I recently designed and manufactured a custom PCB with PCBWay using the ESP32S3-1-N16 microcontroller and when I try to upload firmware via PlatformIO that worked on a previous PCB design, I get an error message saying:
Uploading .pio/build/esp32-s3-devkitc-1/firmware.bin
esptool.py v4.2.1
Serial port /dev/cu.usbserial-0001
Connecting......................................
A fatal error occurred: Failed to connect to ESP32-S3: Wrong boot mode detected (0xb)! The chip needs to be in download mode.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html"
In a previous design, I had designed a PCB with an ESP32 WROOM module where the EN pin was connected to RESET and I didn't have a BOOT button and it works perfectly. As a logical next step, I wanted to update the PCB by replacing a micro USB receptacle with a USB C receptacle as well as replace the ESP32 WROOM module with a ESP32S3-1-N16 module. I even tested this design using a ESP32S3-dev-kit-C to make sure my original firmware from the original design worked on the new design (give or take renaming certain GPIOs due to a different pin mapping) and it worked just fine. But when I designed my latest PCB, I didn't add and connect a BOOT button that existed on the ESP32S3-dev-kit-C. Here are some screenshots of my current schematic's ESP32S3 module
- ESP32S3-1-N16
- Screen Shot 2022-12-27 at 5.12.32 PM.png (123.8 KiB) Viewed 4946 times
as well as the associated RESET schematic
- Reset
- Screen Shot 2022-12-27 at 5.13.57 PM.png (129.18 KiB) Viewed 4946 times
. What should I do to mitigate the above error so that I can successfully upload new firmware given that I cannot switch between "Boot" and "Download" modes? Any help or guidance would be greatly appreciated!
