ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6908
ho 0 tail 12 room 4
load:0x40078000,len:14308
load:0x40080400,len:3716
0x40080400: _init at ??:?
entry 0x40080680
I (29) boot: ESP-IDF v4.3.1 2nd stage bootloader
I (29) boot: compile time 07:01:12
I (29) boot: chip revision: 1
I (32) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (39) boot.esp32: SPI Speed : 40MHz
I (43) boot.esp32: SPI Mode : DIO
I (48) boot.esp32: SPI Flash Size : 4MB
I (52) boot: Enabling RNG early entropy source...
I (58) boot: Partition Table:
I (61) boot: ## Label Usage Type ST Offset Length
I (69) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (76) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (84) boot: 2 ota_0 OTA app 00 10 00010000 001b0000
I (91) boot: 3 ota_1 OTA app 00 11 001c0000 001b0000
I (99) boot: 4 storage Unknown data 01 82 00370000 00080000
I (106) boot: End of partition table
I (110) boot_comm: chip revision: 1, min. application chip revision: 0
I (117) esp_image: segment 0: paddr=001c0020 vaddr=3f400020 size=29e90h (171664) map
I (188) esp_image: segment 1: paddr=001e9eb8 vaddr=3ffbdb60 size=04a94h ( 19092) load
I (196) esp_image: segment 2: paddr=001ee954 vaddr=40080000 size=016c4h ( 5828) load
I (199) esp_image: segment 3: paddr=001f0020 vaddr=400d0020 size=bbc64h (769124) map
I (480) esp_image: segment 4: paddr=002abc8c vaddr=400816c4 size=1d458h (119896) load
I (530) esp_image: segment 5: paddr=002c90ec vaddr=400c0000 size=00064h ( 100) load
I (530) esp_image: segment 6: paddr=002c9158 vaddr=50000000 size=00010h ( 16) load
I (551) boot: Loaded app from partition at offset 0x1c0000
I (551) boot: Disabling RNG early entropy source...
I (562) cpu_start: Pro cpu up.
I (562) cpu_start: Starting app cpu, entry point is 0x40081610
0x40081610: call_start_cpu1 at /opt/esp/idf/components/esp_system/port/cpu_start.c:141
I (0) cpu_start: App cpu up.
https://github.com/espressif/esp-idf/issues/7926
viewtopic.php?f=13&t=11963#
https://esp32.com/viewtopic.php?t=19160#
I don't think this is the same as the Github issue as my bootloader isn't from the commit window mentioned. Is there anything I can do to prevent my devices in field from bricking as far as the customer is concerned?
