Control 5V relay with ESP32 DEVKITC
Nikosant03
Postby Nikosant03 » Sat Mar 16, 2019 3:56 pm
Dear all,
I've got an ESP32 Devkitc and I need to control a 5V relay through a GPIO pin.
I will supply 5V (using a battery and dc/dc converter) into the 5v pin of ESP32. The GPIO outputs is going to be 5V OR 3.3V?
In general is it possible to control a 5V relay with ESP32?
Thanks is advance
chegewara
Re: Control 5V relay with ESP32 DEVKITC
Postby chegewara » Sun Mar 17, 2019 5:42 am
It's not possible but you can use simple logic level shifter.
Deouss
Postby Deouss » Sun Mar 17, 2019 5:36 pm
Depends what relay. I was able to control 5V relay with multiplexer without any problems.
Also adding 3V optocoupler will allow such control
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 1 guest
