Already working codes doesn't work any more.
brigei
Postby brigei » Sat Jan 07, 2023 8:49 pm
below is my code which already worked. Unfortunately now I get this error.
CORRUPT HEAP: Bad head at 0x3f85dc2c. Expected 0xabba1234 got 0x3f9ffff4
abort() was called at PC 0x4008a41d on core 1
ELF file SHA256: 0000000000000000
Backtrace: 0x4008de14:0x3ffdca10 0x4008e08d:0x3ffdca30 0x4008a41d:0x3ffdca50 0x4008a549:0x3ffdca80 0x400fd3db:0x3ffdcaa0 0x400f8eb5:0x3ffdcd60 0x400f8dbd:0x3ffdcdb0 0x400933dd:0x3ffdcde0 0x40082746:0x3ffdce00 0x4008a315:0x3ffdce20 0x4000bec7:0x3ffdce40 0x400d1152:0x3ffdce60 0x4011b9dd:0x3ffdcf80 0x4011c535:0x3ffdcfb0 0x4011c5ed:0x3ffdd040 0x4011bc48:0x3ffdd060 0x4011acc0:0x3ffdd080 0x4011ad17:0x3ffdd0c0 0x4008fd1e:0x3ffdd0e0
Rebooting...
Code: Untitled.cpp Select all
#include "esp_camera.h"
#include <WiFi.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include <LITTLEFS.h>
#include <FS.h>
#include "esp_timer.h"
#include "Arduino.h"
#include "fb_gfx.h"
#include "esp_http_server.h"
#define led 33
#define PART_BOUNDARY "123456789000000000000987654321"
const char* ssid = "Mi Casa";
const char* password = "W1xldgmnuweadWs!";
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
httpd_handle_t stream_httpd = NULL;
static esp_err_t stream_handler(httpd_req_t *req){
camera_fb_t * fb = NULL;
esp_err_t res = ESP_OK;
size_t _jpg_buf_len = 0;
uint8_t * _jpg_buf = NULL;
char * part_buf[64];
res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
if(res != ESP_OK){
return res;
while(true){
fb = esp_camera_fb_get();
_jpg_buf_len = fb->len;
_jpg_buf = fb->buf;
if(res == ESP_OK){
size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
esp_camera_fb_return(fb);
fb = NULL;
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
break;
return res;
void startCameraServer(){
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
config.server_port = 80;
httpd_uri_t index_uri = {
.uri = "/",
.method = HTTP_GET,
.handler = stream_handler,
.user_ctx = NULL
Serial.printf("Starting web server on port: '%d'\n", config.server_port);
if (httpd_start(&stream_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(stream_httpd, &index_uri);
void setup()
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); // prevent brownouts by silencing them
Serial.begin(115200);
Serial.setDebugOutput(true);
Serial.println();
pinMode(led, OUTPUT);
LITTLEFS.begin(true);
WiFi.begin(ssid, password);
Serial.print("WLAN Verbindungsaufbau...");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(200);
Serial.println();
Serial.println("Verbunden");
Serial.print("IP-Adresse: ");
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = 5;
config.pin_d1 = 18;
config.pin_d2 = 19;
config.pin_d3 = 21;
config.pin_d4 = 36;
config.pin_d5 = 39;
config.pin_d6 = 34;
config.pin_d7 = 35;
config.pin_xclk = 0;
config.pin_pclk = 22;
config.pin_vsync = 25;
config.pin_href = 23;
config.pin_sscb_sda = 26;
config.pin_sscb_scl = 27;
config.pin_pwdn = 32;
config.pin_reset = -1;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
else {
Serial.println("Camera initialisiert.");
sensor_t * s = esp_camera_sensor_get();
s->set_framesize(s, FRAMESIZE_UXGA);
s->set_vflip(s, 0);
s->set_hmirror(s, 0);
startCameraServer();
void loop()
delay(1000);
Re: Already working codes doesn't work any more.
Postby Sprite » Sun Jan 08, 2023 3:04 am
You're free()'ing _jpg_buf while you do not own the memory it points to (it's a pointer to a member of fb, and that memory gets freed with esp_camera_fb_return())
brigei
Postby brigei » Sun Jan 08, 2023 1:03 pm
Thanks for your reply. That‘s it!
Greetings.
PS: Now I just have to find out how to close this post ;)
