Using UART0 and U0TXD U0RXD as regular UART on ESP32-C3
vm__dm
Postby vm__dm » Thu Dec 15, 2022 4:03 pm
I need to use U0TXD and U0RXD as regular UART on ESP32-C3.
For testing, I am implementing a USB-to-UART bridge, from the physical UART to the USB-CDC one.
My test application is quite simple:
#include <stdio.h>
#include <driver/gpio.h>
#include <driver/uart.h>
#include <freertos/FreeRTOS.h>
#define UART_NUM 0
FILE* usb_handle = NULL;
void uart_init() {
  uart_config_t uart_config = {
      .baud_rate = 115200,
      .data_bits = UART_DATA_8_BITS,
      .parity = UART_PARITY_DISABLE,
      .stop_bits = UART_STOP_BITS_1,
      .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
      .source_clk = UART_SCLK_DEFAULT,
  // configure UART0
  uart_driver_install(UART_NUM, 1024, 0, 0, NULL, 0);
  uart_param_config(UART_NUM, &uart_config);
  uart_set_pin(UART_NUM, 21, 20, -1, -1);
void usb_init() {
  usb_handle = fopen("/dev/usbserjtag", "r+b");
void rx_task(void*) {
  uart_write_bytes(UART_NUM, "hello uart", 10);
  fwrite("hello usb", 9, 1, usb_handle);
  for (;;) {
    uint8_t buf;
    int read;
    read = fread(&buf, 1, 1, usb_handle);
    if (read > 0) {
      uart_write_bytes(UART_NUM, &buf, 1);
    read = uart_read_bytes(UART_NUM, &buf, 1, 0);
    if (read > 0) {
      fwrite(&buf, 1, 1, usb_handle);
      //uart_write_bytes(UART_NUM, &buf, 1);
void app_main(void) {
  uart_init();
  usb_init();
  xTaskCreate(rx_task, "usb2uart", 4096, NULL, 1, NULL);
I connected an FTDI 3.3V USB2UART cable to ESP32-C3-devkitM-1 pins labeled TX and RX (GPIO21 and 20).
When I boot my device I see messages from the boot ROM (I don't need to disable them ATM) and then my hello message.
On the USB serial I also see the hello message.
If I send data to the USB uart I see the same echoed on the physical UART, but the opposite does not work. I also added a call to echo data back to the UART, but I still don't see anything coming out.
I suppose that is the UART0 RX path not working, because I see that uart_read_bytes always returns 0.
I checked with a scope on the pin and I see incoming data at 3.3V.
Here's my sdkconfig file:
# Automatically generated file. DO NOT EDIT.
# Espressif IoT Development Framework (ESP-IDF) Project Configuration
CONFIG_SOC_ADC_SUPPORTED=y
CONFIG_SOC_DEDICATED_GPIO_SUPPORTED=y
CONFIG_SOC_GDMA_SUPPORTED=y
CONFIG_SOC_TWAI_SUPPORTED=y
CONFIG_SOC_BT_SUPPORTED=y
CONFIG_SOC_ASYNC_MEMCPY_SUPPORTED=y
CONFIG_SOC_USB_SERIAL_JTAG_SUPPORTED=y
CONFIG_SOC_TEMP_SENSOR_SUPPORTED=y
CONFIG_SOC_XT_WDT_SUPPORTED=y
CONFIG_SOC_WIFI_SUPPORTED=y
CONFIG_SOC_SUPPORTS_SECURE_DL_MODE=y
CONFIG_SOC_EFUSE_KEY_PURPOSE_FIELD=y
CONFIG_SOC_EFUSE_HAS_EFUSE_RST_BUG=y
CONFIG_SOC_RTC_FAST_MEM_SUPPORTED=y
CONFIG_SOC_RTC_MEM_SUPPORTED=y
CONFIG_SOC_I2S_SUPPORTED=y
CONFIG_SOC_RMT_SUPPORTED=y
CONFIG_SOC_SDM_SUPPORTED=y
CONFIG_SOC_SYSTIMER_SUPPORTED=y
CONFIG_SOC_SUPPORT_COEXISTENCE=y
CONFIG_SOC_AES_SUPPORTED=y
CONFIG_SOC_MPI_SUPPORTED=y
CONFIG_SOC_SHA_SUPPORTED=y
CONFIG_SOC_HMAC_SUPPORTED=y
CONFIG_SOC_DIG_SIGN_SUPPORTED=y
CONFIG_SOC_FLASH_ENC_SUPPORTED=y
CONFIG_SOC_SECURE_BOOT_SUPPORTED=y
CONFIG_SOC_MEMPROT_SUPPORTED=y
CONFIG_SOC_XTAL_SUPPORT_40M=y
CONFIG_SOC_AES_SUPPORT_DMA=y
CONFIG_SOC_AES_GDMA=y
CONFIG_SOC_AES_SUPPORT_AES_128=y
CONFIG_SOC_AES_SUPPORT_AES_256=y
CONFIG_SOC_ADC_DIG_CTRL_SUPPORTED=y
CONFIG_SOC_ADC_ARBITER_SUPPORTED=y
CONFIG_SOC_ADC_FILTER_SUPPORTED=y
CONFIG_SOC_ADC_MONITOR_SUPPORTED=y
CONFIG_SOC_ADC_DMA_SUPPORTED=y
CONFIG_SOC_ADC_PERIPH_NUM=2
CONFIG_SOC_ADC_MAX_CHANNEL_NUM=5
CONFIG_SOC_ADC_ATTEN_NUM=4
CONFIG_SOC_ADC_DIGI_CONTROLLER_NUM=1
CONFIG_SOC_ADC_PATT_LEN_MAX=8
CONFIG_SOC_ADC_DIGI_MIN_BITWIDTH=12
CONFIG_SOC_ADC_DIGI_MAX_BITWIDTH=12
CONFIG_SOC_ADC_DIGI_RESULT_BYTES=4
CONFIG_SOC_ADC_DIGI_DATA_BYTES_PER_CONV=4
CONFIG_SOC_ADC_DIGI_FILTER_NUM=2
CONFIG_SOC_ADC_DIGI_MONITOR_NUM=2
CONFIG_SOC_ADC_SAMPLE_FREQ_THRES_HIGH=83333
CONFIG_SOC_ADC_SAMPLE_FREQ_THRES_LOW=611
CONFIG_SOC_ADC_RTC_MIN_BITWIDTH=12
CONFIG_SOC_ADC_RTC_MAX_BITWIDTH=12
CONFIG_SOC_ADC_CALIBRATION_V1_SUPPORTED=y
CONFIG_SOC_APB_BACKUP_DMA=y
CONFIG_SOC_BROWNOUT_RESET_SUPPORTED=y
CONFIG_SOC_SHARED_IDCACHE_SUPPORTED=y
CONFIG_SOC_CACHE_MEMORY_IBANK_SIZE=0x4000
CONFIG_SOC_CPU_CORES_NUM=1
CONFIG_SOC_CPU_INTR_NUM=32
CONFIG_SOC_CPU_HAS_FLEXIBLE_INTC=y
CONFIG_SOC_CPU_BREAKPOINTS_NUM=8
CONFIG_SOC_CPU_WATCHPOINTS_NUM=8
CONFIG_SOC_CPU_WATCHPOINT_SIZE=0x80000000
CONFIG_SOC_DS_SIGNATURE_MAX_BIT_LEN=3072
CONFIG_SOC_DS_KEY_PARAM_MD_IV_LENGTH=16
CONFIG_SOC_DS_KEY_CHECK_MAX_WAIT_US=1100
CONFIG_SOC_GDMA_GROUPS=1
CONFIG_SOC_GDMA_PAIRS_PER_GROUP=3
CONFIG_SOC_GDMA_TX_RX_SHARE_INTERRUPT=y
CONFIG_SOC_GPIO_PORT=1
CONFIG_SOC_GPIO_PIN_COUNT=22
CONFIG_SOC_GPIO_SUPPORTS_RTC_INDEPENDENT=y
CONFIG_SOC_GPIO_SUPPORT_FORCE_HOLD=y
CONFIG_SOC_GPIO_SUPPORT_DEEPSLEEP_WAKEUP=y
CONFIG_SOC_GPIO_DEEP_SLEEP_WAKE_VALID_GPIO_MASK=0
CONFIG_SOC_GPIO_SUPPORT_SLP_SWITCH=y
CONFIG_SOC_DEDIC_GPIO_OUT_CHANNELS_NUM=8
CONFIG_SOC_DEDIC_GPIO_IN_CHANNELS_NUM=8
CONFIG_SOC_DEDIC_PERIPH_ALWAYS_ENABLE=y
CONFIG_SOC_I2C_NUM=1
CONFIG_SOC_I2C_FIFO_LEN=32
CONFIG_SOC_I2C_SUPPORT_SLAVE=y
CONFIG_SOC_I2C_SUPPORT_HW_CLR_BUS=y
CONFIG_SOC_I2C_SUPPORT_XTAL=y
CONFIG_SOC_I2C_SUPPORT_RTC=y
CONFIG_SOC_I2S_NUM=y
CONFIG_SOC_I2S_HW_VERSION_2=y
CONFIG_SOC_I2S_SUPPORTS_PCM=y
CONFIG_SOC_I2S_SUPPORTS_PDM=y
CONFIG_SOC_I2S_SUPPORTS_PDM_TX=y
CONFIG_SOC_I2S_SUPPORTS_PDM_CODEC=y
CONFIG_SOC_I2S_SUPPORTS_TDM=y
CONFIG_SOC_LEDC_SUPPORT_APB_CLOCK=y
CONFIG_SOC_LEDC_SUPPORT_XTAL_CLOCK=y
CONFIG_SOC_LEDC_CHANNEL_NUM=6
CONFIG_SOC_LEDC_TIMER_BIT_WIDE_NUM=14
CONFIG_SOC_LEDC_SUPPORT_FADE_STOP=y
CONFIG_SOC_MPU_MIN_REGION_SIZE=0x20000000
CONFIG_SOC_MPU_REGIONS_MAX_NUM=8
CONFIG_SOC_RMT_GROUPS=1
CONFIG_SOC_RMT_TX_CANDIDATES_PER_GROUP=2
CONFIG_SOC_RMT_RX_CANDIDATES_PER_GROUP=2
CONFIG_SOC_RMT_CHANNELS_PER_GROUP=4
CONFIG_SOC_RMT_MEM_WORDS_PER_CHANNEL=48
CONFIG_SOC_RMT_SUPPORT_RX_PINGPONG=y
CONFIG_SOC_RMT_SUPPORT_RX_DEMODULATION=y
CONFIG_SOC_RMT_SUPPORT_TX_ASYNC_STOP=y
CONFIG_SOC_RMT_SUPPORT_TX_LOOP_COUNT=y
CONFIG_SOC_RMT_SUPPORT_TX_SYNCHRO=y
CONFIG_SOC_RMT_SUPPORT_TX_CARRIER_DATA_ONLY=y
CONFIG_SOC_RMT_SUPPORT_XTAL=y
CONFIG_SOC_RMT_SUPPORT_APB=y
CONFIG_SOC_RMT_SUPPORT_RC_FAST=y
CONFIG_SOC_RTC_CNTL_CPU_PD_DMA_BUS_WIDTH=128
CONFIG_SOC_RTC_CNTL_CPU_PD_REG_FILE_NUM=108
CONFIG_SOC_RTC_SLOW_CLOCK_SUPPORT_8MD256=y
CONFIG_SOC_RTCIO_PIN_COUNT=0
CONFIG_SOC_RSA_MAX_BIT_LEN=3072
CONFIG_SOC_SHA_DMA_MAX_BUFFER_SIZE=3968
CONFIG_SOC_SHA_SUPPORT_DMA=y
CONFIG_SOC_SHA_SUPPORT_RESUME=y
CONFIG_SOC_SHA_GDMA=y
CONFIG_SOC_SHA_SUPPORT_SHA1=y
CONFIG_SOC_SHA_SUPPORT_SHA224=y
CONFIG_SOC_SHA_SUPPORT_SHA256=y
CONFIG_SOC_SDM_GROUPS=1
CONFIG_SOC_SDM_CHANNELS_PER_GROUP=4
CONFIG_SOC_SPI_PERIPH_NUM=2
CONFIG_SOC_SPI_MAX_CS_NUM=6
CONFIG_SOC_SPI_MAXIMUM_BUFFER_SIZE=64
