Using IDF 4.4 and 5.0 in VC on Windows
I have some projects already developed on IDF 4.4, but now I have a new one and I want to use 5.0. Is there any way to use two different IDF versions with Visual Code extension?
Re: Using IDF 4.4 and 5.0 in VC on Windows
Yes, you want to use VSC portable.
https://code.visualstudio.com/docs/editor/portable
After you do this, and install Espressif's extension, Click on advanced and install the esp stuff to another location.
Using Espressif docker versions are much easier and cleaner.I have some projects already developed on IDF 4.4, but now I have a new one and I want to use 5.0. Is there any way to use two different IDF versions with Visual Code extension?
https://hub.docker.com/r/espressif/idf
And VS Code supports developing inside a container
https://code.visualstudio.com/docs/remote/containers
Users browsing this forum: ChatGPT-User, pdragun, Semrush [Bot] and 1 guest
