A specific question and then a general one.
I have an ISR that is triggered from a GPIO interrupt when a button is pressed. My plan is to check for button debounce by discarding interrupts that happen too close together. So for example, a button pressed interrupt will not cause action if it occurs less than 100 msecs since the last button pressed. The question I am considering in my design then seems to ask "Can I determine the current time stamp within an ISR?" and that leads me to "gettimeofday()" ... is that a "safe" call to use in an ISR?
Following on from this question then leads me to the next semi obvious question ... which ESP-IDF supplied functions are or are not safe to be invoked from within an ISR? Do we have a table or mapping of which ones can and can't be used?
Is gettimeofday() safe from an ISR perspective?
Users browsing this forum: Applebot, Baidu [Spider], ChatGPT-User and 1 guest
