Choose language/locale for esp32-based hid keyboard?
gargolev
Postby gargolev » Sat Mar 30, 2019 10:13 pm
My board:
https://www.aliexpress.com/item/ESP32-E ... 96371.html
My code:
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
#include "BLE2902.h"
#include "BLEHIDDevice.h"
#include "HIDTypes.h"
#include "HIDKeyboardTypes.h"
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
const uint8_t keyboardHidDescriptor[] = {
  0x05, 0x0c,                    // USAGE_PAGE (Consumer Devices)
  0x09, 0x01,                    // USAGE (Consumer Control)
  0xa1, 0x01,                    // COLLECTION (Application)
  0x85, 0x01,                    //   REPORT_ID (1)
  0x19, 0x00,                    //   USAGE_MINIMUM (Unassigned)
  0x2a, 0x3c, 0x02,              //   USAGE_MAXIMUM (AC Format)
  0x15, 0x00,                    //   LOGICAL_MINIMUM (0)
  0x26, 0x3c, 0x02,              //   LOGICAL_MAXIMUM (572)
  0x95, 0x01,                    //   REPORT_COUNT (1)
  0x75, 0x10,                    //   REPORT_SIZE (16)
  0x81, 0x00,                    //   INPUT (Data,Var,Abs)
  0xc0,                          // END_COLLECTION
  0x05, 0x01,                    // USAGE_PAGE (Generic Desktop)
  0x09, 0x06,                    // USAGE (Keyboard)
  0x85, 0x02,                    //   REPORT_ID (2)
  0x05, 0x07,                    //   USAGE_PAGE (Keyboard)
  0x19, 0xe0,                    //   USAGE_MINIMUM (Keyboard LeftControl)
  0x29, 0xe7,                    //   USAGE_MAXIMUM (Keyboard Right GUI)
  0x25, 0x01,                    //   LOGICAL_MAXIMUM (1)
  0x75, 0x01,                    //   REPORT_SIZE (1)
  0x95, 0x08,                    //   REPORT_COUNT (8)
  0x81, 0x02,                    //   INPUT (Data,Var,Abs)
  0x75, 0x08,                    //   REPORT_SIZE (8)
  0x25, 0x65,                    //   LOGICAL_MAXIMUM (101)
  0x19, 0x00,                    //   USAGE_MINIMUM (Reserved (no event indicated))
  0x29, 0x65,                    //   USAGE_MAXIMUM (Keyboard Application)
  0x81, 0x00,                    //   INPUT (Data,Ary,Abs)
  0xc0                           // END_COLLECTION
typedef struct
 //uint8_t  reportId;                                 // Report ID = 0x02 (2)
  // Collection: CA:ConsumerControl
  uint16_t ConsumerControl;                          // Value = 0 to 572
} inputConsumer_t;
static uint8_t idleRate;           /* in 4 ms units */
typedef struct
// uint8_t  reportId;                                 // Report ID = 0x02 (2)
  // Collection: CA:Keyboard
  uint8_t  KB_KeyboardKeyboardLeftControl  : 1;       // Usage 0x000700E0: Keyboard Left Control, Value = 0 to 1
  uint8_t  KB_KeyboardKeyboardLeftShift  : 1;         // Usage 0x000700E1: Keyboard Left Shift, Value = 0 to 1
  uint8_t  KB_KeyboardKeyboardLeftAlt    : 1;           // Usage 0x000700E2: Keyboard Left Alt, Value = 0 to 1
  uint8_t  KB_KeyboardKeyboardLeftGui    : 1;           // Usage 0x000700E3: Keyboard Left GUI, Value = 0 to 1
  uint8_t  KB_KeyboardKeyboardRightControl : 1;      // Usage 0x000700E4: Keyboard Right Control, Value = 0 to 1
  uint8_t  KB_KeyboardKeyboardRightShift   : 1;        // Usage 0x000700E5: Keyboard Right Shift, Value = 0 to 1
  uint8_t  KB_KeyboardKeyboardRightAlt   : 1;          // Usage 0x000700E6: Keyboard Right Alt, Value = 0 to 1
  uint8_t  KB_KeyboardKeyboardRightGui   : 1;          // Usage 0x000700E7: Keyboard Right GUI, Value = 0 to 1
  uint8_t  Key;                                 // Value = 0 to 101
} inputKeyboard_t;
static inputConsumer_t consumer_Report{};
