I cloned the current IDF and made some tests saving the logs and the current client settings:
I also tried turning off the firewall of my ISR and Ubuntu, no success.
Running the python script from another machine works too.
If the generated .pem file was not appropriate, would a transmission error occur?
TEST_1______________________________________________________________________________________OK
Connect to global broker (SSL example project)
Client log:
D (8135) MQTT_CLIENT: MQTT client_id=ESP32_d5FE19
D (8145) MQTT_CLIENT: Core selection disabled
D (9485) MQTT_CLIENT: Transport connected to mqtts://iot.eclipse.org:8883
I (9485) MQTT_CLIENT: Sending MQTT CONNECT message, type: 1, id: 0000
D (9635) MQTT_CLIENT: Connected
I (9635) MQTTS_EXAMPLE: MQTT_EVENT_CONNECTED
D (9635) MQTT_CLIENT: mqtt_enqueue id: 0, type=1 successful
D (9635) MQTT_CLIENT: Sent subscribe topic=/topic/qos0, id: 52190, type=8 successful
I (9645) MQTTS_EXAMPLE: sent subscribe successful, msg_id=52190
D (9655) MQTT_CLIENT: mqtt_enqueue id: 52190, type=8 successful
D (9655) OUTBOX: ENQUEUE msgid=52190, msg_type=8, len=18, size=18
D (9665) MQTT_CLIENT: Sent subscribe topic=/topic/qos1, id: 35928, type=8 successful
I (9675) MQTTS_EXAMPLE: sent subscribe successful, msg_id=35928
D (9675) MQTT_CLIENT: mqtt_enqueue id: 35928, type=8 successful
D (9685) OUTBOX: ENQUEUE msgid=35928, msg_type=8, len=18, size=36
D (9695) MQTT_CLIENT: unsubscribe, topic"/topic/qos1", id: 6477
D (9695) MQTT_CLIENT: Sent Unsubscribe topic=/topic/qos1, id: 6477, successful
I (9705) MQTTS_EXAMPLE: sent unsubscribe successful, msg_id=6477
D (9785) MQTT_CLIENT: msg_type=9, msg_id=52190
D (9785) MQTT_CLIENT: pending_id=6477, pending_msg_count = 3
D (9785) OUTBOX: DELETED msgid=52190, msg_type=8, remain size=18
D (9795) MQTT_CLIENT: Subscribe successful
I (9795) MQTTS_EXAMPLE: MQTT_EVENT_SUBSCRIBED, msg_id=52190
I (9805) MQTTS_EXAMPLE: sent publish successful, msg_id=0
D (9925) MQTT_CLIENT: msg_type=9, msg_id=35928
D (9935) MQTT_CLIENT: pending_id=6477, pending_msg_count = 2
D (9935) OUTBOX: DELETED msgid=35928, msg_type=8, remain size=0
D (9935) MQTT_CLIENT: Subscribe successful
I (9935) MQTTS_EXAMPLE: MQTT_EVENT_SUBSCRIBED, msg_id=35928
I (9945) MQTTS_EXAMPLE: sent publish successful, msg_id=0
D (10075) MQTT_CLIENT: msg_type=11, msg_id=6477
D (10075) MQTT_CLIENT: pending_id=6477, pending_msg_count = 1
D (10075) MQTT_CLIENT: UnSubscribe successful
I (10075) MQTTS_EXAMPLE: MQTT_EVENT_UNSUBSCRIBED, msg_id=6477
D (10215) MQTT_CLIENT: msg_type=3, msg_id=0
I (10215) MQTT_CLIENT: deliver_publish, message_length_read=19, message_length=19
D (10215) MQTT_CLIENT: Get data len= 4, topic len=11
I (10225) MQTTS_EXAMPLE: MQTT_EVENT_DATA
TOPIC=/topic/qos0
DATA=data
D (10425) MQTT_CLIENT: msg_type=3, msg_id=0
I (10425) MQTT_CLIENT: deliver_publish, message_length_read=19, message_length=19
D (10425) MQTT_CLIENT: Get data len= 4, topic len=11
I (10435) MQTTS_EXAMPLE: MQTT_EVENT_DATA
TOPIC=/topic/qos0
DATA=data
TEST_2____________________________________________________________________________________NOPE
Client config changes:
- .uri = CONFIG_BROKER_URI,
+ //.uri = CONFIG_BROKER_URI,
+ .uri = "mqtts://192.168.1.11:8883",
Using the original .pem file.
Mosquitto:
1553162287: New connection from 192.168.1.115 on port 8883.
1553162287: OpenSSL Error: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca
1553162287: Socket error on client <unknown>, disconnecting.
Client log:
I (8165) event: sta ip: 192.168.1.115, mask: 255.255.255.0, gw: 192.168.1.2
I (8165) MQTTS_EXAMPLE: [APP] Free memory: 236656 bytes
I (8165) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
D (8175) MQTT_CLIENT: MQTT client_id=ESP32_d5FE19
D (8185) MQTT_CLIENT: Core selection disabled
E (8315) TRANS_SSL: mbedtls_ssl_handshake returned -0x2700
E (8325) MQTT_CLIENT: Error transport connect
I (8325) MQTT_CLIENT: Reconnect after 10000 ms
I (8325) MQTTS_EXAMPLE: MQTT_EVENT_DISCONNECTED
D (18335) MQTT_CLIENT: Reconnecting...
