New Node Attribute not Visible
Quabis
Postby Quabis » Tue Feb 21, 2023 8:57 pm
Hi All,
I am trying to add a Status Attribute to the rm_node and plan to update it in periodically to inform about certain processes that are currently running.
The plan was to add either of the two lines below into the Rainmaker setup() method
    esp_rmaker_node_add_attribute(rm_node.getNodeHandle(), "Status", "initializing...");
    rm_node.addNodeAttr("Status","initializing...");
and then updating them while the app is running.
However the attribute is not shown in when i open the details of the node where i can see the Firmware, NodeId etc...
also not when i call
    esp_rmaker_report_node_details();
after setting the Status during rainmaker setup
Any help is very much appreciated.
Piyush
Re: New Node Attribute not Visible
Postby Piyush » Thu Feb 23, 2023 6:08 am
Node attributes are meant to be read only values giving additional info about the node. The current phone apps do not show it anywhere. Only devices and device parameters are shown in the apps. You can check any RainMaker example to see what devices and params are and how to update them.
Quabis
Postby Quabis » Thu Feb 23, 2023 10:24 am
thank you very much for the reply.
Would be a nice feature, since i got parameters that are meant to be identical for all devices...
Best regards
Users browsing this forum: DuckDuckGo [Bot] and 1 guest