static inputKeyboard_t keyboard_report{}; // sent to PC
BLEHIDDevice* hid;
BLECharacteristic* input;
BLECharacteristic* output;
BLECharacteristic* inputVolume;
BLECharacteristic* outputVolume;
bool connected = false;
class MyCallbacks : public BLEServerCallbacks {
  void onConnect(BLEServer* pServer){
    connected = true;
    BLE2902* desc = (BLE2902*)input->getDescriptorByUUID(BLEUUID((uint16_t)0x2902));
    desc->setNotifications(true);
    BLE2902* descv = (BLE2902*)inputVolume->getDescriptorByUUID(BLEUUID((uint16_t)0x2902));
    descv->setNotifications(true);
  void onDisconnect(BLEServer* pServer){
    connected = false;
    desc->setNotifications(false);
    descv->setNotifications(false);
  const int ledPin = A12;
void taskServer(void*){
  BLEDevice::init("ESP32");
  BLEServer *pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyCallbacks());
  hid = new BLEHIDDevice(pServer);
  inputVolume = hid->inputReport(1); // <-- input REPORTID from report map
  outputVolume = hid->outputReport(1); // <-- output REPORTID from report map
  input = hid->inputReport(2); // <-- input REPORTID from report map
  output = hid->outputReport(2); // <-- output REPORTID from report map
  std::string name = "ElectronicCats";
  hid->manufacturer()->setValue(name);
  hid->pnp(0x02, 0xe502, 0xa111, 0x0210);
  hid->hidInfo(0x00,0x02);
  hid->reportMap((uint8_t*)keyboardHidDescriptor, sizeof(keyboardHidDescriptor));
  hid->startServices();
  BLESecurity *pSecurity = new BLESecurity();
//  pSecurity->setKeySize();
  pSecurity->setAuthenticationMode(ESP_LE_AUTH_BOND);
  BLEAdvertising *pAdvertising = pServer->getAdvertising();
  pAdvertising->setAppearance(HID_KEYBOARD);
  pAdvertising->addServiceUUID(hid->hidService()->getUUID());
  pAdvertising->start();
  hid->setBatteryLevel(7);
  delay(portMAX_DELAY);
  Serial.println("Starting BLE work!");
  pinMode(ledPin, OUTPUT);
//  keyboard_report.reportId = 0x02;
  //consumer_Report.reportId = 0x01;
  xTaskCreate(taskServer, "server", 20000, NULL, 5, NULL);
int writtenCount = 0;
//  delay(4000);
//if(connected){
//    const char* hello = "Hello world from esp32 hid keyboard!!!\n";
//    while(*hello){
//      KEYMAP map = keymap[(uint8_t)*hello];
//      uint8_t msg[] = {map.modifier , 0x0, map.usage, 0x0,0x0,0x0,0x0,0x0};
//      input->setValue(msg,sizeof(msg));
//      input->notify();
//      hello++;
//      uint8_t msg1[] = {0x0, 0x0, 0x0, 0x0,0x0,0x0,0x0,0x0};
//      input->setValue(msg1,sizeof(msg1));
//      input->notify();
//      delay(10);
//  delay(50);
  if(connected && (writtenCount < 2)){
    writtenCount++;
    const char* hello = "Hello123";
    while(*hello){
      inputKeyboard_t a{};
      if (map.modifier == 2) {
        a.KB_KeyboardKeyboardLeftShift = 1;
      a.Key = map.usage;
      input->setValue((uint8_t*)&a,sizeof(a));
      input->notify();
      input->setValue((uint8_t*)(&keyboard_report), sizeof(keyboard_report));
      input->notify();
      hello++;
      delay(10);
//    inputKeyboard_t a{};
//    a.Key = 'a';//random(0x02,0x27);
//     input->setValue((uint8_t*)&a,sizeof(a));
//    input->notify();
//    input->setValue((uint8_t*)(&keyboard_report), sizeof(keyboard_report));
//    input->notify();
    delay(1000);
    digitalWrite(ledPin, LOW);
The main problem is "Hello" may be written with random language. ESP32 is connected to iOS via BLE and it is not possible to choose language for this board on device.
How to solve this issue?
Users browsing this forum: Google [Bot] and 2 guests
