu_start: Pro cpu start user code
I (179) cpu_start: Starting scheduler on PRO CPU.
I (222) BTDM_INIT: BT controller compile version [6eb4acf]
I (222) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (312) phy: phy_version: 4000, b6198fa, Sep 3 2018, 15:11:06, 0, 0
I (682) GATTS_TABLE_DEMO: create attribute table successfully, the number handle = 8
I (682) GATTS_TABLE_DEMO: SERVICE_START_EVT, status 0, service_handle 40
I (692) GATTS_TABLE_DEMO: advertising start successfully
I (11652) GATTS_TABLE_DEMO: ESP_GATTS_CONNECT_EVT, conn_id = 0
I (11652) GATTS_TABLE_DEMO: 74 88 6b cb 09 cf
I (12152) GATTS_TABLE_DEMO: update connection params status = 0, min_int = 16, max_int = 32,conn_int = 32,latency = 0, timeout = 400
I (17352) GATTS_TABLE_DEMO: ESP_GATTS_DISCONNECT_EVT, reason = 0x13
I (17362) GATTS_TABLE_DEMO: advertising start successfully
I (36582) GATTS_TABLE_DEMO: ESP_GATTS_CONNECT_EVT, conn_id = 0
I (36582) GATTS_TABLE_DEMO: 74 88 6b cb 09 cf
I (37032) GATTS_TABLE_DEMO: update connection params status = 0, min_int = 16, max_int = 32,conn_int = 32,latency = 0, timeout = 400
I (1687362) GATTS_TABLE_DEMO: ESP_GATTS_DISCONNECT_EVT, reason = 0x13
I (1687372) GATTS_TABLE_DEMO: advertising start successfully
I (1688782) GATTS_TABLE_DEMO: ESP_GATTS_CONNECT_EVT, conn_id = 0
I (1688782) GATTS_TABLE_DEMO: 69 d0 d9 4c 2c ac
I (1689282) GATTS_TABLE_DEMO: update connection params status = 0, min_int = 16, max_int = 32,conn_int = 32,latency = 0, timeout = 400
I (1693882) GATTS_TABLE_DEMO: ESP_GATTS_DISCONNECT_EVT, reason = 0x13
I (1693892) GATTS_TABLE_DEMO: advertising start successfully
I (1813452) GATTS_TABLE_DEMO: ESP_GATTS_CONNECT_EVT, conn_id = 0
I (1813462) GATTS_TABLE_DEMO: 5f cb c1 f0 1b 15
I (1813912) GATTS_TABLE_DEMO: update connection params status = 0, min_int = 16, max_int = 32,conn_int = 32,latency = 0, timeout = 400
I (1817192) GATTS_TABLE_DEMO: ESP_GATTS_DISCONNECT_EVT, reason = 0x13
I (1817202) GATTS_TABLE_DEMO: advertising start successfully
I (2105192) GATTS_TABLE_DEMO: ESP_GATTS_CONNECT_EVT, conn_id = 0
I (2105192) GATTS_TABLE_DEMO: 5f cb c1 f0 1b 15
I (2105642) GATTS_TABLE_DEMO: update connection params status = 0, min_int = 16, max_int = 32,conn_int = 32,latency = 0, timeout = 400
Weijian-Espressif
Re: BLE广播连接之后找不到服务
Postby Weijian-Espressif » Tue Dec 11, 2018 9:57 am
gatt_server demo 测试正常吗? 能看到service吗? 或者换个APP试试?
ChiShaoJun
Re: BLE广播连接之后找不到服务
Postby ChiShaoJun » Thu Dec 13, 2018 2:20 am
换了个蓝牙调试助手搜到服务了。
Weijian-Espressif
Re: BLE广播连接之后找不到服务
Postby Weijian-Espressif » Thu Dec 13, 2018 8:03 am
