A fatal error occurred: Packet content transfer stopped (received 8 bytes) on EPS32-S3 PCB.
MrT Stephens
Postby MrT Stephens » Sun Aug 21, 2022 12:36 pm
Hi Guys,
I'm just wondering if i could get some help. I have been working on an esp32-s3 e-paper smartwatch and I have got an issue when trying to upload the code. This is the error "A fatal error occurred: Packet content transfer stopped (received 8 bytes)". You can also see it in picture below. I have also attached the PDF schematic so that you can look at that.
This is also what i am using to upload the code in arduino ide.
Any help would be amazing. Thanks.
Screenshot 2022-08-21 133505.png (20.55 KiB) Viewed 29510 times
Watchy-MrT-ESP32-S3-V1.pdf
Schematic
(285.72 KiB) Downloaded 568 times
Re: A fatal error occurred: Packet content transfer stopped (received 8 bytes) on EPS32-S3 PCB.
Postby Sprite » Mon Aug 22, 2022 1:15 am
Does this also happen if you force the ESP32S3 into download mode, e.g. by holding BTN2 on powerup of the watch?
MrT Stephens
Postby MrT Stephens » Mon Aug 22, 2022 5:11 pm
MrT Stephens
Postby MrT Stephens » Tue Aug 23, 2022 1:16 pm
If i dont force the esp32-s3 into download mode it will just keep disconnecting from the computer and reconnecting. But once i do force the esp32-s3 into download mode it then stays connected to the computer and then when i try to upload the code that's the error i get.
Postby Sprite » Wed Aug 24, 2022 1:21 am
Hm, not sure then... possibly you can run esptool manually with the --trace option to show where it goes wrong?
MrT Stephens
Postby MrT Stephens » Wed Aug 24, 2022 11:51 am
Someone just mentioned to me in a discord that the flash mode that I am using is incorrect because they sent me this link "https://docs.espressif.com/projects/esp ... modes.html".
That says about in QIO flash communication mode this will use GPIO 9 and 10 for flash communications. But in the ESP32-S3 hardware reference design they do not do this. So have you got any idea on the flash communication mode I am using? Because this could maybe be the reason i am getting this error. Thanks for your help.
MrT Stephens
Postby MrT Stephens » Wed Aug 24, 2022 12:42 pm
Also just noticed if you look in screenshot below the SPIQ and SPID lines are the wrong way around when compared to this section in the esp32-s3 datasheet as seen in other pick below, which im guessing could also be the error. What do you think @ESP Sprite.
Screenshot 2022-08-24 134101.png (54.62 KiB) Viewed 29360 times
Screenshot 2022-08-24 134025.png (24.61 KiB) Viewed 29360 times
Jtlane
Postby Jtlane » Tue Jan 23, 2024 8:14 pm
Was this issue ever resolved? I am running into a very similar issue.
toddkrein
Postby toddkrein » Mon Jan 29, 2024 7:46 pm
This is still a problem. An interesting datapoint: I'm running the Arduino IDE on two different laptops. Same version of the IDE, same version of the board tools, same sketch. On one machine, it works reliably 100% of the time. On the other, it very rarely works, unless I do the copy/paste into a command window and add the --no-stub option.
Makes me wonder if it's a timing problem in the ESPY tool.
toddkrein
Postby toddkrein » Thu Feb 01, 2024 4:23 am
The bug is in the stub used to speed up the app download. I posted an arduino work-around at https://github.com/espressif/esptool/issues/836
Users browsing this forum: Baidu [Spider], ChatGPT-User and 1 guest
