How to show compile information
mikemoy
Postby mikemoy » Sat Mar 16, 2019 10:11 pm
Might someone know how I can get more information when I compile like this?
Annotation 2019-03-16 014325.jpg (24.52 KiB) Viewed 1777 times
mikemoy
Re: How to show compile information
Postby mikemoy » Sat Mar 16, 2019 10:52 pm
I found something close enough. using "make size" does it.
ESP_Angus
Postby ESP_Angus » Mon Mar 18, 2019 1:21 am
For more granular information of this kind there is also "make size-components" and "make size-files". https://docs.espressif.com/projects/esp ... ke-targets
mikemoy
Postby mikemoy » Mon Mar 18, 2019 3:52 pm
When using make size you get the following:
I'm just curious, why doesn't it show percentages for the others?
Annotation 2019-03-18 104949.jpg (39.97 KiB) Viewed 1677 times
ESP_Angus
Postby ESP_Angus » Mon Mar 18, 2019 10:23 pm
The "static DRAM" number is data+bss, as these both take up the same memory region. "static DRAM" is probably equivalent to the "DATA RAM" number in the screenshot you posted from another build system.
We don't give any % for flash-resident data because the tool which calculates sizes doesn't know what partition table is in use, so it doesn't know how much space is available for the app partition.
Maybe partition-awareness is something we could add in the future, but we also don't want to give the impression that this size is fixed (as the partition table can be edited to allow a bigger app).
mikemoy
Postby mikemoy » Tue Mar 19, 2019 1:23 am
Thank you for the great explanation. Maybe for a future use we could pass the flash size like 4MB 8MB and so on.
Users browsing this forum: Bing [Bot], ESP_ulipe, Google [Bot] and 19 guests
