We need waer level file system with directory support into ESP32 IDF. We know that SPIFFS is giving support for that but it is not providing directory level support for that and we need it for small file size like 10 to 20 KB.
So, SPIFFS is not suitable for that.
Please provide or suggest me other appropriate file system for that.
Wear Leveling File System with Directory Support
Regards,
Ritesh Prajapati
Ritesh Prajapati
Re: Wear Leveling File System with Directory Support
I highly recommend LittleFS: https://github.com/ARMmbed/littlefs
It's easy to implement on the ESP32, has built in wear leveling, directory support, power failure resilient and much, much faster than SPIFFS.
Jason
Jason
Thanks for quick response for that.vonnieda wrote: ↑Fri Feb 01, 2019 3:39 amI highly recommend LittleFS: https://github.com/ARMmbed/littlefs
Jason
But as i have checked that it has only file support and not directory level support which we need as per our requirement. Also, I know that SPIFFS is heavy to load and use just for small file and directory support required.
Do you have any idea or any suggestions for that?
Regards,
Ritesh Prajapati
Ritesh Prajapati
SPIFFS does not have directory support, but it can be easily implemented using SPIFFS metadata feature.
I have SPIFFS with full directory support implemented in my MicroPython for ESP32.
LittleFS with full directory support is also implemented. It can be configured to run on top of Wear Leveling driver or without it, with 4096 or 512 bytes sector size.
At the moment I don't have time to implement it as a standalone esp-idf componnent, but I may do it next month.
You may try to extract it from the repository, but it is probably not an easy task...
Perhaps I was not clear. I am recommending LittleFS, not SPIFFS. LittleFS has directory support built in, and I use it every day.Ritesh wrote: ↑Fri Feb 01, 2019 4:04 amThanks for quick response for that.vonnieda wrote: ↑Fri Feb 01, 2019 3:39 amI highly recommend LittleFS: https://github.com/ARMmbed/littlefs
Jason
Jason
Thanks for providing response for that. So, It will be good for us if LittleFS supports directory as well.loboris wrote: ↑Fri Feb 01, 2019 5:58 pmSPIFFS does not have directory support, but it can be easily implemented using SPIFFS metadata feature.
I think there is one of your repository in which you have made one layer on top of SPIFFS to support directory as well.
So, I think we can also use that as well but still I need to check little bit before using that as per our requirements.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Ok. Great. Thanks for update regarding same.vonnieda wrote: ↑Fri Feb 01, 2019 6:03 pmPerhaps I was not clear. I am recommending LittleFS, not SPIFFS. LittleFS has directory support built in, and I use it every day.Ritesh wrote: ↑Fri Feb 01, 2019 4:04 amThanks for quick response for that.vonnieda wrote: ↑Fri Feb 01, 2019 3:39 amI highly recommend LittleFS: https://github.com/ARMmbed/littlefs
Jason
Jason
I will check and let you know if any further query for that.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: djixon, Google Adsense [Bot], MicroController and 167 guests