CONFIG_SOC_SPI_SUPPORT_DDRCLK=y
CONFIG_SOC_SPI_SLAVE_SUPPORT_SEG_TRANS=y
CONFIG_SOC_SPI_SUPPORT_CD_SIG=y
CONFIG_SOC_SPI_SUPPORT_CONTINUOUS_TRANS=y
CONFIG_SOC_SPI_SUPPORT_SLAVE_HD_VER2=y
CONFIG_SOC_SPI_PERIPH_SUPPORT_CONTROL_DUMMY_OUT=y
CONFIG_SOC_MEMSPI_IS_INDEPENDENT=y
CONFIG_SOC_SPI_MAX_PRE_DIVIDER=16
CONFIG_SOC_SPI_MEM_SUPPORT_AUTO_WAIT_IDLE=y
CONFIG_SOC_SPI_MEM_SUPPORT_AUTO_SUSPEND=y
CONFIG_SOC_SPI_MEM_SUPPORT_AUTO_RESUME=y
CONFIG_SOC_SPI_MEM_SUPPORT_IDLE_INTR=y
CONFIG_SOC_SPI_MEM_SUPPORT_SW_SUSPEND=y
CONFIG_SOC_SPI_MEM_SUPPORT_CHECK_SUS=y
CONFIG_SOC_SPI_MEM_SUPPORT_CONFIG_GPIO_BY_EFUSE=y
CONFIG_SOC_MEMSPI_SRC_FREQ_80M_SUPPORTED=y
CONFIG_SOC_MEMSPI_SRC_FREQ_40M_SUPPORTED=y
CONFIG_SOC_MEMSPI_SRC_FREQ_26M_SUPPORTED=y
CONFIG_SOC_MEMSPI_SRC_FREQ_20M_SUPPORTED=y
CONFIG_SOC_SYSTIMER_COUNTER_NUM=2
CONFIG_SOC_SYSTIMER_ALARM_NUM=3
CONFIG_SOC_SYSTIMER_BIT_WIDTH_LO=32
CONFIG_SOC_SYSTIMER_BIT_WIDTH_HI=20
CONFIG_SOC_SYSTIMER_FIXED_DIVIDER=y
CONFIG_SOC_SYSTIMER_INT_LEVEL=y
CONFIG_SOC_SYSTIMER_ALARM_MISS_COMPENSATE=y
CONFIG_SOC_TIMER_GROUPS=2
CONFIG_SOC_TIMER_GROUP_TIMERS_PER_GROUP=1
CONFIG_SOC_TIMER_GROUP_COUNTER_BIT_WIDTH=54
CONFIG_SOC_TIMER_GROUP_SUPPORT_XTAL=y
CONFIG_SOC_TIMER_GROUP_SUPPORT_APB=y
CONFIG_SOC_TIMER_GROUP_TOTAL_TIMERS=2
CONFIG_SOC_TWAI_BRP_MIN=2
CONFIG_SOC_TWAI_BRP_MAX=16384
CONFIG_SOC_TWAI_SUPPORTS_RX_STATUS=y
CONFIG_SOC_SECURE_BOOT_V2_RSA=y
CONFIG_SOC_EFUSE_SECURE_BOOT_KEY_DIGESTS=3
CONFIG_SOC_EFUSE_REVOKE_BOOT_KEY_DIGESTS=y
CONFIG_SOC_SUPPORT_SECURE_BOOT_REVOKE_KEY=y
CONFIG_SOC_FLASH_ENCRYPTED_XTS_AES_BLOCK_MAX=32
CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES=y
CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES_128=y
CONFIG_SOC_MEMPROT_CPU_PREFETCH_PAD_SIZE=16
CONFIG_SOC_MEMPROT_MEM_ALIGN_SIZE=512
CONFIG_SOC_UART_NUM=2
CONFIG_SOC_UART_FIFO_LEN=128
CONFIG_SOC_UART_BITRATE_MAX=5000000
CONFIG_SOC_UART_SUPPORT_APB_CLK=y
CONFIG_SOC_UART_SUPPORT_RTC_CLK=y
CONFIG_SOC_UART_SUPPORT_XTAL_CLK=y
CONFIG_SOC_UART_SUPPORT_WAKEUP_INT=y
CONFIG_SOC_UART_REQUIRE_CORE_RESET=y
CONFIG_SOC_UART_SUPPORT_FSM_TX_WAIT_SEND=y
CONFIG_SOC_COEX_HW_PTI=y
CONFIG_SOC_PHY_DIG_REGS_MEM_SIZE=21
CONFIG_SOC_MAC_BB_PD_MEM_SIZE=192
CONFIG_SOC_WIFI_LIGHT_SLEEP_CLK_WIDTH=12
CONFIG_SOC_PM_SUPPORT_WIFI_WAKEUP=y
CONFIG_SOC_PM_SUPPORT_BT_WAKEUP=y
CONFIG_SOC_PM_SUPPORT_CPU_PD=y
CONFIG_SOC_PM_SUPPORT_WIFI_PD=y
CONFIG_SOC_PM_SUPPORT_BT_PD=y
CONFIG_SOC_TEMPERATURE_SENSOR_SUPPORT_FAST_RC=y
CONFIG_SOC_TEMPERATURE_SENSOR_SUPPORT_XTAL=y
CONFIG_SOC_WIFI_HW_TSF=y
CONFIG_SOC_WIFI_FTM_SUPPORT=y
CONFIG_SOC_WIFI_GCMP_SUPPORT=y
CONFIG_SOC_WIFI_WAPI_SUPPORT=y
CONFIG_SOC_WIFI_CSI_SUPPORT=y
CONFIG_SOC_WIFI_MESH_SUPPORT=y
CONFIG_SOC_BLE_SUPPORTED=y
CONFIG_SOC_BLE_MESH_SUPPORTED=y
CONFIG_IDF_CMAKE=y
CONFIG_IDF_TARGET_ARCH_RISCV=y
CONFIG_IDF_TARGET_ARCH="riscv"
CONFIG_IDF_TARGET="esp32c3"
CONFIG_IDF_TARGET_ESP32C3=y
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0005
# Build type
CONFIG_APP_BUILD_TYPE_APP_2NDBOOT=y
# CONFIG_APP_BUILD_TYPE_ELF_RAM is not set
CONFIG_APP_BUILD_GENERATE_BINARIES=y
CONFIG_APP_BUILD_BOOTLOADER=y
CONFIG_APP_BUILD_USE_FLASH_SECTIONS=y
# CONFIG_APP_REPRODUCIBLE_BUILD is not set
# CONFIG_APP_NO_BLOBS is not set
# end of Build type
# Bootloader config
CONFIG_BOOTLOADER_OFFSET_IN_FLASH=0x0
CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_SIZE=y
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_DEBUG is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_NONE is not set
CONFIG_BOOTLOADER_LOG_LEVEL_NONE=y
# CONFIG_BOOTLOADER_LOG_LEVEL_ERROR is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_WARN is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_INFO is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_DEBUG is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_VERBOSE is not set
CONFIG_BOOTLOADER_LOG_LEVEL=0
# CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_8V is not set
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
# CONFIG_BOOTLOADER_FACTORY_RESET is not set
# CONFIG_BOOTLOADER_APP_TEST is not set
CONFIG_BOOTLOADER_REGION_PROTECTION_ENABLE=y
# CONFIG_BOOTLOADER_WDT_ENABLE is not set
# CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_IN_DEEP_SLEEP is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_ON_POWER_ON is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_ALWAYS is not set
CONFIG_BOOTLOADER_RESERVE_RTC_SIZE=0
# CONFIG_BOOTLOADER_CUSTOM_RESERVE_RTC is not set
CONFIG_BOOTLOADER_FLASH_XMC_SUPPORT=y
# end of Bootloader config
# Security features
CONFIG_SECURE_BOOT_V2_RSA_SUPPORTED=y
CONFIG_SECURE_BOOT_V2_PREFERRED=y
# CONFIG_SECURE_SIGNED_APPS_NO_SECURE_BOOT is not set
# CONFIG_SECURE_BOOT is not set
# CONFIG_SECURE_FLASH_ENC_ENABLED is not set
CONFIG_SECURE_ROM_DL_MODE_ENABLED=y
# end of Security features
# Application manager
CONFIG_APP_COMPILE_TIME_DATE=y
# CONFIG_APP_EXCLUDE_PROJECT_VER_VAR is not set
# CONFIG_APP_EXCLUDE_PROJECT_NAME_VAR is not set
# CONFIG_APP_PROJECT_VER_FROM_CONFIG is not set
CONFIG_APP_RETRIEVE_LEN_ELF_SHA=16
# end of Application manager
CONFIG_ESP_ROM_HAS_CRC_LE=y
CONFIG_ESP_ROM_HAS_CRC_BE=y
CONFIG_ESP_ROM_HAS_JPEG_DECODE=y
CONFIG_ESP_ROM_UART_CLK_IS_XTAL=y
CONFIG_ESP_ROM_USB_SERIAL_DEVICE_NUM=3
CONFIG_ESP_ROM_HAS_RETARGETABLE_LOCKING=y
CONFIG_ESP_ROM_HAS_ERASE_0_REGION_BUG=y
CONFIG_ESP_ROM_GET_CLK_FREQ=y
CONFIG_ESP_ROM_NEEDS_SWSETUP_WORKAROUND=y
# Boot ROM Behavior
CONFIG_BOOT_ROM_LOG_ALWAYS_ON=y
# CONFIG_BOOT_ROM_LOG_ALWAYS_OFF is not set
# CONFIG_BOOT_ROM_LOG_ON_GPIO_HIGH is not set
# CONFIG_BOOT_ROM_LOG_ON_GPIO_LOW is not set
# end of Boot ROM Behavior
# Serial flasher config
CONFIG_ESPTOOLPY_NO_STUB=y
# CONFIG_ESPTOOLPY_FLASHMODE_QIO is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE_DIO=y
# CONFIG_ESPTOOLPY_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASH_SAMPLE_MODE_STR=y
CONFIG_ESPTOOLPY_FLASHMODE="dio"
# CONFIG_ESPTOOLPY_FLASHFREQ_80M is not set
CONFIG_ESPTOOLPY_FLASHFREQ_40M=y
# CONFIG_ESPTOOLPY_FLASHFREQ_26M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_20M is not set
CONFIG_ESPTOOLPY_FLASHFREQ="40m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_2MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_4MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_8MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_16MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_32MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_64MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_128MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="4MB"
CONFIG_ESPTOOLPY_HEADER_FLASHSIZE_UPDATE=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
# CONFIG_ESPTOOLPY_BEFORE_NORESET is not set
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
