ESP WROOM 32 newbie questions
JohnKed
Postby JohnKed » Sat Jun 24, 2017 6:48 pm
Well, I starting with the ESP32 (using Arduino Core) and I have lot of question despite my google searches!
So, question 1:
Does the ESP Wroom 32 has bluetooth? And if yes, it uses the same pcb antenna that's on the PCB or I have to use an external antenna? Can I use Bluetooth and WiFi the same time with this PCB antenna on the module?
2:
I want to have two ESP32 wroom modules and just send basic serial data between them via bluetooth. Do we have any software example about that?
3:
Its seems that the ESP32 has two cores. Can I program those cores to run totally different code with Arduino? If yes, can I exchange info (let's say simple serial data) between those cores internally? Any example?
Also, can both of those cores control separate IO pins?
4:
Can I use the sd card to run ESP32 firmware from there and also use the same sd card for data?
5:
Is it possible to use SsoftwareSerial on any pins of ESP32?
Well... that's all for now! Many thanks in advance!!!
sintech
Re: ESP WROOM 32 newbie questions
Postby sintech » Mon Jun 26, 2017 8:49 am
So, question 1:
Yes, the same antenna. You can use BT and WIFI at the same time.
3:
Yes you can. https://esp32.com/viewtopic.php?f=13&t=2118
Both cores have access to the same memory space, i.e. you can r/w to same variable on both cores. But it is not tread safe approach.
And yes, each core can control any GPIO.
4:
Currently you can use SD card only for data. Program should be stored on SPI flash attached to separate pins (inside module).
5:
Why not.
JohnKed
Postby JohnKed » Mon Jun 26, 2017 2:56 pm
Thank you sintech!!!
It was really helpfull!
Users browsing this forum: ChatGPT-User, Qwantbot and 1 guest
