ESP32-C3 + LittleFs + USB serial/jtag issues
pataga
Postby pataga » Wed Aug 10, 2022 9:52 am
Hardware : ESP32-C3 AI thinker C3FN4 module with 4MB flash, using onboard USB serial/JTAG for flash and debug
Software development environment : VSC + PlatformIO + arduino framework
If I use older releases for the arduino framework e.g. 2.0.2 I get build errors for USB Serial, so 2.0.2 or earlier is not a solution.
If I user newer releases e.g. 2.0.3 I can build and flash successfully.
But with board_build.flash_mode = qio, I get boot loops.
With board_build.flash_mode = dio, I get a LittleFS mount error.
Based on this supposedly resolved issue, we need to specify flash_mode as qio
https://github.com/espressif/arduino-esp32/issues/6579
I tried specifying framework v2.0.3 in platformio.ini and this results in bootloops.
Based on this
viewtopic.php?p=85621 using qio results in bootloops so we need to specify dio
If I specify dio, the code boots but I get LittleFS mount errors.
platformio.ini
[env:esp32c3]
platform = https://github.com/tasmota/platform-espressif32/releases/download/v.2.0.3/platform-espressif32-v.2.0.3.zip
platform_packages =  framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.3
framework = arduino
board = esp32-c3-devkitm-1
board_build.partitions = partitions.csv
board_build.f_cpu = 80000000L
build_flags =
	-DARDUINO_USB_MODE=1
	-DARDUINO_USB_CDC_ON_BOOT
upload_speed = 460800
monitor_speed = 115200
upload_port = /dev/ttyACM1
monitor_port = /dev/ttyACM1
build_type = debug
monitor_filters = esp32_exception_decoder
extra_scripts = ./littlefsbuilder.py
partitions.csv
# Name,  Type, SubType, Offset,   Size,  Flags
# App partition x 2 : 1966080 bytes
ota_0,     app, ota_0,   0x10000,  0x1E0000,
ota_1,     app, ota_1,          ,  0x1E0000,
otadata,  data, ota,            ,  0x2000,
nvs,      data, nvs,            ,  0x6000,
# SPIFFS partition : 163840 bytes
spiffs,     data, spiffs,         ,  0x28000,
I also tried this example partitions file from the link above (apparently working for them with qio and 2.0.3), no difference
nvs,      data, nvs,     0x9000,  0x5000,
otadata,  data, ota,     0xe000,  0x2000,
app0,     app,  ota_0,   0x10000, 0x1D0000,
app1,     app,  ota_1,   0x1E0000, 0x1D0000,
spiffs,   data, spiffs,  0x3B0000, 0x50000,
I would appreciate any pointers on a working platformio.ini for an AI Thinker C3FN4 module that will resolve the boot loops and
LittleFS mounting errors while still supporting USB CDC on boot.
Thanks !
pataga
Re: ESP32-C3 + LittleFs + USB serial/jtag issues
Postby pataga » Wed Aug 10, 2022 1:00 pm
As per https://community.platformio.org/t/no-s ... in/29067/3
I also tried
platform = espressif32
platform_packages =
	framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git#2.0.3
With qio I get a couple of reboots and then a hang, with dio and dout I get a clean boot but LittleFS mount error
Attempting to boot anyway...
entry 0x403ce000
./components/esp_littlefs/src/littlefs/lfs.c:1071:error: Corrupted dir pair at {0x0, 0x1}
E (6338) esp_littlefs: mount failed,  (-84)
E (6338) esp_littlefs: Failed to initialize LittleFS
[  6126][E][LittleFS.cpp:94] begin(): Mounting LittleFS failed! Error: -1
Error mounting LittleFS, restarting...
pataga
Postby pataga » Sun Aug 14, 2022 5:03 am
Accidentally found a platform and packages specification that works :-)
Now LittleFS, Preferences and USB CDC on boot are working ...
Keeping my fingers crossed.
[env:esp32c3]
platform = https://github.com/platformio/platform-espressif32.git
platform_packages =
framework = arduino
board_build.filesystem = littlefs
build_flags =
upload_speed = 115200
build_type = debug
Grohlfer
Postby Grohlfer » Wed Dec 13, 2023 7:54 pm
Hi @pataga!
Could you please share the solution?
Thanks! :D
