ESP32-C3 Datasheet Pulse Counter
afonsobordado
Postby afonsobordado » Sun Apr 03, 2022 4:50 pm
Hey,
Not sure if this is the correct way to get in touch about a documentation issue.
It looks like the datasheet for the ESP32-C3 (esp32-c3_datasheet_en.pdf) shows the ESP32-C3 as having a pulse counter module, in the block diagram on page 2. (Search for "Pulse Counter" in the PDF)
Everywhere else I've searched disagrees (Including this forum post https://www.esp32.com/viewtopic.php?t=26255), and mentions that there is no Pulse Counter on the C3, so it would be nice to get the documentation fixed.
Re: ESP32-C3 Datasheet Pulse Counter
Postby Sprite » Mon Apr 04, 2022 9:04 am
Thanks for reporting this. I think there's normally a link in the PDF where you can report an issue, but I've taken the liberty to file an internal ticket for you; we'll likely have this fixed in the next revision of the datasheet.
calvsg88
Postby calvsg88 » Wed Aug 10, 2022 12:11 pm
I'm not clear. Is there a pulse counter or not?
Postby Sprite » Thu Aug 11, 2022 12:50 am
There is no pulse counter in the ESP32C3. If you look at the diagram mentioned above in the current datasheet, the reference to the pulse counter has been removed.
