Components and CMakeList
ArminArmin
Postby ArminArmin » Mon Dec 05, 2022 7:46 pm
Code: Untitled.html Select all
I have been suggested to put different libraries into a components folder and address them using CMakeList.txt .
My folder structure lookslike this:
- main
   main.c
- components
   -Lib_A
       aa.c
       aa.h
       - A1
           bb.c
           bb.h
       _ A2
           dd.c
           dd.h
   -Lib_B
       ee.c
       ee.h
       - B1
           ff.c
           ff.h
       - B2
           gg.c
           gg.h
I put this in the CMakeList:
set(EXTRA_COMPONENT_DIRS "components")
Then I included it with:
#include "dd.h"
But idf shows:
fatal error: dd.h: No such file or directory
I read here also:
https://docs.espressif.com/projects/esp ... ystem.html
What is the solution?
igrr
Re: Components and CMakeList
Postby igrr » Tue Dec 06, 2022 7:41 am
Hi Armin,
CODE: SELECT ALL
This part is not necessary, "components" directory of the project is searched for components by default.
There can be two reasons for this error. Either you haven't added the directory A2 as a public include directory of component Lib_A; or you didn't add Lib_A component as a dependency to the component where you have '#include" dd.h"'.
Could you please post the CMakeLists.txt file of the component Lib_A and of the component where the "include" error happens?
ArminArmin
Postby ArminArmin » Tue Dec 06, 2022 6:27 pm
Thanks,
I got only two CMakeList files, one is in the project folder and the other one is in the main/ folder.
Like this:
project folder:
   - components
   - main
      -CMakeLists.txt
   - CMakeLists.txt
igrr
Postby igrr » Wed Dec 07, 2022 10:35 am
Okay, that might be the issue then.
Each component in the ESP-IDF build system should have a CMakeLists.txt file. You can find more information about component CMakeLists.txt files at https://docs.espressif.com/projects/esp ... ists-files. Please try creating the CMakeLists.txt files in the components Lib_A and Lib_B.
For example, based on the structure you have shown, the CMakeLists.txt for Lib_A might look as follows:
idf_component_register(SRCS aa.c A1/bb.c A2/dd.c
                       INCLUDE_DIRS . A1 A2
                       REQUIRES driver esp_wifi
This will do the following:
  • Compile source files aa.c, A1/bb.c and A2/dd.c
  • Expose the component root dir (.) and A1, A2 as public include directories of the component. This will allow other components to use `#include "aa.h"` or `#include "bb.h"`
  • Specify which other components Lib_A depends on. In this example I have put "driver" and "esp_wifi" there. You need to change it based on the header files you want to include in Lib_A.
ArminArmin
Postby ArminArmin » Thu Dec 08, 2022 1:37 pm
Thank you so much for explaining.
Out of curiosity,
If A1/ directory has multiple files (.h), then each of those files should be written in the CMakeList?
For example, Let's say there are 100 files in the A1/ , then all of those 100 files should be specified in the CMakeList?
Is it possible to specify the folder name only?
igrr
Postby igrr » Tue Dec 13, 2022 4:04 pm
In addition to the options mentioned by chegewara, idf_component_register also accepts SRC_DIRS argument. You can specify the names of the directories, and IDF will look for .c, .cpp, .S source files in those directories. This argument is mentioned in the same build-system reference page linked earlier.
Unlike source files, header files do not need to be specified in CMake.
Users browsing this forum: Applebot, ChatGPT-User, Google [Bot], MicroController, Semrush [Bot] and 5 guests