# CONFIG_ESPTOOLPY_AFTER_NORESET is not set
CONFIG_ESPTOOLPY_AFTER="hard_reset"
CONFIG_ESPTOOLPY_MONITOR_BAUD=115200
# end of Serial flasher config
# Partition Table
CONFIG_PARTITION_TABLE_SINGLE_APP=y
# CONFIG_PARTITION_TABLE_SINGLE_APP_LARGE is not set
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
# CONFIG_PARTITION_TABLE_CUSTOM is not set
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions_singleapp.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
# end of Partition Table
# Compiler options
CONFIG_COMPILER_OPTIMIZATION_DEFAULT=y
# CONFIG_COMPILER_OPTIMIZATION_SIZE is not set
# CONFIG_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_COMPILER_OPTIMIZATION_NONE is not set
CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE=y
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_DISABLE is not set
CONFIG_COMPILER_FLOAT_LIB_FROM_GCCLIB=y
CONFIG_COMPILER_OPTIMIZATION_ASSERTION_LEVEL=2
# CONFIG_COMPILER_OPTIMIZATION_CHECKS_SILENT is not set
CONFIG_COMPILER_HIDE_PATHS_MACROS=y
# CONFIG_COMPILER_CXX_EXCEPTIONS is not set
# CONFIG_COMPILER_CXX_RTTI is not set
CONFIG_COMPILER_STACK_CHECK_MODE_NONE=y
# CONFIG_COMPILER_STACK_CHECK_MODE_NORM is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_STRONG is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_ALL is not set
# CONFIG_COMPILER_WARN_WRITE_STRINGS is not set
# CONFIG_COMPILER_SAVE_RESTORE_LIBCALLS is not set
# CONFIG_COMPILER_DUMP_RTL_FILES is not set
# end of Compiler options
# Component config
# Application Level Tracing
# CONFIG_APPTRACE_DEST_JTAG is not set
CONFIG_APPTRACE_DEST_NONE=y
# CONFIG_APPTRACE_DEST_UART1 is not set
# CONFIG_APPTRACE_DEST_USB_CDC is not set
CONFIG_APPTRACE_DEST_UART_NONE=y
CONFIG_APPTRACE_UART_TASK_PRIO=1
CONFIG_APPTRACE_LOCK_ENABLE=y
# end of Application Level Tracing
# Bluetooth
# CONFIG_BT_ENABLED is not set
# end of Bluetooth
# Driver Configurations
# Legacy ADC Configuration
# CONFIG_ADC_SUPPRESS_DEPRECATE_WARN is not set
# Legacy ADC Calibration Configuration
# CONFIG_ADC_CALI_SUPPRESS_DEPRECATE_WARN is not set
# end of Legacy ADC Calibration Configuration
# end of Legacy ADC Configuration
# SPI Configuration
# CONFIG_SPI_MASTER_IN_IRAM is not set
CONFIG_SPI_MASTER_ISR_IN_IRAM=y
# CONFIG_SPI_SLAVE_IN_IRAM is not set
CONFIG_SPI_SLAVE_ISR_IN_IRAM=y
# end of SPI Configuration
# TWAI Configuration
# CONFIG_TWAI_ISR_IN_IRAM is not set
# end of TWAI Configuration
# Temperature sensor Configuration
# CONFIG_TEMP_SENSOR_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_TEMP_SENSOR_ENABLE_DEBUG_LOG is not set
# end of Temperature sensor Configuration
# UART Configuration
CONFIG_UART_ISR_IN_IRAM=y
# end of UART Configuration
# GPIO Configuration
# CONFIG_GPIO_CTRL_FUNC_IN_IRAM is not set
# end of GPIO Configuration
# Sigma Delta Modulator Configuration
# CONFIG_SDM_CTRL_FUNC_IN_IRAM is not set
# CONFIG_SDM_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_SDM_ENABLE_DEBUG_LOG is not set
# end of Sigma Delta Modulator Configuration
# GPTimer Configuration
# CONFIG_GPTIMER_CTRL_FUNC_IN_IRAM is not set
# CONFIG_GPTIMER_ISR_IRAM_SAFE is not set
# CONFIG_GPTIMER_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_GPTIMER_ENABLE_DEBUG_LOG is not set
# end of GPTimer Configuration
# RMT Configuration
# CONFIG_RMT_ISR_IRAM_SAFE is not set
# CONFIG_RMT_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_RMT_ENABLE_DEBUG_LOG is not set
# end of RMT Configuration
# I2S Configuration
# CONFIG_I2S_ISR_IRAM_SAFE is not set
# CONFIG_I2S_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_I2S_ENABLE_DEBUG_LOG is not set
# end of I2S Configuration
# end of Driver Configurations
# eFuse Bit Manager
# CONFIG_EFUSE_CUSTOM_TABLE is not set
# CONFIG_EFUSE_VIRTUAL is not set
CONFIG_EFUSE_MAX_BLK_LEN=256
# end of eFuse Bit Manager
# ESP-TLS
CONFIG_ESP_TLS_USING_MBEDTLS=y
CONFIG_ESP_TLS_USE_DS_PERIPHERAL=y
# CONFIG_ESP_TLS_CLIENT_SESSION_TICKETS is not set
# CONFIG_ESP_TLS_SERVER is not set
# CONFIG_ESP_TLS_PSK_VERIFICATION is not set
# CONFIG_ESP_TLS_INSECURE is not set
# end of ESP-TLS
# ADC and ADC Calibration
# CONFIG_ADC_ONESHOT_CTRL_FUNC_IN_IRAM is not set
# CONFIG_ADC_CONTINUOUS_ISR_IRAM_SAFE is not set
# end of ADC and ADC Calibration
# Common ESP-related
CONFIG_ESP_ERR_TO_NAME_LOOKUP=y
# end of Common ESP-related
# Ethernet
CONFIG_ETH_ENABLED=y
CONFIG_ETH_USE_SPI_ETHERNET=y
# CONFIG_ETH_SPI_ETHERNET_DM9051 is not set
# CONFIG_ETH_SPI_ETHERNET_W5500 is not set
# CONFIG_ETH_SPI_ETHERNET_KSZ8851SNL is not set
# CONFIG_ETH_USE_OPENETH is not set
# CONFIG_ETH_TRANSMIT_MUTEX is not set
# end of Ethernet
# Event Loop Library
# CONFIG_ESP_EVENT_LOOP_PROFILING is not set
CONFIG_ESP_EVENT_POST_FROM_ISR=y
CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR=y
# end of Event Loop Library
# GDB Stub
# end of GDB Stub
# ESP HTTP client
CONFIG_ESP_HTTP_CLIENT_ENABLE_HTTPS=y
# CONFIG_ESP_HTTP_CLIENT_ENABLE_BASIC_AUTH is not set
# CONFIG_ESP_HTTP_CLIENT_ENABLE_DIGEST_AUTH is not set
# end of ESP HTTP client
# HTTP Server
CONFIG_HTTPD_MAX_REQ_HDR_LEN=512
CONFIG_HTTPD_MAX_URI_LEN=512
CONFIG_HTTPD_ERR_RESP_NO_DELAY=y
CONFIG_HTTPD_PURGE_BUF_LEN=32
# CONFIG_HTTPD_LOG_PURGE_DATA is not set
# CONFIG_HTTPD_WS_SUPPORT is not set
# CONFIG_HTTPD_QUEUE_WORK_BLOCKING is not set
# end of HTTP Server
# ESP HTTPS OTA
# CONFIG_ESP_HTTPS_OTA_DECRYPT_CB is not set
# CONFIG_ESP_HTTPS_OTA_ALLOW_HTTP is not set
# end of ESP HTTPS OTA
# ESP HTTPS server
# CONFIG_ESP_HTTPS_SERVER_ENABLE is not set
# end of ESP HTTPS server
# Hardware Settings
# MAC Config
CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_STA=y
CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_AP=y
CONFIG_ESP_MAC_ADDR_UNIVERSE_BT=y
CONFIG_ESP_MAC_ADDR_UNIVERSE_ETH=y
# CONFIG_ESP32C3_UNIVERSAL_MAC_ADDRESSES_TWO is not set
CONFIG_ESP32C3_UNIVERSAL_MAC_ADDRESSES_FOUR=y
CONFIG_ESP32C3_UNIVERSAL_MAC_ADDRESSES=4
# end of MAC Config
# Sleep Config
# CONFIG_ESP_SLEEP_POWER_DOWN_FLASH is not set
CONFIG_ESP_SLEEP_GPIO_RESET_WORKAROUND=y
CONFIG_ESP_SLEEP_FLASH_LEAKAGE_WORKAROUND=y
# CONFIG_ESP_SLEEP_MSPI_NEED_ALL_IO_PU is not set
# end of Sleep Config
# RTC Clock Config
CONFIG_RTC_CLK_SRC_INT_RC=y
# CONFIG_RTC_CLK_SRC_EXT_CRYS is not set
# CONFIG_RTC_CLK_SRC_EXT_OSC is not set
# CONFIG_RTC_CLK_SRC_INT_8MD256 is not set
CONFIG_RTC_CLK_CAL_CYCLES=1024
CONFIG_RTC_CLOCK_BBPLL_POWER_ON_WITH_USB=y
# end of RTC Clock Config
# Peripheral Control
CONFIG_PERIPH_CTRL_FUNC_IN_IRAM=y
# end of Peripheral Control
# MMU Config
CONFIG_MMU_PAGE_SIZE_64KB=y
CONFIG_MMU_PAGE_MODE="64KB"
CONFIG_MMU_PAGE_SIZE=0x10000
# end of MMU Config
# CONFIG_ESP32C3_REV_MIN_0 is not set
# CONFIG_ESP32C3_REV_MIN_1 is not set
# CONFIG_ESP32C3_REV_MIN_2 is not set
CONFIG_ESP32C3_REV_MIN_3=y
