Hi everyone,
I'm attempting to have ESP32-S3 acting like a oscillator to drive another MCU, so I need a stable clock output.
I've look around here and github, someone mentioned the I2S APLL on ESP32, but it's not available on ESP32-S3. Does that mean I have to use a ledc generator? I'm kinda afraid that the frequency stability won't meet the requirement. Is there a better way to achieve this?
32MHz clock output on ESP32-S3?
rpiloverbd
Re: 32MHz clock output on ESP32-S3?
Have you seen this thread? viewtopic.php?t=1037
It talks about 20MHz though.
That's the LEDC way, it seems that the clock is not as accurate as needed.
What do you need wrt accuracy? Simply the right frequency, or do you also need low jitter?
I was trying to drive another MCU to save some space on the pcb. I tested it with a dupont line (~19cm long) and an ESP32-S3-DevKit-M, routing output to GPIO38. While the usb controller (on the other chip) works properly, flashing a new firmware using uart is a constant fail. I left ESP32-S3 continuously working when operating the other chip, so the clock should not break off.
Missed the reply button, see above please.What do you need wrt accuracy? Simply the right frequency, or do you also need low jitter?
Hm, your issue may be jitter. LEDC uses 80MHz as a base clock, and that doesn't divide nicely into 32MHz; the only way to do it is with a fractional divider, and that introduces jitter. Unfortunately, USB is pretty insistent on a low-jitter clock signal; depending on how the clock infrastructure of the other MCU works, there likely isn't a way to get this to work with the LEDC at all.
Some peripherals in the ESP32S3 can use an internal 160MHz generated by the PLL as a base clock, e.g. the LCD/camera device. If you don't use that, there may be a way to abuse it to generate a clock... 160/5=32 exactly.
Yes, I noticed that too!Hm, your issue may be jitter. LEDC uses 80MHz as a base clock, and that doesn't divide nicely into 32MHz; the only way to do it is with a fractional divider, and that introduces jitter. Unfortunately, USB is pretty insistent on a low-jitter clock signal; depending on how the clock infrastructure of the other MCU works, there likely isn't a way to get this to work with the LEDC at all.
esp_lcd_panel_handle_t panel_handle = NULL;
esp_lcd_rgb_panel_config_t panel_config = {
.data_width = 16, // RGB565 in parallel mode, thus 16bit in width
.clk_src = LCD_CLK_SRC_PLL160M,
.pclk_gpio_num = HSE_OUTPUT_IO,
.timings = {
.pclk_hz = HSE_FREQUENCY,
.h_res = 1,
.v_res = 1,
// The following parameters should refer to LCD spec
.hsync_back_porch = 40,
.hsync_front_porch = 20,
.hsync_pulse_width = 1,
.vsync_back_porch = 8,
.vsync_front_porch = 4,
.vsync_pulse_width = 1,
ESP_ERROR_CHECK(esp_lcd_new_rgb_panel(&panel_config, &panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_reset(panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_init(panel_handle));
is it too later here?
is it possible to use ESP32S3 make a clock without use Internet and External RTC module?
Adam
Adam
