Crowbar
idahowalker
Crowbar
Postby idahowalker » Sun Jan 13, 2019 1:11 pm
I power the ESP32 from its own 5V power supply.
If, whiles connected to the computer the voltage regulator that supplies the ESP32 decides to fail, mine did, and a USB cable is plugged into a computer, as mine was, the source of the voltage, in my case 9V, is directly connected to the source computer USB buss, like mine was.
My solution will be to crowbar the ESP32 supply source, 9V.
Mostly though this is just a bit of info.
mrburnette
Re: Crowbar
Postby mrburnette » Mon Jan 14, 2019 3:07 am
A powered USB hub will sacrifice itself and protect the PC.
Ray
permal
Re: Crowbar
Postby permal » Mon Jan 14, 2019 9:40 am
What does that mean?
FreddyVictor
Re: Crowbar
Postby FreddyVictor » Mon Jan 14, 2019 11:41 am
He/She means to simply short-circuit the 9volt supply !
Not sure I would recommend that since any power source for these chips is going to be able to supply a good amount of current, so who knows what may happen
I'm sure there must be better options eg: re-settable fuse, zener diode etc
idahowalker
Re: Crowbar
Postby idahowalker » Mon Jan 14, 2019 2:21 pm
Thank you mrburnette for your suggestion. I added in a powered hub.
The crowbar will short the 9V supply causing the fuse to blow and preventing the 9 volts, from a failed voltage regulator, from reaching the ESP32.
Users browsing this forum: Google [Bot] and 8 guests