# CONFIG_ESP32C3_REV_MIN_4 is not set
CONFIG_ESP32C3_REV_MIN=3
# GDMA Configuration
# CONFIG_GDMA_CTRL_FUNC_IN_IRAM is not set
# CONFIG_GDMA_ISR_IRAM_SAFE is not set
# end of GDMA Configuration
# Main XTAL Config
CONFIG_XTAL_FREQ_40=y
CONFIG_XTAL_FREQ=40
# end of Main XTAL Config
# end of Hardware Settings
# LCD and Touch Panel
# LCD Touch Drivers are maintained in the IDF Component Registry
# LCD Peripheral Configuration
CONFIG_LCD_PANEL_IO_FORMAT_BUF_SIZE=32
# CONFIG_LCD_ENABLE_DEBUG_LOG is not set
# end of LCD Peripheral Configuration
# end of LCD and Touch Panel
# ESP NETIF Adapter
CONFIG_ESP_NETIF_IP_LOST_TIMER_INTERVAL=120
CONFIG_ESP_NETIF_TCPIP_LWIP=y
# CONFIG_ESP_NETIF_LOOPBACK is not set
# CONFIG_ESP_NETIF_L2_TAP is not set
# CONFIG_ESP_NETIF_BRIDGE_EN is not set
# end of ESP NETIF Adapter
# PHY
CONFIG_ESP_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP_PHY_MAX_TX_POWER=20
CONFIG_ESP_PHY_REDUCE_TX_POWER=y
CONFIG_ESP_PHY_ENABLE_USB=y
# end of PHY
# Power Management
# CONFIG_PM_ENABLE is not set
CONFIG_PM_POWER_DOWN_CPU_IN_LIGHT_SLEEP=y
# end of Power Management
# ESP PSRAM
# ESP Ringbuf
# CONFIG_RINGBUF_PLACE_FUNCTIONS_INTO_FLASH is not set
# CONFIG_RINGBUF_PLACE_ISR_FUNCTIONS_INTO_FLASH is not set
# end of ESP Ringbuf
# ESP System Settings
# CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_80 is not set
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_160=y
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ=160
CONFIG_ESP_SYSTEM_PANIC_PRINT_HALT=y
# CONFIG_ESP_SYSTEM_PANIC_PRINT_REBOOT is not set
# CONFIG_ESP_SYSTEM_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP_SYSTEM_PANIC_GDBSTUB is not set
# CONFIG_ESP_SYSTEM_GDBSTUB_RUNTIME is not set
CONFIG_ESP_SYSTEM_SINGLE_CORE_MODE=y
CONFIG_ESP_SYSTEM_RTC_FAST_MEM_AS_HEAP_DEPCHECK=y
CONFIG_ESP_SYSTEM_ALLOW_RTC_FAST_MEM_AS_HEAP=y
# CONFIG_ESP_SYSTEM_USE_EH_FRAME is not set
# Memory protection
CONFIG_ESP_SYSTEM_MEMPROT_FEATURE=y
CONFIG_ESP_SYSTEM_MEMPROT_FEATURE_LOCK=y
# end of Memory protection
CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_ESP_MAIN_TASK_STACK_SIZE=3584
CONFIG_ESP_MAIN_TASK_AFFINITY_CPU0=y
# CONFIG_ESP_MAIN_TASK_AFFINITY_NO_AFFINITY is not set
CONFIG_ESP_MAIN_TASK_AFFINITY=0x0
CONFIG_ESP_MINIMAL_SHARED_STACK_SIZE=2048
# CONFIG_ESP_CONSOLE_UART_DEFAULT is not set
CONFIG_ESP_CONSOLE_USB_SERIAL_JTAG=y
# CONFIG_ESP_CONSOLE_UART_CUSTOM is not set
# CONFIG_ESP_CONSOLE_NONE is not set
CONFIG_ESP_CONSOLE_SECONDARY_NONE=y
CONFIG_ESP_CONSOLE_UART_NUM=0
# CONFIG_ESP_INT_WDT is not set
# CONFIG_ESP_TASK_WDT is not set
# CONFIG_ESP_PANIC_HANDLER_IRAM is not set
# CONFIG_ESP_DEBUG_STUBS_ENABLE is not set
CONFIG_ESP_DEBUG_OCDAWARE=y
CONFIG_ESP_SYSTEM_CHECK_INT_LEVEL_4=y
# Brownout Detector
CONFIG_ESP_BROWNOUT_DET=y
CONFIG_ESP_BROWNOUT_DET_LVL_SEL_7=y
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_2 is not set
CONFIG_ESP_BROWNOUT_DET_LVL=7
# end of Brownout Detector
CONFIG_ESP_SYSTEM_BROWNOUT_INTR=y
# end of ESP System Settings
# IPC (Inter-Processor Call)
CONFIG_ESP_IPC_TASK_STACK_SIZE=1024
# end of IPC (Inter-Processor Call)
# High resolution timer (esp_timer)
# CONFIG_ESP_TIMER_PROFILING is not set
CONFIG_ESP_TIME_FUNCS_USE_RTC_TIMER=y
CONFIG_ESP_TIME_FUNCS_USE_ESP_TIMER=y
CONFIG_ESP_TIMER_TASK_STACK_SIZE=3584
CONFIG_ESP_TIMER_INTERRUPT_LEVEL=1
# CONFIG_ESP_TIMER_SUPPORTS_ISR_DISPATCH_METHOD is not set
CONFIG_ESP_TIMER_IMPL_SYSTIMER=y
# end of High resolution timer (esp_timer)
# Wi-Fi
CONFIG_ESP32_WIFI_ENABLED=y
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=10
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=32
# CONFIG_ESP32_WIFI_STATIC_TX_BUFFER is not set
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM=32
# CONFIG_ESP32_WIFI_CSI_ENABLED is not set
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=6
CONFIG_ESP32_WIFI_NVS_ENABLED=y
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP32_WIFI_MGMT_SBUF_NUM=32
CONFIG_ESP32_WIFI_IRAM_OPT=y
CONFIG_ESP32_WIFI_RX_IRAM_OPT=y
CONFIG_ESP32_WIFI_ENABLE_WPA3_SAE=y
CONFIG_ESP32_WIFI_ENABLE_WPA3_OWE_STA=y
# CONFIG_ESP_WIFI_SLP_IRAM_OPT is not set
# CONFIG_ESP_WIFI_FTM_ENABLE is not set
# CONFIG_ESP_WIFI_STA_DISCONNECTED_PM_ENABLE is not set
# CONFIG_ESP_WIFI_EXTERNAL_COEXIST_ENABLE is not set
# CONFIG_ESP_WIFI_GCMP_SUPPORT is not set
# CONFIG_ESP_WIFI_GMAC_SUPPORT is not set
CONFIG_ESP_WIFI_SOFTAP_SUPPORT=y
# CONFIG_ESP_WIFI_SLP_BEACON_LOST_OPT is not set
# end of Wi-Fi
# Core dump
# CONFIG_ESP_COREDUMP_ENABLE_TO_FLASH is not set
# CONFIG_ESP_COREDUMP_ENABLE_TO_UART is not set
CONFIG_ESP_COREDUMP_ENABLE_TO_NONE=y
# end of Core dump
# FAT Filesystem support
CONFIG_FATFS_VOLUME_COUNT=2
# CONFIG_FATFS_SECTOR_512 is not set
# CONFIG_FATFS_SECTOR_1024 is not set
# CONFIG_FATFS_SECTOR_2048 is not set
CONFIG_FATFS_SECTOR_4096=y
CONFIG_FATFS_SECTORS_PER_CLUSTER_1=y
# CONFIG_FATFS_SECTORS_PER_CLUSTER_2 is not set
# CONFIG_FATFS_SECTORS_PER_CLUSTER_4 is not set
# CONFIG_FATFS_SECTORS_PER_CLUSTER_8 is not set
# CONFIG_FATFS_SECTORS_PER_CLUSTER_16 is not set
# CONFIG_FATFS_SECTORS_PER_CLUSTER_32 is not set
# CONFIG_FATFS_SECTORS_PER_CLUSTER_64 is not set
# CONFIG_FATFS_SECTORS_PER_CLUSTER_128 is not set
# CONFIG_FATFS_CODEPAGE_DYNAMIC is not set
CONFIG_FATFS_CODEPAGE_437=y
# CONFIG_FATFS_CODEPAGE_720 is not set
# CONFIG_FATFS_CODEPAGE_737 is not set
# CONFIG_FATFS_CODEPAGE_771 is not set
# CONFIG_FATFS_CODEPAGE_775 is not set
# CONFIG_FATFS_CODEPAGE_850 is not set
# CONFIG_FATFS_CODEPAGE_852 is not set
# CONFIG_FATFS_CODEPAGE_855 is not set
# CONFIG_FATFS_CODEPAGE_857 is not set
# CONFIG_FATFS_CODEPAGE_860 is not set
# CONFIG_FATFS_CODEPAGE_861 is not set
# CONFIG_FATFS_CODEPAGE_862 is not set
# CONFIG_FATFS_CODEPAGE_863 is not set
# CONFIG_FATFS_CODEPAGE_864 is not set
# CONFIG_FATFS_CODEPAGE_865 is not set
# CONFIG_FATFS_CODEPAGE_866 is not set
# CONFIG_FATFS_CODEPAGE_869 is not set
# CONFIG_FATFS_CODEPAGE_932 is not set
# CONFIG_FATFS_CODEPAGE_936 is not set
# CONFIG_FATFS_CODEPAGE_949 is not set
# CONFIG_FATFS_CODEPAGE_950 is not set
CONFIG_FATFS_AUTO_TYPE=y
# CONFIG_FATFS_FAT12 is not set
# CONFIG_FATFS_FAT16 is not set
CONFIG_FATFS_CODEPAGE=437
CONFIG_FATFS_LFN_NONE=y
# CONFIG_FATFS_LFN_HEAP is not set
# CONFIG_FATFS_LFN_STACK is not set
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=y
# CONFIG_FATFS_USE_FASTSEEK is not set
# end of FAT Filesystem support
# FreeRTOS
# Kernel
# CONFIG_FREERTOS_SMP is not set
CONFIG_FREERTOS_UNICORE=y
CONFIG_FREERTOS_HZ=100
CONFIG_FREERTOS_OPTIMIZED_SCHEDULER=y
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE is not set
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL is not set
