Need help to start with ESP32 Audio Framework
Posted: Sat Jan 26, 2019 5:11 pm
by Ritesh
Can you please suggest me using which development board I can start to use ESP32 Audio Development Framework with its examples?
Provide suggestions for that.
Re: Need help to start with ESP32 Audio Framework
Posted: Sat Jan 26, 2019 6:51 pm
by krzychb
Hi Ritesh,
There are two development boards supported by majority of examples in ESP-ADF: ESP32-LyraT and ESP32-LyraTD-MSC
* ESP32-LyraT has been the first development board supported by ESP-ADF and therefore most of examples are written for this particular board
* Even if there is a smaller number of examples working "out of box" with ESP32-LyraTD-MSC board, then it is fairly easy to switch between the boards by adding https://github.com/espressif/esp-adf/bl ... .c#L55-L62
* Some of examples are dedicated to particular board depending on peripherals used, see https://docs.espressif.com/projects/esp ... index.html
* ESP32-LyraT is 2x cheaper than ESP32-LyraTD-MSC, so if you do not need microphone array and support for AEC, then I would chose ESP32-LyraT.
Posted: Sun Jan 27, 2019 3:15 am
by Ritesh
Hi Ritesh,
Thanks for providing details for that.
So, I believe Alexa device can also be used with that framework for audio related functionality. Correct?
Posted: Sun Jan 27, 2019 10:54 am
by krzychb
Hi Ritesh,
The Amazon Alexa functionality is on the roadmap but not yet implemented.
To evaluate this functionality please check https://github.com/espressif/esp-va-sdk ... E-Alexa.md
Posted: Sun Jan 27, 2019 2:13 pm
by Ritesh
Hi Ritesh,
