I am using esp32 development kit, and trying to check ESP-MDF light example with that.
I am facing that device stuck in Yellow blinking.
I am trying to run with mesh app for android.
App shows me BLE disconnected after 10% of progress.
Here are the logs
(317) phy: phy_version: 4000, b6198fa, Sep 3 2018, 15:11:06, 0, 0
I (318) wifi: mode : sta (30:ae:a4:8f:2e:0c)
I (320) ESPNOW: espnow [version: 1.0] init
I (331) [light, 616]: event_loop_cb, event: 0x2101
I (1139) [mconfig_chain, 348]: Generate RSA public and private keys
I (1139) wifi: ic_enable_sniffer
I (1141) [light, 216]: BLE name: light_2e0c
W (1142) [mdf_info_store, 74]: <ESP_ERR_NVS_NOT_FOUND> Erase key-value pair, key: mupgrade_count
I (1144) [light, 616]: event_loop_cb, event: 0x2200
I (1798) BTDM_INIT: BT controller compile version [97a362b]
I (1799) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2097) [mconfig_blufi, 517]: BLUFI init finish, set ble advertising data
I (2098) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2107) [mconfig_blufi, 845]: start ble advertising
W (3194) [mdf_info_store, 74]: <ESP_ERR_NVS_NOT_FOUND> Erase key-value pair, key: light_count
D (3195) [light, 144]: Erase restart count
I (23310) [light, 616]: event_loop_cb, event: 0x2202
I (24381) [mconfig_blufi, 541]: BLUFI ble disconnect
I (24385) [light, 616]: event_loop_cb, event: 0x2203
I (29989) [light, 616]: event_loop_cb, event: 0x2202
I (31060) [mconfig_blufi, 541]: BLUFI ble disconnect
I (31063) [light, 616]: event_loop_cb, event: 0x2203
I (36618) [light, 616]: event_loop_cb, event: 0x2202
I (37739) [mconfig_blufi, 541]: BLUFI ble disconnect
I (37742) [light, 616]: event_loop_cb, event: 0x2203
I (43249) [light, 616]: event_loop_cb, event: 0x2202
Any sugession?
Thanks.
ESp-mesh
Re: ESp-mesh
Hi tushark,
If the App fails at 10%, then it means the BLE connection between the devices and the smartphone fails.
Please restart your Bluetooth function on your smartphone and retry.
Bangbang
Bangbang
