RS232 UART Acceptable Voltage for ESP32
DanMars
Postby DanMars » Fri Mar 29, 2019 7:02 pm
Hi All,
I have a project to have an ESP32 talk to a RS232 device. The device is powered by 12 volts, and the RS232 specs indicate the voltage can be as high as +-15v. I assume I cannot wire the TX/RX wires directly into the ESP32 pins for the chosen UART as 12V will probably fry the ESP32. Or will it? What's the best practice for this? Perhaps there is a level shift chip that works for 12v to 3.3v?
Thank you for any insight.
Dan
Re: RS232 UART Acceptable Voltage for ESP32
Postby Sprite » Sat Mar 30, 2019 7:21 am
The GPIOs of the ESP32 indeed won't be happy if you stick 12V on them. The more-or-less canonical solution for this would be a MAX3232 or equivalent, fed off the same 3.3V the ESP32 is powered by.
DanMars
Postby DanMars » Sat Mar 30, 2019 8:23 pm
Thank you for your help. I will look into those options.
Dan
shyney
Postby shyney » Mon Jul 24, 2023 8:01 am
Dan
Did you find a solution for this? The Datasheet of the MAX3232 Chip says:
Accepts 5-V logic input with 3.3-V supply
so I guess 12v logic from the RS232 Device is not acceptable...
Postby Sprite » Tue Jul 25, 2023 1:16 am
You wouldn't apply the 12V RS232 signal to the logic inputs, you would connect them to the RS232 line data inputs, and those do accept 12V.
