Error create mqtt task
alitergee
Postby alitergee » Wed Aug 24, 2022 2:07 pm
I'm working on a project where mqtt_app is started on event IP_EVENT_STA_GOT_IP and mqtt app is stopped when WIFI_EVENT_STA_DISCONNECTED event occurs.
The general flow when
MQTT_CLIENT: Error create mqtt task
can be (mostly) seen is as follows -
1.ESP Bootup
2.WIFI_EVENT_STA_START
3.WIFI_EVENT_AP_START
4.WIFI_EVENT_STA_CONNECTED
5.IP_EVENT_STA_GOT_IP
6.MQTT app start
then after some time,
7.WIFI_EVENT_STA_DISCONNECTED
8.MQTT app stop
9.WIFI_EVENT_STA_CONNECTED
10.IP_EVENT_STA_GOT_IP
11. MQTT app start
but,
E (348564) MQTT_CLIENT: Error create mqtt task
E (348574) MQTT:
 FAILED TO START MQTT CLIENT -1
following error is faced. And therefore until software reset is done, mqtt won't connect.
mqtt app start function is as follows
void mqtt_app_start(char mac_id[])
    mqtt_events = xEventGroupCreate();
    mqtt_credential_read_nvs(); //++ function to read MQTT credential from NVS
    sprintf(mqtt_var.data_topic, "%s/data", mac_id);
    esp_mqtt_client_config_t mqtt_config = {
        .uri = mqtt_var.mqtt_url,
        .username = mqtt_var.mqtt_user,
        .password = mqtt_var.mqtt_pass,
        .keepalive = 60};
    client = esp_mqtt_client_init(&mqtt_config);
    /* The last argument may be used to pass data to the event handler, in this example mqtt_event_handler */
    esp_mqtt_client_register_event(client, ESP_EVENT_ANY_ID, mqtt_event_handler, client);
    esp_err_t mqtt_err = esp_mqtt_client_start(client);
    if (mqtt_err != ESP_OK)
        ESP_LOGE(TAG, "\n FAILED TO START MQTT CLIENT %d\n", mqtt_err);
        vTaskDelay(100/ portTICK_PERIOD_MS);
        esp_restart();
    else
        xEventGroupWaitBits(mqtt_events, MQTT_CONNECTED | MQTT_DISCONNECTED, pdTRUE, pdFALSE, pdMS_TO_TICKS(10000));
mqtt stop function is as follows
void mqtt_app_stop()
    ESP_LOGE(TAG, "\n\nxx -- STOPPING MQTT -- xx\n");
    mqtt_con_flag = false;
    mqtt_connected = false;
    esp_err_t mqtt_err = esp_mqtt_client_stop(client);
        ESP_LOGE(TAG, "\n FAILED TO STOP MQTT CLIENT %s\n", esp_err_to_name(mqtt_err));
    else
        if(HandleMqtt != NULL)
            vTaskDelete(HandleMqtt);
        // vTaskDelete(HandleMqtt); //creating problems in wifi reconnection
        xEventGroupSetBits(mqtt_events, MQTT_DISCONNECTED);
I'm new to ESP32 and ESP-IDF. May I know why is this happening?
Please help. Thank you.
chegewara
Re: Error create mqtt task
Postby chegewara » Wed Aug 24, 2022 5:05 pm
If you want to do it this way then you are missing one piece of puzzle:
esp_mqtt_client_destroy(client)
Users browsing this forum: Baidu [Spider], ESP_rrtandler, meta-externalagent, PetalBot and 4 guests