TEST_2.1___________________________________________________________________________________NOPE
Using a generated .pem file (Steves's guide)
Mosquitto:
1553163090: New connection from 192.168.1.115 on port 8883.
1553163091: New client connected from 192.168.1.115 as ESP32_d5FE19 (c1, k120).
1553163091: Sending CONNACK to ESP32_d5FE19 (0, 0)
1553163091: Socket error on client ESP32_d5FE19, disconnecting.
Client log:
I (4656) event: sta ip: 192.168.1.115, mask: 255.255.255.0, gw: 192.168.1.2
I (4656) MQTTS_EXAMPLE: [APP] Free memory: 236660 bytes
I (4656) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
D (4666) MQTT_CLIENT: MQTT client_id=ESP32_d5FE19
D (4676) MQTT_CLIENT: Core selection disabled
D (5536) MQTT_CLIENT: Transport connected to mqtts://192.168.1.11:8883
I (5546) MQTT_CLIENT: Sending MQTT CONNECT message, type: 1, id: 0000
E (5556) MQTT_CLIENT: Invalid MSG_TYPE response: 0, read_len: 16
I (5556) MQTT_CLIENT: Error MQTT Connected
I (5576) MQTT_CLIENT: Reconnect after 10000 ms
I (5576) MQTTS_EXAMPLE: MQTT_EVENT_DISCONNECTED
I (5596) wifi: pm start, type:0
D (20576) MQTT_CLIENT: Reconnecting...
TEST_3______________________________________________________________________________________OK
Python script.
Mosquitto:
1553169896: New connection from 192.168.1.11 on port 8883.
1553169896: New client connected from 192.168.1.11 as controll (c1, k60).
1553169896: Sending CONNACK to controll (0, 0)
1553169900: Received PUBLISH from controll (d0, q0, r0, m0, 'movies/pulp_fiction', ... (72 bytes))
1553169904: Received DISCONNECT from controll
1553169904: Client controll disconnected.
Python client log:
('buffer ', 'Sending CONNECT (u0, p0, wr0, wq0, wf0, c1, k60) client_id=controll')
('waiting', False)
('buffer ', 'Received CONNACK (0, 0)')
('connected', True)
publishing
('buffer ', "Sending PUBLISH (d0, q0, r0, m1), 'movies/pulp_fiction', ... (72 bytes)")
('buffer ', 'Sending DISCONNECT')
TEST_4____________________________________________________________________________________NOPE
Skipping the certification.
Client config:
.event_handle = mqtt_event_handler,
- .cert_pem = (const char *)iot_eclipse_org_pem_start,
+ //.cert_pem = (const char *)iot_eclipse_org_pem_start,
Mosquitto:
1553163659: New connection from 192.168.1.115 on port 8883.
1553163660: New client connected from 192.168.1.115 as ESP32_d5FE19 (c1, k120).
1553163660: Sending CONNACK to ESP32_d5FE19 (0, 0)
1553163660: Socket error on client ESP32_d5FE19, disconnecting.
Client log:
I (4633) event: sta ip: 192.168.1.115, mask: 255.255.255.0, gw: 192.168.1.2
I (4633) MQTTS_EXAMPLE: [APP] Free memory: 236480 bytes
I (4633) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
D (4643) MQTT_CLIENT: MQTT client_id=ESP32_d5FE19
D (4643) MQTT_CLIENT: Core selection disabled
D (5433) MQTT_CLIENT: Transport connected to mqtts://192.168.1.11:8883
I (5433) MQTT_CLIENT: Sending MQTT CONNECT message, type: 1, id: 0000
E (5443) MQTT_CLIENT: Invalid MSG_TYPE response: 0, read_len: 16
I (5443) MQTT_CLIENT: Error MQTT Connected
I (5463) MQTT_CLIENT: Reconnect after 10000 ms
Code: Untitled.py Select all
import paho.mqtt.client as paho
import time
broker="192.168.1.11"
port=8883
conn_flag = False
def on_connect(client, userdata, flags, rc):
global conn_flag
conn_flag = True
print("connected",conn_flag)
conn_flag = True
def on_log(client, userdata, level, buf):
print("buffer ",buf)
def on_disconnect(client, userdata, rc):
print("client disconnected ok")
client1 = paho.Client("controll")
client1.on_log = on_log
client1.tls_set('ca.crt')
client1.on_connect = on_connect
client1.on_disconnect = on_disconnect
client1.connect(broker,port)
while not conn_flag:
time.sleep(1)
print("waiting",conn_flag)
client1.loop()
time.sleep(3)
print("publishing")
client1.publish("movies/pulp_fiction","and you will know my name is the Lord when I lay my vengeance upon thee.")
time.sleep(2)
client1.loop()
time.sleep(2)
client1.disconnect()
