ESP IDF 4.4
I want to use I2S1 for VOIP Example here: https://github.com/espressif/esp-adf/bl ... voip_app.c
The only change I made in the example is as follows:
Code: voip_app.c Select all
#define I2S1_CHANNELS I2S_CHANNEL_FMT_ONLY_LEFT
int ret = i2s_write_expand(I2S_NUM_1, buf, len, 16, I2S_BITS, &bytes_write, wait_time);
i2s_driver_init(I2S_NUM_1, I2S1_CHANNELS, I2S_BITS);
audio_player_int_tone_init(I2S_SAMPLE_RATE, I2S1_CHANNELS, I2S_BITS);
Code: board_pins_config.c Select all
esp_err_t get_i2s_pins(i2s_port_t port, i2s_pin_config_t *i2s_config)
AUDIO_NULL_CHECK(TAG, i2s_config, return ESP_FAIL);
if (port == I2S_NUM_0) {
i2s_config->bck_io_num = -1;
i2s_config->ws_io_num = -1;
i2s_config->data_out_num = -1;
i2s_config->data_in_num = -1;
i2s_config->mck_io_num = -1;
} else if (port == I2S_NUM_1) {
i2s_config-> bck_io_num = GPIO_NUM_9;
i2s_config->ws_io_num = GPIO_NUM_45;
i2s_config->data_out_num = GPIO_NUM_8;
i2s_config->data_in_num = GPIO_NUM_10;
i2s_config->mck_io_num = GPIO_NUM_16;
} else {
memset(i2s_config, -1, sizeof(i2s_pin_config_t));
ESP_LOGE(TAG, "i2s port %d is not supported", port);
return ESP_FAIL;
return ESP_OK;
The audio from speaker is working; however, the two microphones on the ESP32-S3-Korvo-2 V3.0, are not sending any voice i.e microphones stopped working.
When I revert back my changes to I2S0, everything is working.
Really need little guidance here!!!
