ELF binary parser
snahmad75
ELF binary parser
Postby snahmad75 » Thu Dec 13, 2018 11:49 pm
I there any C or C++ ELF binary parser which can parse bin files. either signed or not.
Thanks,
Naeem
Re: ELF binary parser
Postby Sprite » Sat Dec 15, 2018 3:44 am
Erm, a bin-file is not an elf-file, so an elf parser can, by definition, not parse a bin file. What do you need this for?
loboris
Postby loboris » Sat Dec 15, 2018 10:05 am
A standard elf file is also created during the build process and it can be parsed using any elf parser like 'readelf'
<mydir>$ readelf -h -l MicroPython.elf
ELF Header:
  Magic:   7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
  Class:                             ELF32
  Data:                              2's complement, little endian
  Version:                           1 (current)
  OS/ABI:                            UNIX - System V
  ABI Version:                       0
  Type:                              EXEC (Executable file)
  Machine:                           Tensilica Xtensa Processor
  Version:                           0x1
  Entry point address:               0x40081708
  Start of program headers:          52 (bytes into file)
  Start of section headers:          14056380 (bytes into file)
  Flags:                             0x300
  Size of this header:               52 (bytes)
  Size of program headers:           32 (bytes)
  Number of program headers:         8
  Size of section headers:           40 (bytes)
  Number of section headers:         55
  Section header string table index: 52
Program Headers:
  Type           Offset   VirtAddr   PhysAddr   FileSiz MemSiz  Flg Align
  LOAD           0x000000 0x3f3ffee0 0x3f3ffee0 0x62ba8 0x62ba8 RW  0x1
  LOAD           0x062bb0 0x3ffc0000 0x3ffc0000 0x055b4 0x055b4 RW  0x1
  LOAD           0x068168 0x3ffc55b8 0x3ffc55b8 0x00000 0x0c1f8 RW  0x1
  LOAD           0x068164 0x40080000 0x40080000 0x00400 0x00400 R E 0x1
  LOAD           0x068564 0x40080400 0x40080400 0x1f980 0x1f980 RWE 0x1
  LOAD           0x087ee4 0x400c0000 0x400c0000 0x00663 0x00663 R E 0x1
  LOAD           0x088548 0x400d0018 0x400d0018 0x160432 0x160432 R E 0x1
  LOAD           0x1e8980 0x50000000 0x50000000 0x0098a 0x0098c RW  0x1
 Section to Segment mapping:
  Segment Sections...
   00     .flash.rodata
   01     .dram0.data
   02     .dram0.bss
   03     .iram0.vectors
   04     .iram0.text
   05     .rtc.text
   06     .flash.text
   07     .rtc.data .rtc_noinit
Ritesh
Contact:
Postby Ritesh » Sun Dec 16, 2018 4:35 pm
Thanks,
Naeem
readelf and objdump utilities will be helpful to parse elf and binary files.
Regards,
Ritesh Prajapati
snahmad75
Postby snahmad75 » Mon Dec 17, 2018 9:48 am
Thanks,
Naeem
OK, Thanks. As I understood readelf and objdump utilities are python scripts.
Ritesh
Contact:
Postby Ritesh » Mon Dec 17, 2018 10:09 am
Thanks,
Naeem
You can use xtensa-esp32-elf-readelf and xtensa-esp32-elf-objdump utilities which are part if ESP32 Toolchain using which you can parse elf file as per your requirement.
Regards,
Ritesh Prajapati
Angus
Postby Angus » Mon Dec 17, 2018 10:53 pm
If you want to parse the .bin file rather than the .elf file (which is the output of "esptool.py elf2image" and the file which is actually flashed to the ESP32), then you can use esptool.py:
esptool.py --chip esp32 image_info binfile.bin
This doesn't work for the .elf file, you need to use one of the other tools mentioned in the thread.
Note that esptool.py ignores any signature appended to the .bin file.
Users browsing this forum: Applebot, Baidu [Spider], Bytespider, Qwantbot and 16 guests
