We are receiving the esp32 s2 WROVER module tuesday.
Awesome feature that you don't have to use the default uart, didn't though about that. Tested it and worked great!
ESP32 S2 FH4 First factory upload
Re: ESP32 S2 FH4 First factory upload
The ESP32 S2 WROVER Module works, It connects via USB and i can also program it via there.
I did find out that our current 12v power input was not as clean as we thought, but after connecting more capacitors it was fixed. We also tried this on the old chip to see if it was the power supply, but sadly it was not. For now we will just keep using the modules, they should work just as fine for us.
The other modules have all the same components to connect to the esp module right, like the mini if we want a smaller format module?
Users browsing this forum: Bing [Bot], Semrush [Bot] and 4 guests
