BNO055 I2C operation problem
maksyuki
Postby maksyuki » Wed Mar 13, 2019 12:22 pm
Hi, I recently use the sensor BNO055 and cannot read right data from it by using I2C driver of esp32-idf(version:3.1.3). But when I use the Adafruit BNO055 example(arduino 3rd party library provide) and arduino-esp32 library to compile and flash the program by using Arduino IDE, the right data can be read. The hardware and circuit connection is same, so I think the hardware have no problem. I read the BNO055's datasheet and I find it support I2C clock stretching operation. To find the error, I write the test codes which read the BNO055 device chip id using arduino-esp32 library and esp32-idf(version:3.13) respectively. First, the right read timing sequence by using arduino-esp32 library is as shown below:
Second, the I2C config code using esp32-idf(version:3.1.3) is as shown below:
    i2c_config_t conf;
    conf.mode             = I2C_MODE_MASTER;
    conf.sda_io_num       = sda_pin; //sda_pin is 21
    conf.sda_pullup_en    = GPIO_PULLUP_ENABLE;
    conf.scl_io_num       = scl_pin; //scl_pin is 22
    conf.scl_pullup_en    = GPIO_PULLUP_ENABLE;
    conf.master.clk_speed = clk_frq; //clk_frq is 100000
    i2c_param_config(i2c_port, &conf); //i2c_port=I2C_NUM_1
    i2c_driver_install(i2c_port, conf.mode, I2C_NUM1_MASTER_RX_BUF_DISABLE, I2C_NUM1_MASTER_TX_BUF_DISABLE, 0); //i2c_port=I2C_NUM_1
the I2C read BNO055 CHIP ID register code is as shown below:
    int32_t ret_test = 0;
    uint8_t BNO055_ADDR = 0x28;
    uint8_t BNO055_CHIP_ID = 0x00;
    uint8_t tmp_data = 0x00;
    i2c_cmd_handle_t cmd = i2c_cmd_link_create();
    i2c_master_start(cmd);
    i2c_master_write_byte(cmd, BNO055_ADDR << 1, MASTER_EN_CHECK_ACK); //MASTER_EN_CHECK_ACK=1
    i2c_master_write_byte(cmd, BNO055_CHIP_ID, MASTER_EN_CHECK_ACK); //MASTER_EN_CHECK_ACK=1
    i2c_master_stop(cmd);
    ret_test = i2c_master_cmd_begin(I2C_NUM1_MASTER_PORT_GPIO, cmd, 1000 / portTICK_RATE_MS); //I2C_NUM1_MASTER_PORT_GPIO=I2C_NUM_1
    i2c_master_write_byte(cmd, (BNO055_ADDR<<1) + 1, MASTER_EN_CHECK_ACK); //MASTER_EN_CHECK_ACK=1
    i2c_master_read_byte(cmd, &tmp_data, 0x01);
    i2c_cmd_link_delete(cmd);
    if(ret_test == ESP_OK)
        printf("the BNO055 id is %#X\n", tmp_data);
    else
        printf("the BNO055 timeout!!!\n");
the error read timing sequence by using esp32-idf(version:3.13) is as shown below:
I find the error timing sequence doesn't write the register address after the completion of writing device address. But I don't know what can lead to this error. Please give me some advice if someone have some success over this. Thanks.
Users browsing this forum: No registered users and 14 guests
