Adding a library to CMakeList
ArminArmin
Postby ArminArmin » Mon Dec 12, 2022 6:50 pm
I have LVGL library:
https://github.com/espressif/esp-iot-solution
In this path:
c:/path/esp-iot-solution
I would like to add this path to my project.
What I did:
1. Created a new environment variable for the library path (c:/path/esp-iot-solution) called IOT_SOLUTION_PATH.
2. In the CMakeLists.txt of the project, I added:
set(EXTRA_COMPONENT_DIRS "${EXTRA_COMPONENT_DIRS} ${IOT_SOLUTION_PATH}/components/button")
3. Include it:
#include "iot_button.h"
After compiling:
fatal error: #include "iot_button.h": No such file or directory
In general, even though I added the environment variable to the CMakeList.txt, the program still cannot get the related files.
What is the solution?
igrr
Re: Adding a library to CMakeList
Postby igrr » Tue Dec 13, 2022 4:30 pm
Same as in the other topic, please check whether you have added the component (iot_button in this case) to the REQUIRES or PRIV_REQUIRES list of the component where you are trying to include the header file.
Note that for new projects, we recommend installing the components automatically using the IDF Component Manager, instead of manually downloading them and adding to CMake. You can find the components at https://components.espressif.com/ and install them using "idf.py add-dependency" command. Several example in ESP-IDF v5.0 are already using this approach.
Users browsing this forum: Baidu [Spider], MicroController, Perplexity-User and 5 guests
