Upload a pre-encrypted .bin on ESP32C3 webserver for OTA with IDF 5.0
Pandre4
Postby Pandre4 » Tue Dec 13, 2022 4:34 pm
I worked on a program with IDF 5.0. It generates a webserser (via Acces Point mode) where i can directly upload an .bin firmware to update the firmware with simples OTA tools, without using HTTPS OTA. This works fine.
After, I have begun to implement a secure boot and the firmware encryption, but I need to read an encrypted .bin for the OTA to secure our futur products of course. In the official documentation, i saw an example to make a pre encrypted OTA with HTTPS OTA tools.
So, is there a way to upload a pre encrypted .bin on the ESP32C3 webserver with secure boot on and encryption on, without using HTTPS OTA tools ? Using simple functions that I already use such as esp_ota_begin, esp_ota_write... And of course, if i use a not encrypted .bin for OTA, the firmware refuses to updating.
Thanks you for your help.
Paul
Mahavir
Re: Upload a pre-encrypted .bin on ESP32C3 webserver for OTA with IDF 5.0
Postby Mahavir » Wed Dec 14, 2022 7:08 am
Hello Paul,
Pre-encrypted OTA example also generates an encrypted firmware image as a part of the build system. Please refer to https://github.com/espressif/esp-idf/tr ... sh-example. You may upload this image on the server for OTA updates.
Pandre4
Postby Pandre4 » Fri Dec 16, 2022 11:14 am
Ok, there is something I didn't understand. The pre-encryption image (.bin) for OTA uses a different key than the firmware encryption.
It is clearer in my mind. Finally, I fixed some problems, I can update my firmware (encryption on and secure boot on) with OTA, with a .bin unencrypted. I will work with a encrypted .bin later, this is not urgent.
Thanks for your help.
Uschi_bloom
Postby Uschi_bloom » Tue Feb 14, 2023 2:18 pm
Hey Paul,
did you manage to set up ota updates with pre-encrypted bin files via your esp webserver?
I am currently looking for a solution to this problem as well.
Users browsing this forum: Amazon [Bot], Qwantbot and 3 guests
