Faced a strange problem with ESP32-WROOM-32U.
If I initialize the RGBMatrix panel (32*64, NOT connected to ESP32board, only initialization), then initialize the STA wifi, the ESP immediately gives the error
Guru Meditation Error: Core 1 panic'ed (Cache disabled but cached memory region accessed).Code:
#include <WiFi.h>
#include <Adafruit_GFX.h>
#include <RGBmatrixPanel.h>
#define A 12
#define B 16
#define C 17
#define D 18
#define CLK 15
#define LAT 32
#define OE 33
#define Sound 14
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false, 64);
const char* ssid = "SSID";
const char* password = "PASSWORD";
void setup()
Serial.begin(115200);
Serial.println("Starting Screen");
Serial.println("");
pinMode(Sound, OUTPUT);
//beep on start
tone(Sound, 5000, 400);
vTaskDelay(1000/portTICK_PERIOD_MS);
noTone(Sound);
Serial.println("Starting WiFi STA");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("Starting Matrix");
matrix.begin(); // setup the LED matrix
matrix.setTextWrap(false); // Don't wrap at end of line - will do ourselves
matrix.fillScreen(0);
void loop()
}Code: Select all
ELF file SHA256: 0000000000000000
Rebooting...
ets Jun 8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13864
load:0x40080400,len:3608
entry 0x400805f0
[ 4][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
Starting Screen
[ 32][D][Tone.cpp:124] tone(): _pin=14, frequency=5000 Hz, duration=400 ms
[ 32][V][Tone.cpp:62] tone_init(): Creating tone queue
[ 34][V][Tone.cpp:68] tone_init(): Tone queue created
[ 39][V][Tone.cpp:72] tone_init(): Creating tone task
[ 44][V][Tone.cpp:85] tone_init(): Tone task created
[ 49][D][Tone.cpp:31] tone_task(): Task received from queue TONE_START: _pin=14, frequency=5000 Hz, duration=400 ms
[ 59][D][Tone.cpp:33] tone_task(): Setup LED controll on channel 0
[ 1049][D][Tone.cpp:105] noTone(): noTone was called
Starting WiFi STA
[ 1049][D][Tone.cpp:45] tone_task(): Task received from queue TONE_END: pin=14
[ 1066][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
[ 1152][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
[ 1154][V][WiFiGeneric.cpp:97] set_esp_interface_ip(): Configuring Station static IP: 0.0.0.0, MASK: 0.0.0.0, GW: 0.0.0.0
[ 1154][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
Starting Matrix
[ 3579][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: SSID, BSSID: 00:00:00:00:00:00, Reason: 201
[ 3580][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
[ 3587][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
[ 3593][D][WiFiGeneric.cpp:966] _eventCallback(): WiFi Reconnect Running
Core 1 register dump:
PC : 0x400d5c58 PS : 0x00060035 A0 : 0x8008199d A1 : 0x3ffbf21c
A2 : 0x00000000 A3 : 0x0036f318 A4 : 0x8008f3a0 A5 : 0x3ffb7e50
A6 : 0x00000003 A7 : 0x00060323 A8 : 0x800d5c58 A9 : 0x3ffbf1fc
A10 : 0x0036f30f A11 : 0x00000000 A12 : 0x0036f30e A13 : 0x80000000
A14 : 0x007bf298 A15 : 0x003fffff SAR : 0x00000020 EXCCAUSE: 0x00000007
EXCVADDR: 0x00000000 LBEG : 0x400852d5 LEND : 0x400852dd LCOUNT : 0x00000027
Backtrace:0x400d5c55:0x3ffbf21c |<-CORRUPTEDWhat could be causing the reboots?