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1536
# CONFIG_FREERTOS_USE_IDLE_HOOK is not set
# CONFIG_FREERTOS_USE_TICK_HOOK is not set
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
# CONFIG_FREERTOS_ENABLE_BACKWARD_COMPATIBILITY is not set
CONFIG_FREERTOS_TIMER_TASK_PRIORITY=1
CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH=2048
CONFIG_FREERTOS_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
# CONFIG_FREERTOS_USE_TRACE_FACILITY is not set
# CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS is not set
# end of Kernel
# Port
CONFIG_FREERTOS_TASK_FUNCTION_WRAPPER=y
# CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK is not set
# CONFIG_FREERTOS_ENABLE_STATIC_TASK_CLEAN_UP is not set
CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER=y
CONFIG_FREERTOS_ISR_STACKSIZE=1536
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_TICK_SUPPORT_SYSTIMER=y
CONFIG_FREERTOS_CORETIMER_SYSTIMER_LVL1=y
# CONFIG_FREERTOS_CORETIMER_SYSTIMER_LVL3 is not set
CONFIG_FREERTOS_SYSTICK_USES_SYSTIMER=y
# CONFIG_FREERTOS_PLACE_FUNCTIONS_INTO_FLASH is not set
# CONFIG_FREERTOS_PLACE_SNAPSHOT_FUNS_INTO_FLASH is not set
# CONFIG_FREERTOS_CHECK_PORT_CRITICAL_COMPLIANCE is not set
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=y
CONFIG_FREERTOS_ENABLE_TASK_SNAPSHOT=y
# end of Port
CONFIG_FREERTOS_NO_AFFINITY=0x7FFFFFFF
CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION=y
CONFIG_FREERTOS_DEBUG_OCDAWARE=y
# end of FreeRTOS
# Hardware Abstraction Layer (HAL) and Low Level (LL)
CONFIG_HAL_ASSERTION_EQUALS_SYSTEM=y
# CONFIG_HAL_ASSERTION_DISABLE is not set
# CONFIG_HAL_ASSERTION_SILENT is not set
# CONFIG_HAL_ASSERTION_ENABLE is not set
CONFIG_HAL_DEFAULT_ASSERTION_LEVEL=2
# end of Hardware Abstraction Layer (HAL) and Low Level (LL)
# Heap memory debugging
CONFIG_HEAP_POISONING_DISABLED=y
# CONFIG_HEAP_POISONING_LIGHT is not set
# CONFIG_HEAP_POISONING_COMPREHENSIVE is not set
CONFIG_HEAP_TRACING_OFF=y
# CONFIG_HEAP_TRACING_STANDALONE is not set
# CONFIG_HEAP_TRACING_TOHOST is not set
# CONFIG_HEAP_ABORT_WHEN_ALLOCATION_FAILS is not set
# end of Heap memory debugging
# Log output
CONFIG_LOG_DEFAULT_LEVEL_NONE=y
# CONFIG_LOG_DEFAULT_LEVEL_ERROR is not set
# CONFIG_LOG_DEFAULT_LEVEL_WARN is not set
# CONFIG_LOG_DEFAULT_LEVEL_INFO is not set
# CONFIG_LOG_DEFAULT_LEVEL_DEBUG is not set
# CONFIG_LOG_DEFAULT_LEVEL_VERBOSE is not set
CONFIG_LOG_DEFAULT_LEVEL=0
CONFIG_LOG_MAXIMUM_EQUALS_DEFAULT=y
# CONFIG_LOG_MAXIMUM_LEVEL_ERROR is not set
# CONFIG_LOG_MAXIMUM_LEVEL_WARN is not set
# CONFIG_LOG_MAXIMUM_LEVEL_INFO is not set
# CONFIG_LOG_MAXIMUM_LEVEL_DEBUG is not set
# CONFIG_LOG_MAXIMUM_LEVEL_VERBOSE is not set
CONFIG_LOG_MAXIMUM_LEVEL=0
CONFIG_LOG_COLORS=y
CONFIG_LOG_TIMESTAMP_SOURCE_RTOS=y
# CONFIG_LOG_TIMESTAMP_SOURCE_SYSTEM is not set
# end of Log output
# LWIP
CONFIG_LWIP_LOCAL_HOSTNAME="espressif"
# CONFIG_LWIP_NETIF_API is not set
# CONFIG_LWIP_TCPIP_CORE_LOCKING is not set
CONFIG_LWIP_DNS_SUPPORT_MDNS_QUERIES=y
# CONFIG_LWIP_L2_TO_L3_COPY is not set
# CONFIG_LWIP_IRAM_OPTIMIZATION is not set
CONFIG_LWIP_TIMERS_ONDEMAND=y
CONFIG_LWIP_MAX_SOCKETS=10
# CONFIG_LWIP_USE_ONLY_LWIP_SELECT is not set
# CONFIG_LWIP_SO_LINGER is not set
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
# CONFIG_LWIP_SO_RCVBUF is not set
# CONFIG_LWIP_NETBUF_RECVINFO is not set
CONFIG_LWIP_IP4_FRAG=y
CONFIG_LWIP_IP6_FRAG=y
# CONFIG_LWIP_IP4_REASSEMBLY is not set
# CONFIG_LWIP_IP6_REASSEMBLY is not set
# CONFIG_LWIP_IP_FORWARD is not set
# CONFIG_LWIP_STATS is not set
CONFIG_LWIP_ESP_GRATUITOUS_ARP=y
CONFIG_LWIP_GARP_TMR_INTERVAL=60
CONFIG_LWIP_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=y
# CONFIG_LWIP_DHCP_DISABLE_CLIENT_ID is not set
CONFIG_LWIP_DHCP_DISABLE_VENDOR_CLASS_ID=y
# CONFIG_LWIP_DHCP_RESTORE_LAST_IP is not set
CONFIG_LWIP_DHCP_OPTIONS_LEN=68
CONFIG_LWIP_NUM_NETIF_CLIENT_DATA=0
# DHCP server
CONFIG_LWIP_DHCPS=y
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
# end of DHCP server
# CONFIG_LWIP_AUTOIP is not set
CONFIG_LWIP_IPV6=y
# CONFIG_LWIP_IPV6_AUTOCONFIG is not set
CONFIG_LWIP_IPV6_NUM_ADDRESSES=3
# CONFIG_LWIP_IPV6_FORWARD is not set
# CONFIG_LWIP_NETIF_STATUS_CALLBACK is not set
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
# TCP
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=16
CONFIG_LWIP_TCP_HIGH_SPEED_RETRANSMISSION=y
CONFIG_LWIP_TCP_MAXRTX=12
CONFIG_LWIP_TCP_SYNMAXRTX=12
CONFIG_LWIP_TCP_MSS=1440
CONFIG_LWIP_TCP_TMR_INTERVAL=250
CONFIG_LWIP_TCP_MSL=60000
CONFIG_LWIP_TCP_FIN_WAIT_TIMEOUT=20000
CONFIG_LWIP_TCP_SND_BUF_DEFAULT=5744
CONFIG_LWIP_TCP_WND_DEFAULT=5744
CONFIG_LWIP_TCP_RECVMBOX_SIZE=6
CONFIG_LWIP_TCP_QUEUE_OOSEQ=y
# CONFIG_LWIP_TCP_SACK_OUT is not set
CONFIG_LWIP_TCP_OVERSIZE_MSS=y
# CONFIG_LWIP_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_LWIP_TCP_OVERSIZE_DISABLE is not set
CONFIG_LWIP_TCP_RTO_TIME=1500
# end of TCP
# UDP
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_LWIP_UDP_RECVMBOX_SIZE=6
# end of UDP
# Checksums
# CONFIG_LWIP_CHECKSUM_CHECK_IP is not set
# CONFIG_LWIP_CHECKSUM_CHECK_UDP is not set
CONFIG_LWIP_CHECKSUM_CHECK_ICMP=y
# end of Checksums
CONFIG_LWIP_TCPIP_TASK_STACK_SIZE=3072
CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU0 is not set
CONFIG_LWIP_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_LWIP_PPP_SUPPORT is not set
CONFIG_LWIP_IPV6_MEMP_NUM_ND6_QUEUE=3
CONFIG_LWIP_IPV6_ND6_NUM_NEIGHBORS=5
# CONFIG_LWIP_SLIP_SUPPORT is not set
# ICMP
CONFIG_LWIP_ICMP=y
# CONFIG_LWIP_MULTICAST_PING is not set
# CONFIG_LWIP_BROADCAST_PING is not set
# end of ICMP
# LWIP RAW API
CONFIG_LWIP_MAX_RAW_PCBS=16
# end of LWIP RAW API
# SNTP
CONFIG_LWIP_SNTP_MAX_SERVERS=1
# CONFIG_LWIP_DHCP_GET_NTP_SRV is not set
CONFIG_LWIP_SNTP_UPDATE_DELAY=3600000
# end of SNTP
CONFIG_LWIP_BRIDGEIF_MAX_PORTS=7
CONFIG_LWIP_ESP_LWIP_ASSERT=y
# Hooks
# CONFIG_LWIP_HOOK_TCP_ISN_NONE is not set
CONFIG_LWIP_HOOK_TCP_ISN_DEFAULT=y
# CONFIG_LWIP_HOOK_TCP_ISN_CUSTOM is not set
CONFIG_LWIP_HOOK_IP6_ROUTE_NONE=y
# CONFIG_LWIP_HOOK_IP6_ROUTE_DEFAULT is not set
# CONFIG_LWIP_HOOK_IP6_ROUTE_CUSTOM is not set
CONFIG_LWIP_HOOK_ND6_GET_GW_NONE=y
# CONFIG_LWIP_HOOK_ND6_GET_GW_DEFAULT is not set
# CONFIG_LWIP_HOOK_ND6_GET_GW_CUSTOM is not set
CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_NONE=y
# CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_DEFAULT is not set
# CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_CUSTOM is not set
CONFIG_LWIP_HOOK_IP6_INPUT_NONE=y
# CONFIG_LWIP_HOOK_IP6_INPUT_DEFAULT is not set
# CONFIG_LWIP_HOOK_IP6_INPUT_CUSTOM is not set
# end of Hooks
# CONFIG_LWIP_DEBUG is not set
# end of LWIP
# mbedTLS
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
# CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC is not set
# CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC is not set
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
# CONFIG_MBEDTLS_DYNAMIC_BUFFER is not set
# CONFIG_MBEDTLS_DEBUG is not set
# mbedTLS v3.x related
# CONFIG_MBEDTLS_SSL_PROTO_TLS1_3 is not set
# CONFIG_MBEDTLS_SSL_VARIABLE_BUFFER_LENGTH is not set
# CONFIG_MBEDTLS_X509_TRUSTED_CERT_CALLBACK is not set
# CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION is not set
CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE=y
# end of mbedTLS v3.x related
# Certificate Bundle
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE=y
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_FULL=y
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_CMN is not set
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_NONE is not set
# CONFIG_MBEDTLS_CUSTOM_CERTIFICATE_BUNDLE is not set
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_MAX_CERTS=200
# end of Certificate Bundle
# CONFIG_MBEDTLS_ECP_RESTARTABLE is not set
# CONFIG_MBEDTLS_CMAC_C is not set
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_AES_USE_INTERRUPT=y
CONFIG_MBEDTLS_HARDWARE_MPI=y
CONFIG_MBEDTLS_MPI_USE_INTERRUPT=y
CONFIG_MBEDTLS_HARDWARE_SHA=y
CONFIG_MBEDTLS_ROM_MD5=y
# CONFIG_MBEDTLS_ATCA_HW_ECDSA_SIGN is not set
# CONFIG_MBEDTLS_ATCA_HW_ECDSA_VERIFY is not set
CONFIG_MBEDTLS_HAVE_TIME=y
# CONFIG_MBEDTLS_PLATFORM_TIME_ALT is not set
# CONFIG_MBEDTLS_HAVE_TIME_DATE is not set
CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y
CONFIG_MBEDTLS_SHA512_C=y
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
# CONFIG_MBEDTLS_TLS_SERVER_ONLY is not set
# CONFIG_MBEDTLS_TLS_CLIENT_ONLY is not set
# CONFIG_MBEDTLS_TLS_DISABLED is not set
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# TLS Key Exchange Methods
# CONFIG_MBEDTLS_PSK_MODES is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
# end of TLS Key Exchange Methods
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# CONFIG_MBEDTLS_SSL_PROTO_GMTSSL1_1 is not set
# CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS=y
# Symmetric Ciphers
CONFIG_MBEDTLS_AES_C=y
# CONFIG_MBEDTLS_CAMELLIA_C is not set
# CONFIG_MBEDTLS_DES_C is not set
# CONFIG_MBEDTLS_BLOWFISH_C is not set
# CONFIG_MBEDTLS_XTEA_C is not set
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
# CONFIG_MBEDTLS_NIST_KW_C is not set
# end of Symmetric Ciphers
# CONFIG_MBEDTLS_RIPEMD160_C is not set
# Certificates
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
# end of Certificates
CONFIG_MBEDTLS_ECP_C=y
# CONFIG_MBEDTLS_DHM_C is not set
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
# CONFIG_MBEDTLS_ECJPAKE_C is not set
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
# CONFIG_MBEDTLS_POLY1305_C is not set
# CONFIG_MBEDTLS_CHACHA20_C is not set
# CONFIG_MBEDTLS_HKDF_C is not set
# CONFIG_MBEDTLS_THREADING_C is not set
CONFIG_MBEDTLS_LARGE_KEY_SOFTWARE_MPI=y
# CONFIG_MBEDTLS_SECURITY_RISKS is not set
# end of mbedTLS
# ESP-MQTT Configurations
CONFIG_MQTT_PROTOCOL_311=y
# CONFIG_MQTT_PROTOCOL_5 is not set
CONFIG_MQTT_TRANSPORT_SSL=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET_SECURE=y
# CONFIG_MQTT_MSG_ID_INCREMENTAL is not set
# CONFIG_MQTT_SKIP_PUBLISH_IF_DISCONNECTED is not set
# CONFIG_MQTT_REPORT_DELETED_MESSAGES is not set
# CONFIG_MQTT_USE_CUSTOM_CONFIG is not set
# CONFIG_MQTT_TASK_CORE_SELECTION_ENABLED is not set
# CONFIG_MQTT_CUSTOM_OUTBOX is not set
# end of ESP-MQTT Configurations
# Newlib
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF is not set
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_LF is not set
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
# CONFIG_NEWLIB_NANO_FORMAT is not set
CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC_HRT=y
# CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC is not set
# CONFIG_NEWLIB_TIME_SYSCALL_USE_HRT is not set
# CONFIG_NEWLIB_TIME_SYSCALL_USE_NONE is not set
# end of Newlib
# NVS
# CONFIG_NVS_ASSERT_ERROR_CHECK is not set
# end of NVS
# OpenThread
# CONFIG_OPENTHREAD_ENABLED is not set
# end of OpenThread
# Protocomm
CONFIG_ESP_PROTOCOMM_SUPPORT_SECURITY_VERSION_0=y
CONFIG_ESP_PROTOCOMM_SUPPORT_SECURITY_VERSION_1=y
CONFIG_ESP_PROTOCOMM_SUPPORT_SECURITY_VERSION_2=y
# end of Protocomm
# PThreads
CONFIG_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_PTHREAD_STACK_MIN=768
CONFIG_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_PTHREAD_TASK_NAME_DEFAULT="pthread"
# end of PThreads
# SPI Flash driver
# CONFIG_SPI_FLASH_VERIFY_WRITE is not set
# CONFIG_SPI_FLASH_ENABLE_COUNTERS is not set
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_HAS_ROM_IMPL=y
# CONFIG_SPI_FLASH_ROM_IMPL is not set
CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS=y
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_FAILS is not set
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_ALLOWED is not set
# CONFIG_SPI_FLASH_SHARE_SPI1_BUS is not set
# CONFIG_SPI_FLASH_BYPASS_BLOCK_ERASE is not set
CONFIG_SPI_FLASH_YIELD_DURING_ERASE=y
CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS=20
CONFIG_SPI_FLASH_ERASE_YIELD_TICKS=1
# CONFIG_SPI_FLASH_AUTO_SUSPEND is not set
CONFIG_SPI_FLASH_WRITE_CHUNK_SIZE=8192
# CONFIG_SPI_FLASH_SIZE_OVERRIDE is not set
# CONFIG_SPI_FLASH_CHECK_ERASE_TIMEOUT_DISABLED is not set
# CONFIG_SPI_FLASH_OVERRIDE_CHIP_DRIVER_LIST is not set
# SPI Flash behavior when brownout
CONFIG_SPI_FLASH_BROWNOUT_RESET_XMC=y
CONFIG_SPI_FLASH_BROWNOUT_RESET=y
# end of SPI Flash behavior when brownout
# Auto-detect flash chips
CONFIG_SPI_FLASH_SUPPORT_ISSI_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_MXIC_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_GD_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_WINBOND_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_BOYA_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_TH_CHIP=y
# end of Auto-detect flash chips
CONFIG_SPI_FLASH_ENABLE_ENCRYPTED_READ_WRITE=y
# end of SPI Flash driver
# SPIFFS Configuration
CONFIG_SPIFFS_MAX_PARTITIONS=3
# SPIFFS Cache Configuration
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
# CONFIG_SPIFFS_CACHE_STATS is not set
# end of SPIFFS Cache Configuration
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
# CONFIG_SPIFFS_GC_STATS is not set
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
# CONFIG_SPIFFS_FOLLOW_SYMLINKS is not set
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=4
CONFIG_SPIFFS_USE_MTIME=y
