Obviously i can use the promisc mode to capture traffic, even when this traffic doesn't 'goes threw' the esp 32 ( = the esp32 is not connected to this network). I was wondering because i learned, that the promiscuous mode is for capturing traffic, but the device has to be connected with this network. For capturing traffic of a network which i'm not connected to, i need the monitor mode.
So in 'my opinion', the esp32 has the monitor mode. Why is there always the speech of promisc mode ( eg https://github.com/espressif/esp-idf/bl ... esp_wifi.h ). Or did i get something wrong with promiscuous- and monitor mode?
esp32: promisc mode or monitor mode?
Re: esp32: promisc mode or monitor mode?
Do you mean that you want to connect to a wifi AP, stay connected, and also get all packets in promiscuous mode?
I am trying to do that and I find that when I call the wifi connection is dropped.
It behaves as if, it abandons the managed station mode and goes into monitor mode, losing the wifi connection in the process. Is that what you are trying to say as well?
esp_wifi_set_promiscuous(1);It behaves as if, it abandons the managed station mode and goes into monitor mode, losing the wifi connection in the process. Is that what you are trying to say as well?
Users browsing this forum: Amazon [Bot], Craig_2026 and 1 guest
