HTTP server in SoftAp mode with IP configuration [ESP-IDF]
karlo.verde.13
Contact:
Postby karlo.verde.13 » Mon Mar 18, 2019 10:02 pm
Hey there!
This is an example of HTTP server in AP mode.
NOTES
  • Some header files are unnecessary.
  • This example also includes IP configuration.
  • The URI handler has minimal code in this example but you can define it as you wish.
  • If you have an Android device, I recommend that you use this app: https://play.google.com/store/apps/deta ... tprequests.
Code: Untitled.c Select all
#include "string.h"
#include "freertos/task.h"
#include "esp_wifi.h"
#include "esp_system.h"
#include "esp_event.h"
#include "esp_event_loop.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_http_server.h"
#define SOFT_AP_SSID "ESP32 SoftAP"
#define SOFT_AP_PASSWORD "Password"
#define SOFT_AP_IP_ADDRESS_1 192
#define SOFT_AP_IP_ADDRESS_2 168
#define SOFT_AP_IP_ADDRESS_3 5
#define SOFT_AP_IP_ADDRESS_4 18
#define SOFT_AP_GW_ADDRESS_1 192
#define SOFT_AP_GW_ADDRESS_2 168
#define SOFT_AP_GW_ADDRESS_3 5
#define SOFT_AP_GW_ADDRESS_4 20
#define SOFT_AP_NM_ADDRESS_1 255
#define SOFT_AP_NM_ADDRESS_2 255
#define SOFT_AP_NM_ADDRESS_3 255
#define SOFT_AP_NM_ADDRESS_4 0
#define SERVER_PORT 3500
#define HTTP_METHOD HTTP_POST
#define URI_STRING "/test"
static httpd_handle_t httpServerInstance = NULL;
static esp_err_t methodHandler(httpd_req_t* httpRequest){
ESP_LOGI("HANDLER","This is the handler for the <%s> URI", httpRequest->uri);
return ESP_OK;
static httpd_uri_t testUri = {
.uri = URI_STRING,
.method = HTTP_METHOD,
.handler = methodHandler,
.user_ctx = NULL,
static void startHttpServer(void){
httpd_config_t httpServerConfiguration = HTTPD_DEFAULT_CONFIG();
httpServerConfiguration.server_port = SERVER_PORT;
if(httpd_start(&httpServerInstance, &httpServerConfiguration) == ESP_OK){
ESP_ERROR_CHECK(httpd_register_uri_handler(httpServerInstance, &testUri));
static void stopHttpServer(void){
if(httpServerInstance != NULL){
ESP_ERROR_CHECK(httpd_stop(httpServerInstance));
static esp_err_t wifiEventHandler(void* userParameter, system_event_t *event) {
switch(event->event_id){
case SYSTEM_EVENT_AP_STACONNECTED:
startHttpServer();
case SYSTEM_EVENT_AP_STADISCONNECTED:
stopHttpServer();
default:
return ESP_OK;
static void launchSoftAp(){
ESP_ERROR_CHECK(nvs_flash_init());
tcpip_adapter_init();
ESP_ERROR_CHECK(tcpip_adapter_dhcps_stop(TCPIP_ADAPTER_IF_AP));
tcpip_adapter_ip_info_t ipAddressInfo;
memset(&ipAddressInfo, 0, sizeof(ipAddressInfo));
IP4_ADDR(
&ipAddressInfo.ip,
SOFT_AP_IP_ADDRESS_1,
SOFT_AP_IP_ADDRESS_2,
SOFT_AP_IP_ADDRESS_3,
SOFT_AP_IP_ADDRESS_4);
IP4_ADDR(
&ipAddressInfo.gw,
SOFT_AP_GW_ADDRESS_1,
SOFT_AP_GW_ADDRESS_2,
SOFT_AP_GW_ADDRESS_3,
SOFT_AP_GW_ADDRESS_4);
IP4_ADDR(
&ipAddressInfo.netmask,
SOFT_AP_NM_ADDRESS_1,
SOFT_AP_NM_ADDRESS_2,
SOFT_AP_NM_ADDRESS_3,
SOFT_AP_NM_ADDRESS_4);
ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP, &ipAddressInfo));
ESP_ERROR_CHECK(tcpip_adapter_dhcps_start(TCPIP_ADAPTER_IF_AP));
ESP_ERROR_CHECK(esp_event_loop_init(wifiEventHandler, NULL));
wifi_init_config_t wifiConfiguration = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&wifiConfiguration));
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
wifi_config_t apConfiguration = {
.ap = {
.ssid = SOFT_AP_SSID,
.password = SOFT_AP_PASSWORD,
.ssid_len = 0,
//.channel = default,
.authmode = WIFI_AUTH_WPA2_PSK,
.ssid_hidden = 0,
.max_connection = 1,
.beacon_interval = 150,
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &apConfiguration));
ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
ESP_ERROR_CHECK(esp_wifi_start());
void app_main(void){
launchSoftAp();
while(1) vTaskDelay(10);
Hope it helps
Best regards
Verde :mrgreen:
