[Latest Update] ESP32 Hardware Reference Design
pighixxx
Re: [Documentation Release] PCB of ESP32 Module
Postby pighixxx » Mon Dec 07, 2015 12:39 pm
Hi to all,
here the first pinout of ESP32.
Download the pdf at:
http://www.pighixxx.com/test/2015/12/esp32-pinout/
testato
Postby testato » Mon Dec 07, 2015 1:31 pm
always the best :D
Caesium
Postby Caesium » Mon Dec 07, 2015 6:59 pm
What's the source of this? Any verification it is real please? :)
pighixxx
Postby pighixxx » Mon Dec 07, 2015 7:55 pm
The source is Esprissif:)
Postby rudi ;-) » Mon Dec 07, 2015 10:23 pm
Oh that is not good! - We do not use Beta from Esprissif! You are at the wrong forum.. :o
Or do you mean Espressif ? :roll:
can we trust you that you did it named right in the modul ?
:mrgreen:
this is fun! ;- )
( i hope i will never write wrong "espressif" and if it does, make fun of me too )
thank you for your nice work again.
you did it nice in 07 and other, thank you!
one wish:
if you can named the SoC PIN Nr and write in parenthesesin to the Modul Pins,
example http://esp32.com/viewtopic.php?f=2&t=23
this would help in read documents later.
have you a donation link?
greetings to you!
btw, where is espressif?
verification it is real need, please
:oops:
Postby rudi ;-) » Mon Dec 07, 2015 11:29 pm
WTF....
hope, espressif has not mounted the chip like this picture?
this would be not good :o
sorry
please check the chip position on picture :mrgreen:
think you must rotating the chip? or point pin 1 is wrong?
why an old chip from 2014 ? :ugeek:
have a look to this:
check it out!.PNG (67.23 KiB) Viewed 57749 times
and have a look to your design
info:
the antenna pin on modul is is?
the pin 1 of chip is?
let us know your update asap,
rudi
Postby rudi ;-) » Tue Dec 08, 2015 12:18 am
checked rev1.PNG (78.06 KiB) Viewed 57748 times
please have a control to the pin names too,
perhabs all fine - but controll it please.
pighixxx
Postby pighixxx » Tue Dec 08, 2015 8:58 am
Hi to All,
sorry for the mistake I mean Espressif :D
I released a new version that fixes some bugs. Thanks for the feedback!
Download pdf here:
Edit
And yes, I've a donation link.
http://www.pighixxx.com/test/donate/
Postby rudi ;-) » Wed Dec 09, 2015 12:54 am
Hi Alberto
txs, can you please tell, which base you take?
john have linked yours here, so i am little confuse :)
http://esp32.com/viewtopic.php?f=2&t=14&#p107
perhabs he do not had valid only link to the pic.
because in some named connectors the name is difficult:
i can not controll all have no docu about - only the RTOS SDK 1.0 Src Code.
one example here can be controll and is showing here in the
base espressif RTOS SDK 1.0
SRC= https://github.com/espressif/ESP32_RTOS ... _mux_reg.h
take a look to GPIO 15 example:
#define PERIPHS_IO_MUX_MTDO_U (DR_REG_IO_MUX_BASE +0x3c)
#define FUNC_MTDO_U0RTS 3
#define FUNC_MTDO_GPIO15 2
#define FUNC_MTDO_HSPICS0 1
#define FUNC_MTDO_MTDO 0
we have U0RTS
The named pin is U0RTS
Your Pic shows U0CTS
btw
U0CTS is named in RTOS SDK 1.0
#define PERIPHS_IO_MUX_MTCK_U (DR_REG_IO_MUX_BASE +0x38)
#define FUNC_MTCK_U0CTS 3
#define FUNC_MTCK_GPIO13 2
#define FUNC_MTCK_HSPID 1
#define FUNC_MTCK_MTCK 0
that normaly must be PAD 16, ( GPIO13 ) but your pic shows no named pin for Uart0 CTS
have not controll all, but think there is a little mistake.
Which Base you take for naming the pads?
Because ;- ) we have Bounty Programm and perhabs the linked header file in RTOS SDK have a bug :o or yours :?
Info:
RTS = Request to send
CTS = Clear to send
( hey i like your work so much! its fun ok! if john tell you this named pin then make a entry in bug bounty program, and john ;-) ... 3 : 0 ) :mrgreen:
Edit:
Picture add
Info add
CTS = Clear to send
pighixxx
Postby pighixxx » Wed Dec 09, 2015 8:08 am
Hi Rudy,
I double checked the info on my hands and yes, you're on right.
Preliminary information that I had was incorrect. Today I release a new pinout version enriched with new information.
Stay in touch!