# Debug Configuration
# CONFIG_SPIFFS_DBG is not set
# CONFIG_SPIFFS_API_DBG is not set
# CONFIG_SPIFFS_GC_DBG is not set
# CONFIG_SPIFFS_CACHE_DBG is not set
# CONFIG_SPIFFS_CHECK_DBG is not set
# CONFIG_SPIFFS_TEST_VISUALISATION is not set
# end of Debug Configuration
# end of SPIFFS Configuration
# TCP Transport
# Websocket
CONFIG_WS_TRANSPORT=y
CONFIG_WS_BUFFER_SIZE=1024
# CONFIG_WS_DYNAMIC_BUFFER is not set
# end of Websocket
# end of TCP Transport
# Unity unit testing library
CONFIG_UNITY_ENABLE_FLOAT=y
CONFIG_UNITY_ENABLE_DOUBLE=y
# CONFIG_UNITY_ENABLE_64BIT is not set
# CONFIG_UNITY_ENABLE_COLOR is not set
CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER=y
# CONFIG_UNITY_ENABLE_FIXTURE is not set
# CONFIG_UNITY_ENABLE_BACKTRACE_ON_FAIL is not set
# end of Unity unit testing library
# Virtual file system
CONFIG_VFS_SUPPORT_IO=y
CONFIG_VFS_SUPPORT_DIR=y
CONFIG_VFS_SUPPORT_SELECT=y
CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_VFS_SUPPORT_TERMIOS=y
# Host File System I/O (Semihosting)
CONFIG_VFS_SEMIHOSTFS_MAX_MOUNT_POINTS=1
# end of Host File System I/O (Semihosting)
# end of Virtual file system
# Wear Levelling
# CONFIG_WL_SECTOR_SIZE_512 is not set
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
# end of Wear Levelling
# Wi-Fi Provisioning Manager
CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=16
CONFIG_WIFI_PROV_AUTOSTOP_TIMEOUT=30
CONFIG_WIFI_PROV_BLE_FORCE_ENCRYPTION=y
# end of Wi-Fi Provisioning Manager
# Supplicant
CONFIG_WPA_MBEDTLS_CRYPTO=y
CONFIG_WPA_MBEDTLS_TLS_CLIENT=y
# CONFIG_WPA_WAPI_PSK is not set
# CONFIG_WPA_SUITE_B_192 is not set
# CONFIG_WPA_DEBUG_PRINT is not set
# CONFIG_WPA_TESTING_OPTIONS is not set
# CONFIG_WPA_WPS_STRICT is not set
# CONFIG_WPA_11KV_SUPPORT is not set
# CONFIG_WPA_MBO_SUPPORT is not set
# CONFIG_WPA_DPP_SUPPORT is not set
# CONFIG_WPA_11R_SUPPORT is not set
# CONFIG_WPA_WPS_SOFTAP_REGISTRAR is not set
# end of Supplicant
# end of Component config
# Deprecated options for backward compatibility
# CONFIG_NO_BLOBS is not set
CONFIG_LOG_BOOTLOADER_LEVEL_NONE=y
# CONFIG_LOG_BOOTLOADER_LEVEL_ERROR is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_WARN is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_INFO is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE is not set
CONFIG_LOG_BOOTLOADER_LEVEL=0
# CONFIG_APP_ROLLBACK_ENABLE is not set
# CONFIG_FLASH_ENCRYPTION_ENABLED is not set
# CONFIG_FLASHMODE_QIO is not set
# CONFIG_FLASHMODE_QOUT is not set
CONFIG_FLASHMODE_DIO=y
# CONFIG_FLASHMODE_DOUT is not set
CONFIG_MONITOR_BAUD=115200
CONFIG_OPTIMIZATION_LEVEL_DEBUG=y
CONFIG_COMPILER_OPTIMIZATION_LEVEL_DEBUG=y
# CONFIG_OPTIMIZATION_LEVEL_RELEASE is not set
# CONFIG_COMPILER_OPTIMIZATION_LEVEL_RELEASE is not set
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
# CONFIG_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED is not set
CONFIG_OPTIMIZATION_ASSERTION_LEVEL=2
# CONFIG_CXX_EXCEPTIONS is not set
CONFIG_STACK_CHECK_NONE=y
# CONFIG_STACK_CHECK_NORM is not set
# CONFIG_STACK_CHECK_STRONG is not set
# CONFIG_STACK_CHECK_ALL is not set
# CONFIG_WARN_WRITE_STRINGS is not set
# CONFIG_ESP32_APPTRACE_DEST_TRAX is not set
CONFIG_ESP32_APPTRACE_DEST_NONE=y
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
# CONFIG_EVENT_LOOP_PROFILING is not set
CONFIG_POST_EVENTS_FROM_ISR=y
CONFIG_POST_EVENTS_FROM_IRAM_ISR=y
# CONFIG_OTA_ALLOW_HTTP is not set
# CONFIG_ESP_SYSTEM_PD_FLASH is not set
CONFIG_ESP32C3_LIGHTSLEEP_GPIO_RESET_WORKAROUND=y
CONFIG_ESP32C3_RTC_CLK_SRC_INT_RC=y
# CONFIG_ESP32C3_RTC_CLK_SRC_EXT_CRYS is not set
# CONFIG_ESP32C3_RTC_CLK_SRC_EXT_OSC is not set
# CONFIG_ESP32C3_RTC_CLK_SRC_INT_8MD256 is not set
CONFIG_ESP32C3_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
CONFIG_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_REDUCE_PHY_TX_POWER=y
CONFIG_ESP_SYSTEM_PM_POWER_DOWN_CPU=y
# CONFIG_ESP32C3_DEFAULT_CPU_FREQ_80 is not set
CONFIG_ESP32C3_DEFAULT_CPU_FREQ_160=y
CONFIG_ESP32C3_DEFAULT_CPU_FREQ_MHZ=160
CONFIG_ESP32C3_MEMPROT_FEATURE=y
CONFIG_ESP32C3_MEMPROT_FEATURE_LOCK=y
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_MAIN_TASK_STACK_SIZE=3584
# CONFIG_CONSOLE_UART_DEFAULT is not set
# CONFIG_CONSOLE_UART_CUSTOM is not set
# CONFIG_CONSOLE_UART_NONE is not set
# CONFIG_ESP_CONSOLE_UART_NONE is not set
CONFIG_CONSOLE_UART_NUM=0
# CONFIG_INT_WDT is not set
# CONFIG_TASK_WDT is not set
# CONFIG_ESP32_DEBUG_STUBS_ENABLE is not set
CONFIG_ESP32C3_DEBUG_OCDAWARE=y
CONFIG_BROWNOUT_DET=y
CONFIG_ESP32C3_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_7=y
CONFIG_ESP32C3_BROWNOUT_DET_LVL_SEL_7=y
# CONFIG_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_ESP32C3_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_ESP32C3_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_ESP32C3_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_ESP32C3_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_ESP32C3_BROWNOUT_DET_LVL_SEL_2 is not set
CONFIG_BROWNOUT_DET_LVL=7
CONFIG_ESP32C3_BROWNOUT_DET_LVL=7
CONFIG_IPC_TASK_STACK_SIZE=1024
CONFIG_TIMER_TASK_STACK_SIZE=3584
# CONFIG_EXTERNAL_COEX_ENABLE is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_UART is not set
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=2048
CONFIG_TIMER_QUEUE_LENGTH=10
# CONFIG_ENABLE_STATIC_TASK_CLEAN_UP_HOOK is not set
# CONFIG_HAL_ASSERTION_SILIENT is not set
# CONFIG_L2_TO_L3_COPY is not set
CONFIG_ESP_GRATUITOUS_ARP=y
CONFIG_GARP_TMR_INTERVAL=60
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=12
CONFIG_TCP_MSS=1440
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
CONFIG_TCP_OVERSIZE_MSS=y
# CONFIG_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_TCP_OVERSIZE_DISABLE is not set
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=3072
CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_TCPIP_TASK_AFFINITY_CPU0 is not set
CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_PPP_SUPPORT is not set
CONFIG_ESP32C3_TIME_SYSCALL_USE_RTC_SYSTIMER=y
# CONFIG_ESP32C3_TIME_SYSCALL_USE_RTC is not set
# CONFIG_ESP32C3_TIME_SYSCALL_USE_SYSTIMER is not set
# CONFIG_ESP32C3_TIME_SYSCALL_USE_NONE is not set
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_ESP32_PTHREAD_STACK_MIN=768
CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT="pthread"
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS is not set
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED is not set
CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_SUPPORT_TERMIOS=y
CONFIG_SEMIHOSTFS_MAX_MOUNT_POINTS=1
# End of deprecated options
vm__dm
Re: Using UART0 and U0TXD U0RXD as regular UART on ESP32-C3
Postby vm__dm » Fri Dec 16, 2022 8:10 am
I did some more testing. I took the serial echo sample and leave log output only on USB Jtag/CDC.
I could run it using UART 1 controller on pins MTMS/GPIO4 for TX and MTDI/GPIO5 for RX.
