I want to understand how to keep RTC clock working while chip logic is off(if possible)
if I connect VDD3P3_RTC to 3.3V supercapacitor/battery would it be enough? Do I need also to provide 3.3V to CHIP_PU?
What is the purpose of VDD3P3_RTC pin in ESP32-PICO-D4 ?
- Untitled.png (7.59 KiB) Viewed 7861 times
Re: What is the purpose of VDD3P3_RTC pin in ESP32-PICO-D4 ?
Unfortunately, what you want is not possible on the current ESP32 design as the RTC voltage rail powers other bits of the chip as well.
Opposite question. Can I keep VDD3P3_RTC not connected?
If I dont use RealTime schematic with timer quartz 32768
Stay its float
Stay its float
No. It powers a chip domain that is needed for normal use.
