ESP-IDF include additional paths
my first ESP32 project develops and of course I want to organize the headers and sources in a structured way.
However, if I create a new folder in the workspace and add it as include path(eclipse), the make process cant find it.
I use the latest version (cloned today) of ESP-IDF on windows with eclipse.
My naive approach was to add the include path inside of eclipse, but I am afraid this information is not passed to make.
Could someone please give instruction on how to add additional header/source folders.
Sorry if this is a duplicate post, I could not find any information about it in the forum or online. (Mainly because the keywords are used very often...)
my page: http://www.barth-dev.de/
Re: ESP-IDF include additional paths
Howdy,
Here is a video called "ESP32: Integration with Eclipse"....
https://www.youtube.com/watch?v=bYh2w0HzS7s
Have a look at this and see if it answers the question. It it doesn't please post back.
From a high level ... the way I think about it ...
The ESP-IDF make system uses "component.mk" files to specify which directories each component provides (if any) include files.
The Eclipse environment "drives" the Makefile provided with ESP-IDF and hence doesn't "actually" have to know where the include files reside in order for a build to complete successfully. However, for entry assist and for the Eclipse editors, we can go further and "tell" the Eclipse project which folders to search for include files ... for the purpose of clean editing.
In addition to kolban's answer, you can find the documentation of "component.mk" contents here:
EDIT: updated the link to the new location
https://docs.espressif.com/projects/esp ... -variables
You can use either COMPONENT_ADD_INCLUDEDIRS or COMPONENT_PRIV_INCLUDEDIRS (depending if the headers are "public" or "private") to tell the esp-idf 'make' system where to find headers.
Angus
Angus
COMPONENT_ADD_INCLUDEDIRS and COMPONENT_SRCDIRS work fine.
Thanks!
kolban, you are right. Eclipse is simply a convenient editor, which has to know the include paths in order to ease editing. However, from GCC I know that additional eclipse include dirs are passed in the CLI. I thought that the make script maybe is getting this information too. But to be honest, I do not know very much about make
Thanks!
I have a question with the project organization that i want to resolve. I want to organize my project with another name folders. Could someone say how to change the name of the main folder? I have this folders:
- .git
- build
- main (i want to name it src)
thx
- .git
- build
thx
Howdy,
In your ESP-IDF project you will find a Makefile. This is in the same folder as "main".
You can name the sub directories that are going to contain source to be compiled by adding the variable SRCDIRS into the Makefile. If you don't supply it, the implicit default is "main".
For example, you can add the following:
SRCDIRS := src
which will result in the application being compiled with the content of a directory called "src" rather than main.
SRCDIRS := src
I've been able to organize my project with multiple directories in the 'main' directory. I would like to add subdirectories to some of those directories.
In my main directory, I have a component.mk file with the following:
COMPONENT_SRCDIRS := . dir_1 dir_2 dir_3
If I try adding dir_3/dir_3_a, I get the following error:
->main
->dir_1
->dir_2
->dir_3
->dir_3_a
->dir_3_b
->dir_3_b_1
/path/to/project/main/dir_3/dir_3_a/file.c fatal error: opening dependency file dir_3/dir_3_a/file.d: No such file or directory
I am using mingw on windows 10 installed under : c:\msys32
My project is under different folder.
c:\Work. It refer to my own libraries path.
COMPONENT_ADD_INCLUDEDIRS = ../LibDev/
works instead of
COMPONENT_EXTRA_INCLUDES := ../LibDev/
c:Work\LibDev\test.h
but linker not finding method to link with test.cpp
Thanks,
Naeem
works instead of
Thanks,
Naeem
We might need some more information from you to assist. Include directories are where the compiler looks for header files (.h files) that contain declarations of data and functions. These are used during compilation. At the conclusion of compilation you have object files and libraries. These then are linked together to form your application.
This thread talks about how the compiled looks for header files to compile source code. At the end of your last post, you mentioned there was a problem with "linking" and not with "compilation". The include paths (for headers) aren't related to the linkage steps. Perhaps if you describes your thought process and what you are actually observing we could provide better guidance?
Yes you are right. My issue is now linking with my own static library.
My project is under this folder.
C:\Work\Actisense\http_server2
C:\Work\Actisense\http_server2\main\component.mk
content
COMPONENT_ADD_LDFLAGS=-lstdc++ -l$(COMPONENT_NAME)
COMPONENT_ADD_INCLUDEDIRS := . ../../../LibDev/
I can compile it but not linking to static lib ray contains test.cpp
but when I It include test.h
C:\Work\LibDev\CommonLib\test.h
C:\Work\LibDev\CommonLib\test.cpp
C:\Work\LibDev\CommonLib\component.mk
Content of file=component.mk are
#CXXFLAGS+=-fexceptions
#CXXFLAGS+= -std=c++11
COMPONENT_ADD_INCLUDEDIRS := CommonLib
COMPONENT_SRCDIRS := CommonLib
COMPONENT_SUBMODULES := CommonLib
IDF_PATH = C:/msys32/home/naeem/esp/esp-idf
Current Mingw installation folder.
C:\msys32
Error:
LD build/app-template.elf
C:/Work/Actisense/http_server2/build/main\libmain.a(main.o):(.literal.app_main+0x18): undefined reference to `test::execute()'
C:/Work/Actisense/http_server2/build/main\libmain.a(main.o): In function `app_main':
C:/work/Actisense/http_server2/main/main.cpp:95: undefined reference to `test::execute()'
make: *** [C:/msys32/home/naeem/esp/esp-idf/make/project.mk:389: /c/Work/Actisense/http_server2/build/app-template.elf] Error 1
It is not generating libCommonLib.a file
Kindly help me please.
However If i put CommonLib under C:\msys32\home\naeem\esp\esp-idf\components it links. it generate libCommonLib.a file.
content
C:\msys32
Error:
Users browsing this forum: Bing [Bot] and 195 guests
