Where is the driver/* layer in my Arduino/ESP32 libraries?
leleroy
Postby leleroy » Thu Dec 22, 2022 5:16 am
I installed the ESP32-Arduino support (via the Library Manager) according to this link:
https://docs.espressif.com/projects/ard ... ds-manager
But can't find ESP-IDF driver/* layer files at all?
https://docs.espressif.com/projects/esp ... ction.html
To be clear, can't include:
#include "driver/xxx.h"
Do I need different installation on top of the ESP32-Arduino support method?
If yes, how can I do it safely without any collisions?
lbernstone
Re: Where is the driver/* layer in my Arduino/ESP32 libraries?
Postby lbernstone » Thu Dec 22, 2022 3:22 pm
There is no xxx driver, only the devices on board...
There is a further layer of abstraction for Arduino. You should use the arduino drivers rather than IDF.
https://github.com/espressif/arduino-es ... ores/esp32
https://github.com/espressif/arduino-es ... ude/driver
leleroy
Postby leleroy » Fri Dec 23, 2022 8:46 pm
Got it. Thanks!
Users browsing this forum: Baidu [Spider], Barkrowler, meta-externalagent and 1 guest
