I am programming the FOC control of a three-phase brushless motor using MCPWM. At that time, I want to perform processing in synchronization with the carrier frequency. Does anyone know how to implement carrier sync interrupts on the ESP32?
For example, the RP2040 (Raspberry Pi Pico) C / C ++ SDK provides the following functions.
pwm_set_irq_enabled (slice *, true);
irq_set_exclusive_handler (PWM_IRQ_WRAP, arbitrary function);
irq_set_enabled (PWM_IRQ_WRAP, true);
Thank you very much for your kind support.
Carrier synchronization interrupt method using MCPWM
fluxdesigner
lbernstone
Re: Carrier synchronization interrupt method using MCPWM
I think what you are talking about is over my head, but the documentation is at https://docs.espressif.com/projects/esp ... ynchronize
https://github.com/espressif/esp-idf/tr ... nc_example
fluxdesigner
Thank you for your reply.
I understood that what you taught me was "how to synchronize three PWMs to operate".
Certainly, this content is a very important point for FOC control with ESP32.
However, what I wanted to know this time was "a method of generating an interrupt in synchronization with a PWM carrier and operating an arbitrary function".
https://github.com/simplefoc/Arduino-FO ... 32_mcu.cpp
Fortunately, as a result of conducting a survey including the information of the link you gave me, I found that the following project embodies what I want to know.
The important point is the part that uses the "mcpwm_isr_register () function".
thank you for your cooperation.
Thank you very much.