I changed UART controller to UART 0 and it still works on the same pinout (so it doesn't seem to be an issue using that specific UART controller).
I configured UART 0 TX pin on U0TXD/GPIO21, keeping RX as before (MTDI/GPIO5).
Then I moved RX to U0RXD/GPIO20 and echo is not longer working (no character is received on the UART).
There is something I need to do on the IOMUX layer to enable Rx path for U0RXD/GPIO20?
Pinout seem to suggest that those pins are "dedicated" to the UART and also those used by boot ROM, so I thought it was the suggested connection to be used for UART interface...
vm__dm
Postby vm__dm » Fri Dec 16, 2022 10:42 am
This thing is really driving me crazy.
I use the uart_echo example and I still can't receive any character on U0RXD/GPIO20.
I see output from ROM and the "hello" string, but sending character to that pin doesn't seem to lead to any result.
I also tried to use esp_rom to route that signal via GPIO matrix, but this doesn't seem to improve the situation.
If I change ECHO_TEST_RXD to 5 then everything work.
I am using an ESP32-c3-devkitm-1 board (only change is that I moved the two resistors to bypass the USB2serial converter on the board and connect USB signals directly to the MCU.
I connected an FTDI 3.3V cable to the board (only GND, TX, and RX are connected) to test.
I swapped both the board and the cable, to be sure that this is not a hardware fault.
I connected a scope to the pin and see the signal from FTDI cable to the RX pin, so issue seem to be on the ESP32 side.
/* UART Echo Example
   This example code is in the Public Domain (or CC0 licensed, at your option.)
   Unless required by applicable law or agreed to in writing, this
   software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
   CONDITIONS OF ANY KIND, either express or implied.
#include <stdio.h>
#include "freertos/task.h"
#include "driver/uart.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
#include "esp_log.h"
#include "soc/io_mux_reg.h"
#include "soc/gpio_sig_map.h"
#include "soc/gpio_struct.h"
#include "soc/uart_pins.h"
#include "soc/uart_periph.h"
#include "hal/gpio_hal.h"
 * This is an example which echos any data it receives on configured UART back to the sender,
 * with hardware flow control turned off. It does not use UART driver event queue.
 * - Port: configured UART
 * - Receive (Rx) buffer: on
 * - Transmit (Tx) buffer: off
 * - Flow control: off
 * - Event queue: off
 * - Pin assignment: see defines below (See Kconfig)
#define ECHO_TEST_TXD (21)
#define ECHO_TEST_RXD (20)
#define ECHO_TEST_RTS (UART_PIN_NO_CHANGE)
#define ECHO_TEST_CTS (UART_PIN_NO_CHANGE)
#define ECHO_UART_PORT_NUM      (0)
#define ECHO_UART_BAUD_RATE     (CONFIG_EXAMPLE_UART_BAUD_RATE)
#define ECHO_TASK_STACK_SIZE    (CONFIG_EXAMPLE_TASK_STACK_SIZE)
static const char *TAG = "UART TEST";
#define BUF_SIZE (1024)
static void echo_task(void *arg)
    /* Configure parameters of an UART driver,
     * communication pins and install the driver */
        .baud_rate = ECHO_UART_BAUD_RATE,
    int intr_alloc_flags = 0;
#if CONFIG_UART_ISR_IN_IRAM
    intr_alloc_flags = ESP_INTR_FLAG_IRAM;
#endif
    ESP_ERROR_CHECK(uart_param_config(ECHO_UART_PORT_NUM, &uart_config));
    ESP_ERROR_CHECK(uart_driver_install(ECHO_UART_PORT_NUM, BUF_SIZE * 2, 0, 0, NULL, intr_alloc_flags));
    ESP_ERROR_CHECK(uart_set_pin(ECHO_UART_PORT_NUM,ECHO_TEST_TXD,ECHO_TEST_RXD,ECHO_TEST_RTS,ECHO_TEST_CTS));
    gpio_hold_dis(ECHO_TEST_RXD);
    gpio_hold_dis(ECHO_TEST_TXD);
    gpio_hal_iomux_func_sel(GPIO_PIN_MUX_REG[ECHO_TEST_TXD], PIN_FUNC_GPIO);
    gpio_set_level(ECHO_TEST_TXD, 1);
    esp_rom_gpio_connect_out_signal(ECHO_TEST_TXD, UART_PERIPH_SIGNAL(ECHO_UART_PORT_NUM, SOC_UART_TX_PIN_IDX), 0, 0);
    gpio_hal_iomux_func_sel(GPIO_PIN_MUX_REG[ECHO_TEST_RXD], PIN_FUNC_GPIO);
    gpio_set_pull_mode(ECHO_TEST_RXD, GPIO_PULLUP_ONLY);
    gpio_set_direction(ECHO_TEST_RXD, GPIO_MODE_INPUT);
    esp_rom_gpio_pad_unhold(ECHO_TEST_RXD);
    esp_rom_gpio_pad_pullup_only(ECHO_TEST_RXD);
    esp_rom_gpio_pad_select_gpio(ECHO_TEST_RXD);
    esp_rom_gpio_connect_in_signal(ECHO_TEST_RXD, UART_PERIPH_SIGNAL(ECHO_UART_PORT_NUM, SOC_UART_RX_PIN_IDX), 0);
    uart_write_bytes(ECHO_UART_PORT_NUM, (const char *) "hello", 5);
    // Configure a temporary buffer for the incoming data
    uint8_t *data = (uint8_t *) malloc(BUF_SIZE);
    while (1) {
        // Read data from the UART
        int len = uart_read_bytes(ECHO_UART_PORT_NUM, data, (BUF_SIZE - 1), 20 / portTICK_PERIOD_MS);
        // Write data back to the UART
        uart_write_bytes(ECHO_UART_PORT_NUM, (const char *) data, len);
        if (len) {
            data[len] = '\0';
            ESP_LOGI(TAG, "Recv str: %s", (char *) data);
void app_main(void)
    xTaskCreate(echo_task, "uart_echo_task", ECHO_TASK_STACK_SIZE, NULL, 10, NULL);
vm__dm
Postby vm__dm » Fri Dec 16, 2022 1:17 pm
Ok, I found the issue.
We re-wired the ESP32C3 board to bypass the on-board USB2UART (we wanted to test in a situation close to the final HW setup).
We moved R1-R2 to R3-R4, as suggested here:
https://esp32.com/viewtopic.php?t=21007
But we didn't remove R21 and R22 so the UART pins were still connected to the Cp210 converter. This didn't seem to be an issue for TXD but was preventing RXD from working (probably signal quality was impacted, even if it didn't look so bad during a quick check with an oscilloscope).
So, if you want to bypass the converter on that board is better to remove also R21-R22.
learning_mcu
Postby learning_mcu » Thu Jun 08, 2023 11:33 am
Hi, I am stuck also trying to use UART0 and U0TXD U0RXD as regular UART on ESP32-C3. It is a custom board. Where everything else works fine, connects to network, reads interrupts, and reads I2C line. For RS485 communication, I am using an "Auto direction control by transistor" scheme here.
https://iotips.tech/tag/esp32/
which is also used in a waveshare product. And works well with RP2040. I did a side by side comparison with an equivalent code using RPI PICO SDK.
https://www.waveshare.com/w/upload/0/02 ... -RS485.pdf
This kind of scheme where TXD pin is grounded is also in ESP's documentatation. Please see, The circuit C: auto switching of transmitter/receiver in the documentation
Screenshot 2023-06-08 at 02.00.04.png (377.2 KiB) Viewed 7058 times
, where TXD is grounded too:
https://docs.espressif.com/projects/esp ... /uart.html
Here is my schematic and code
Screenshot 2023-06-07 at 03.09.39.png (330.37 KiB) Viewed 7058 times
. I cannot get the RS485 device to respond on ESP32C3. Same Can you give me some leads please.
#include "uart_handler.h"
#include "esp_system.h"
#include "string.h"
const uart_port_t uart_num = UART_NUM_0;
.baud_rate = 38400,
//.rx_flow_ctrl_thresh = 122,
// Configure UART parameters
ESP_ERROR_CHECK(uart_param_config(uart_num, &uart_config));
// Set UART pins(TX: IO4, RX: IO5, RTS: IO18, CTS: IO19)
ESP_ERROR_CHECK(uart_set_pin(UART_NUM_0, 20, 21, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE));
// Setup UART in rs485 mode
ESP_ERROR_CHECK(uart_set_mode(uart_num, UART_MODE_RS485_APP_CTRL));
// ESP_ERROR_CHECK(uart_set_mode(uart_num, UART_RS485_CONF_REG.UART_RS485RXBY_TX_EN = 1));
// ESP_ERROR_CHECK(uart_set_mode(uart_num, , UART_RS485_CONF_REG.UART_RS485TX_RX_EN = 0));
// Setup UART buffered IO with event queue
const int uart_buffer_size = (1024 * 2);
QueueHandle_t uart_queue;
// Install UART driver using an event queue here
ESP_ERROR_CHECK(uart_driver_install(UART_NUM_0, uart_buffer_size,
uart_buffer_size, 10, &uart_queue, 0));
void tx_task() {
// Write data to UART.
uart_flush(uart_num);
// uart_flush_input(uart_num);
char* test_str = "getData\n\r";
uart_write_bytes(uart_num, (const char*)test_str, strlen(test_str));
// Write data to UART, end with a break signal.
// uart_write_bytes_with_break(uart_num, const char*)test_str,strlen(test_str), 100);
vTaskDelay(pdMS_TO_TICKS(500));
void rx_task(char rxdata[RX_BUF_SIZE]) {
tx_task();
// Read data from UART.
uint8_t data[128];
int length = 0;
ESP_ERROR_CHECK(uart_get_buffered_data_len(uart_num, (size_t*)&length));
length = uart_read_bytes(uart_num, data, length, 100);
ESP_LOGI("UART HANDLER", "Read %d bytes: '%s'", length, (char*) data);
Users browsing this forum: Amazon [Bot], Bytespider, Google [Bot], Semrush [Bot] and 4 guests
