Page 1 of 2
NTP server giving time after long time
Posted: Fri Jan 11, 2019 11:43 am
by burkulesomesh43
Hi all,
I have used sntp example from esp idf and modified it as per my use as folllows-->>>
void sntp_task(void *pvParameter) {
	sntp_setoperatingmode(SNTP_OPMODE_POLL);
	sntp_setservername(0,"asia.pool.ntp.org");
	sntp_init();
	time_t now;
	struct tm timeinfo;
	struct tm *tmp;
	time(&now);
	localtime_r(&now, &timeinfo);
	while(timeinfo.tm_year < (2019 - 1900))
		printf("Time not set, trying...\n");
		vTaskDelay(5000 / portTICK_PERIOD_MS);
		time(&now);
	while(1)
		time(&now);
		setenv("TZ", "UTC-5:30", 1);
		tzset();
		tmp = localtime( &now );
		strftime(Timebuffer, sizeof(Timebuffer), "%d/%m/%Y  %I:%M:%S %p", tmp);
		vTaskDelay(999 / portTICK_RATE_MS);
but sometimes it does not gives time instantly or can't get time.
Don't know what is the problem.
please help me out to solve this.
Re: NTP server giving time after long time
Posted: Fri Jan 11, 2019 5:04 pm
by Ritesh
We have used ntp into our project but we have applied all server which are used for ntp server configuration. So, We haven't faced any issue like that.
Would you please try with that as provided into sntp example and check with that?
It might be like sometime you will not get time from server and you will get it from second server as quickly as possible.
Posted: Fri Jan 11, 2019 5:34 pm
by burkulesomesh43
can you please provide example you have used?
how can we use two servers?
Posted: Sat Jan 12, 2019 10:55 am
by Ritesh
Please find attached code for reference purpose for SNTP Init Process.
void initialize_sntp (void)
	sntp_setservername(0, "pool.ntp.org");
	sntp_setservername(1, "europe.pool.ntp.org");
	sntp_setservername(2, "uk.pool.ntp.org ");
	sntp_setservername(3, "us.pool.ntp.org");
	sntp_setservername(4, "time1.google.com");
	sntp_init();
Let me know if still issue after using that.
Posted: Sat Jan 12, 2019 12:22 pm
by burkulesomesh43
	sntp_init();
I am getting this issue again.
Actually it gives that issue sometimes only but don't know, why?
Posted: Sat Jan 12, 2019 1:05 pm
by Ritesh
	sntp_init();
Please send me logs in details because we are using that way and didn't face any issue yet.
Posted: Tue Jun 11, 2019 10:38 am
by burkulesomesh43
	sntp_init();
There is no logs generated. it only tries to reach NTP server continuosly.
Posted: Tue Jun 11, 2019 10:55 am
by Ritesh
We have tried same way at our end and didn't face any issue till now. I just want to clarify that are you sending NTP request after getting proper IP and external connectivity into device itself?
Posted: Tue Jun 11, 2019 10:59 am
by burkulesomesh43
Yes, I am sending NTP request after connecting the device to Network.
Posted: Tue Jun 11, 2019 11:10 am
by Ritesh
Then it should be worked?
Would you please try with master IDF as well with just sample STA example in which after getting IP event just ping to SNTP Server accordingly.
If still it is not working then there might be chances into your network as well or try with Hot-Spot as well with external network connectivity.
